  3. DTRE
  4. DT 125R not starting
20 Posts 4 Posters 3.7k Views
  • O Offline
    O Offline
    Oisin
    Hello again everyone.
    My dt won't start. I was riding it around earlier in the day then I put it into the shed to work on it, in the process the fuel line snapped so I took of the carb and hooked one up to it. After that it wouldn't start. I checked for spark which I have and I tried my best to give the carb a good cleaning. The fuel level is a bit low so I'm wondering if I really need to top it up past the reserve. Not sure though. Any ideas. All help appreciated, thanks
      Is the float blocked. Is the spark plug wet. Are you sure it's getting fuel.
      Easy(dirty) way to check. Spray a lynx deodrant into the combustion chamber and try and start it. If it fires into life (even briefly) you know it's a fueling issue.
      NINJAN O 3 Replies Last reply
        NINJAN Offline
        NINJAN Offline
        @Calum Does it have to be Lynx??? 😀 😀 😀
          O Offline
          O Offline
          Oisin
          @Calum Ok thanks Calum I'll give it a try 👍
            O Offline
            O Offline
            Oisin
            @Calum I did that and she fired briefly (thanks be to God) where should I go from here?
            • O Oisin
              @Oisin Well it's a fueling issue then by the sounds of it.
              Take the carb off and ensure the needle isn't shutting the float off.
              O 2 Replies Last reply
                O Offline
                O Offline
                Oisin
                @Calum Ok ill play around with the carb and let u know thanks again
                  O Offline
                  O Offline
                  Oisin
                  @Calum I checked the float and adjusted it to be in line with the carb bidy itself. I cleaned out the fuel tank and tried again, still nothing. Any ideas on what gat I can do next? Would it be worth talking of the side panel of the carb and looking in there?
                    I'm sorry, I'm really confused.
                    The bike was working, you then broke a fuel line and now it doesn't work?
                    So quite clearly the only thing that's changed is that fuel line.
                    O 1 Reply Last reply
                      O Offline
                      O Offline
                      Oisin
                      @Calum I know I'm lost myself what else could it possibly be like. So frustrating
                        Well it sounds like a fueling issue.
                          O Offline
                          O Offline
                          Oisin
                          @Calum Would u have any ideas where I would go from here
                          markus.wM 2 Replies Last reply
                            Yes, check the fueling.
                            • O Oisin
                              markus.wM Offline
                              markus.wM Offline
                              @Oisin is it possible at all that when you replaced said fuel pipe it was connected back up incorrectly/ wrong place/wrong way around? Just a thought.
                              • O Oisin
                                markus.wM Offline
                                markus.wM Offline
                                @Oisin maybe check said fuel pipe is actually allowing fuel to pass through. I presume it's a new pipe but stranger things have happened.
                                  @markus-w I had this when I replaced it with a silicone host, it kinked and stopped fuel from flowing.
                                  Use properly braided and rated fuel hose. Is my advice.
                                    markus.wM Offline
                                    markus.wM Offline
                                    @Calum yes I agree. That's good advice. Some parts it doesn't matter so much but there's certain things you just can't skimp on.
                                      O Offline
                                      O Offline
                                      Oisin
                                      @markus-w got it going it was the fuel line thanks very much
                                      • O Oisin
                                        markus.wM Offline
                                        markus.wM Offline
                                        @Oisin happy days, you're most welcome. Can I ask what was wrong with the fuel line?
                                          O Offline
                                          O Offline
                                          Oisin
                                          @markus-w It appeared to be kinked under the fuel tank and so I couldn't see it. I also have the tank a good clean out which helped a lot I think
