Brake pedal travel
Is there a way to adjust the amount of travel in the brake pedal? Or is it just a case of bleeding the brake line and changing the pads. The pads have enough meat on them brake fluid level is fine, I’d just like less travel on them unless that what they are like on the DT. My foot ends up and a 45 degree angle downwards to fully press it. Cheers
Is there a way to adjust the amount of travel in the brake pedal? Or is it just a case of bleeding the brake line and changing the pads. The pads have enough meat on them brake fluid level is fine, I’d just like less travel on them unless that what they are like on the DT. My foot ends up and a 45 degree angle downwards to fully press it. Cheers @DTlee yes there is. As @NINJA said it's just below the master cylinder it's a 11mm adjuster nut and 12mm lock nut, loosen lock nut and adjust so the pedal rests just below the top of the footpeg, about half inch. Though if there is too much travel in the pedal it's probably air in the system and needs bleeding.
Thanks for the response going to try and bleed it as brake pedal looks like it’s in the right position already so I don’t think I’ll be able to adjust it any more annoyingly @DTlee Buy one of these kits dude, they make bleeding brakes a doodle and you get 100% air free brake fluid every time!!!
