  3. Wheels
  4. Rear wheel
Rear wheel
47 Posts 4 Posters 11.9k Views
    jonne123
    Different forks? Swingarm? What can you recommend and most cheaply?
    • J jonne123
      @jonne123 Yeah you know, the Aprilia has completely different geometry to the DTR. So it's going to need fabrication.
      The front and rear wheel need to be aligned. The front and rear sprockets need to align. The wheels need to be centralised. Cause it's from a completely different machine.
        jonne123
        maybe spacers like the has my uncles friend is machinist
          If money is a concern, stick with what you got and put some decent tyres on it.
          Even Excel rims are expensive and require work. So there is no one easy solution.
          The easiest way to do it would be to buy some nice and expensive Excel rims, and lace up your hubs to them That way you retain the original brakes and spacers and geometry with SM Rims.
          The DTX solution, you need forks, brakes and wheels. These were hard to come by new, now it's practically a nightmare.
          • J jonne123
            @jonne123 If you don't mind fabricating parts, then you'll need spacers and the hub carriers modified to take the bigger brakes. and a bracket made to mount the brakes to the wheels.
            Can see the work required in my DTRE build thread as I run RS125 wheels on my DTR.
              jonne123
              I know i need brake caliper upradge nad change just brake leg on right. on rear put the wheel backwars
                jonne123
                can you link the thread
                  No, you need to centralise the wheels, rotate the tyres and also line up the front and rear sprockets. Otherwise you'll chew through rear sprocket carrier bearings in no time at all!
                    https://dt125r.co.uk/topic/15/the-leviathan-project/127
                      jonne123
                      #24
                      but the axle radious is the same? can i keep front brake caliper at left side?
                        jonne123
                        does stock rs hub carries fit?
                          No nothing fits, it all has to be fabricated. Even the spindles are different sizes.
                          The front spindle is too small. Rear spindle was okay.
                            If you have access to a machinist, the cost is minimal. But it all adds up. Hours on the lathe and precise measurements were necessary to get all the stars to align. I had to shim the rear sprocket to get it to fall inline with the front.
                            When I took the bike in to have the tyres replaced. They omitted the shims and the rear sprocket carrier bearing collapsed shortly after. So it does have to be on point.
                              jonne123
                              #28
                              And in summer i go to machine shop for summerwork so i can make them afterwork.
                              And are the rims same size if you can give some measurements of the parts?
                              How about the speedo?
                              Does the ride quality increase
                              • J jonne123
                                @jonne123 WR 125 wheels fit
                                  jonne123
                                  #30
                                  But could buy those for 20€
                                  So 20€ for skf wheel bearings
                                  • front brake disc
                                  -Rear sprocket
                                  -speedometer drive
                                  • front caliper
                                  -fabrication metal
                                  So i would image around
                                  200€
                                  So not that bad
                                  • declanD
                                    it very rarely is as easy as you expect but i suppose if you follow callums build thread in relation to your wheels you will be okay
                                      jonne123
                                      I plan to do this as simple as possible.
                                      Rear:
                                      Sprockets and 520 chain
                                      Spacers
                                      Front:
                                      Spacers
                                      Speedo drive
                                      Front axle
                                      Brake upradge
                                        @jonne123 You need adaptors for the brakes!
                                        You have to centralise the brakes over the disc, otherwise one side of the pad will just bind against the disc.
                                        It's a lot of work. The easiest thing to do is just get decent tyres on a DTR setup,
                                          @Calum I don’t think he will listen to us lol
