  4. Help!
Help!
6 Posts 3 Posters 585 Views
    jonne123
    I put my clutch together. The gears worked fine. I noticed i didnt align the balance axle. I fixed that. I test my gears no oil. Didnt work. I pushed that axle it locked on down. I had to remove the clutch basket. Then i put it back on the drum . Few gers worked now nothing. Did i fuck it from insade or did i put the the axle in wrong pin on the selectol rum end? Pls help
      Are you selecting gears on the work bench? Or is it in the bike?
      I sometimes find you need to rock the engine a little to get gears to select succinctly. So just rotating the clutch basket left and right and try selecting gears once you have a small revolution.
        jonne123
        At bike i only touched the clutch. How to i know what pin i put the gear axle end on the gear drum
          jonne123
          Because i pushed the axle and it came of the drum
            jonne123
            I hope i didnt f anyrhing up insade but i dont think thats possible
            • J jonne123
              @jonne123 look a few videos up on YouTube there’s one I saw yesterday that shows the gear drum
