  4. Dt200 engine build
Dt200 engine build
13 Posts 6 Posters 3.0k Views
  • SamRatBoyS Offline
    SamRatBoyS Offline
    SamRatBoy
    Hey there all. I've been wanting to fit a Dt200 engine into my for a few years now and so when I saw a reasonable priced seized 200 bottom end on eBay I couldn't resist. I however couldn't find a reasonable priced Wr200 barrel with powervalve nor a Dt200 barrel. Eventually I spotted a Sdr200 cylinder on the bay complete with power valve (sadly it doesn't have boost ports like the we 😞 ) and purchased it. Needless to say the crank will be sent for a rebuild. My question is does anyone know if the taper on the flywheel side of the Dt200 crank is the same as the Dt125? Im having trouble finding a 200 stator, flywheel and cdi. I'm hoping at first to be able to run it with the 125 stator and cdi. I know it won't be running at optimum but can anyone confirm if this won't work or will be harmful to the engine or have any ideas. Thanks, Sam
    • ChallengerC Offline
      ChallengerC Offline
      Challenger
      3ET/2YY DT200R stator and flywheel are exactly the same as in DT125R. Only difference is part number stamped on the flywheel.
      SamRatBoyS 1 Reply Last reply
      • ChallengerC Challenger
        SamRatBoyS Offline
        SamRatBoyS Offline
        SamRatBoy
        @Challenger excellent news 🙂 thanks for the reply
        • autovictorA Offline
          autovictorA Offline
          autovictor
          is it possible to fit the re/x stator on the dt/wr 200 crankshaft? does anybody did the 200 conversion on a re/x?
          • autovictorA autovictor
            @autovictor The RE/X Flywheel goes on reverse to that of the DTR and has the starter motor teeth.
            So at a guess, I'd say it's not possible without modifications. Woodruff key will be in the wrong place and taper of the crank will be wrong.
            • O Offline
              O Offline
              Joining the 200 club! Be a while though, got my holiday to pay for first!
              ChallengerC 1 Reply Last reply
              3
              • O oldman
                ChallengerC Offline
                ChallengerC Offline
                Challenger
                @oldman nice to see that cylinder on the forum 😀
                • pedrobatista10P Offline
                  pedrobatista10
                  guys how much cost 3xp barrel at the moment? saw one on ebay from greece for 215€ ( need to be repaired i guess)
                    ChallengerC Offline
                    ChallengerC Offline
                    Challenger
                    @pedrobatista10 there are really a lot of variables when it comes to the condition of a barrel
                      pedrobatista10
                      @Challenger this one, i think its the only one for sale on ebay.
                      https://www.ebay.com/itm/yamaha-wr200-cylinder-barrel-barel-jug-dt-4bf-3xp-wr-200-wr200rd-dt200-dt200wr/143238727899?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D004f0a5e233846359e4fc32bca6e4f96%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D143238727899%26itm%3D143238727899%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6ccdbf0e-46a6-11ea-a919-74dbd18033a0|parentrq%3A0bfd5ebd1700a861903b0e28ffee23c0|iid%3A1
                        No way, at that price I'd give it a miss!
                        You definitely want the valve & head.
                        The crack needs welding, it'll need replating. I've seen entire engines go for not much more than that.
                        Not worth the gain in my opinion.
                          pedrobatista10
                          look at this beautiful kit, not cheap but looks very good
                          https://www.olx.pt/anuncio/kit-cilindro-200-para-yamaha-dt-125-r-dtr-tzr-rz-IDEht5T.html
                            Missing the head. If that had the head it would be more of a goer.
