Help!
I put my clutch together. The gears worked fine. I noticed i didnt align the balance axle. I fixed that. I test my gears no oil. Didnt work. I pushed that axle it locked on down. I had to remove the clutch basket. Then i put it back on the drum . Few gers worked now nothing. Did i fuck it from insade or did i put the the axle in wrong pin on the selectol rum end? Pls help
Are you selecting gears on the work bench? Or is it in the bike?
I sometimes find you need to rock the engine a little to get gears to select succinctly. So just rotating the clutch basket left and right and try selecting gears once you have a small revolution.
