  4. Oil level
Oil level
6 Posts 4 Posters 505 Views
    jonne123
    I have newer style clutch cover with 1 line should the oil be at that line when engine is warmed?
    • tunertomT Offline
      tunertomT Offline
      tunertom
      you always check/set oil levels when cold
        jonne123
        In haynes manual it says run it wait the oill to setle
          750ml of oil. It says it on the side of the case.
            jonne123
            It looks low after i added the oil
            • J jonne123
              @jonne123 as long as you put the 750 in and didn’t leak or spill any it’s fine
