  3. Wheels
  4. Rear wheel
Rear wheel
47 Posts 4 Posters 12.5k Views
    jonne123
    can you link the thread
      No, you need to centralise the wheels, rotate the tyres and also line up the front and rear sprockets. Otherwise you'll chew through rear sprocket carrier bearings in no time at all!
        https://dt125r.co.uk/topic/15/the-leviathan-project/127
          jonne123
          #24
          but the axle radious is the same? can i keep front brake caliper at left side?
            jonne123
            does stock rs hub carries fit?
              No nothing fits, it all has to be fabricated. Even the spindles are different sizes.
              The front spindle is too small. Rear spindle was okay.
                If you have access to a machinist, the cost is minimal. But it all adds up. Hours on the lathe and precise measurements were necessary to get all the stars to align. I had to shim the rear sprocket to get it to fall inline with the front.
                When I took the bike in to have the tyres replaced. They omitted the shims and the rear sprocket carrier bearing collapsed shortly after. So it does have to be on point.
                  jonne123
                  #28
                  And in summer i go to machine shop for summerwork so i can make them afterwork.
                  And are the rims same size if you can give some measurements of the parts?
                  How about the speedo?
                  Does the ride quality increase
                  • J jonne123
                    @jonne123 WR 125 wheels fit
                      jonne123
                      #30
                      But could buy those for 20€
                      So 20€ for skf wheel bearings
                      • front brake disc
                      -Rear sprocket
                      -speedometer drive
                      • front caliper
                      -fabrication metal
                      So i would image around
                      200€
                      So not that bad
                      • declanD
                        it very rarely is as easy as you expect but i suppose if you follow callums build thread in relation to your wheels you will be okay
                          jonne123
                          I plan to do this as simple as possible.
                          Rear:
                          Sprockets and 520 chain
                          Spacers
                          Front:
                          Spacers
                          Speedo drive
                          Front axle
                          Brake upradge
                            @jonne123 You need adaptors for the brakes!
                            You have to centralise the brakes over the disc, otherwise one side of the pad will just bind against the disc.
                            It's a lot of work. The easiest thing to do is just get decent tyres on a DTR setup,
                              @Calum I don’t think he will listen to us lol
                                jonne123
                                How big of a difference is good tires on sm wheel or enduro? And im just planning its atleast 3 monts to a 1.5 years when i will be ready
                                  I will say right now mate, the most fun I've had on my DTR is in bog stock trim.
                                  I absolutely adored the handling of it stock, or lack there of.
                                  My SM DT just grips and stops on a dime and that's really safe, but doesn't make for much fun.
                                  Now I love my setup, wouldn't change it for the world. I'm just saying, grass isn't always greener.
                                  By far the best thing you can do, get some dual sport tyres (so you can still do light off roading). Stiffen that front suspension unit up. get a pipe on it and a 3MB head if it hasn't got it already and and a Zeeltronic ignition system.
                                  You bike will be absolute hoon to ride and will pack a little punch too.
                                  Otherwise, I'd sell that DTR and get a better bike like an Aprilia MX125. Trust me, if I had my time again, that's exactly what I'd do.
                                    jonne123
                                    Well its fastest on the town so... its good enough for me
                                    • J jonne123
                                      @jonne123 Trust me, focus on sorting the brakes out, decent tyres and a few little mods. Don't spend too much money on it, it simply isn't worth it. Better bikes out there. And these bikes will be best left in stock trim. be worth more!
                                        jonne123
                                        After all mods the total spend is around 1200€
                                          Including the price of the bike.
                                          Cause I mean...
                                          Could just get one of those bad boys 😃
