portingignitech4dldtrwr200
135 Posts 27 Posters 142.0k Views 6 Watching
    I am running Apico KTM ones. Nice and wide.
    PeluriP 1 Reply Last reply
      PeluriP
      PeluriP
      Peluri
      @Calum That's nice, how do the KTM pegs fit the DTR? Any modding needed or bolt-on?
        I just ground down the ends of them as they wouldn't sit flush. It's a very minor mod I didn't think twice about it.
          PeluriP
          PeluriP
          Peluri
          @Calum Ok so they fit easily? I'll think about getting myself a pair of those then!
            Yeah it was simple. I tried looking I could find exactly what I bought. I must have done it after I "finished" my bike and thus didn't document it. But yeah was a really easy mod and now I have Phat footrests.
              PeluriP
              PeluriP
              Peluri
              @Calum Really nice! My only problem is the budget, those things are like a 100€ 😬 Maybe I should get some Chinesium ones 😅
              • PeluriP Peluri
                @Peluri the Chinese footpegs look nice been meaning to get a set
                  PeluriP
                  PeluriP
                  Peluri
                  @declan Alright, I'll get myself a pair of those! Thanks!
                    Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                    QUICK ENOUGH LOL
                    finchfockerF
                    finchfockerF
                    finchfocker
                    @Darty what ignitec cdi did you go for?? Ive sent an email and they have recommended the DCCDIP1 race
                    • finchfockerF finchfocker
                      PeluriP
                      PeluriP
                      Peluri
                      @finchfocker I myself just bought the DCCDIP1 race. Seems like a great unit, just programmed myself a ignition map to start off with, hopefully I'll get a chance to plug her in soon!
