portingignitech4dldtrwr200
135 Posts 27 Posters 141.9k Views 6 Watching
  • C
    C
    conmador
    hey, are the calipers you designed for the dtx front brake? or is it for dtr front brake? because if it is for dtx front brake i would be interested
    • MiniaM
      MiniaM
      Minia
      Thats a cool dtr!
        @declan Cheers boss, yeah I guess it hasn't risen much, it's not running right at top end RPM's. Possibly the Reeds failing.
        It's amazing how much more torquey it is than before, it's not a bad commuter bike still πŸ˜‚
        Stevie WonderS
        Stevie WonderS
        Stevie Wonder
        @Darty this is what’s sat at the top of my tabs list for the past 4 weeks, your bike build. It’s Mk1 stage with the aprillia headlight and YZ wheels is probably my biggest inspiration for my bike to date. Timeless classic looking crosser and I can’t relp but keep looking at or referring to the pictures of it late at night πŸ˜‰ (when I’m on eBay that is and not a certain other website πŸ˜‚)
        DartyD 1 Reply Last reply
          @dtStevie98
          Lost but not forgotten, back on a standard Top end, bent Shifter fork and Clutch issues, bent caliper hanger, seized caliper piston, slightly bent yokes as it turns out from long ago, and the Dep Expansion pipe that is only 65% left in existence.
          I also dented the tank very badly and cannot pull it out, it's trashed,
          And the Power-valve which was 'fully sent'. It blew the remaining pin out the exhaust,, I think as the bottom end didn't grenade itself.
          It was doing 80mph in 5th gear and still pulling, so it was mission accomplished.
          Full Yeet.
            wrote on last edited by Darty
            #97
            *Nobody
            ME:
            *A custom inlet tract for a DT125R.
            Couple beers and some eyeballing and you can make whatever you want.
            Getting to old for Pod filters and hacking shit bits together. So if you could, why not re-design OEM equipment in your favour?
            Knocked these up on Solidworks to be a straight swap into the frame and Airbox.
            The brief, for my application, getting an inlet tract as straight as possible for 34mm or larger Carburettor to fit around my YZ490 shock, which is way larger than the original DTR unit.
            Science bitch.
            I have access to a 3D printer, so I've been designing and making prototypes just for a bit of fun after work,
            Technology these days....,
            4
              Lions smart, is it up to the task though...
                *Nobody
                ME:
                Science bitch.
                Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                @Darty Would you be kind enough to send me the STL file for the intake manifold so i can 3d print this on my printer please buddy?
                  @Walney-Reptiles Yeh when I've made a working prototype I'll let you know bud,
                    Walney-ReptilesW
                    Walney-ReptilesW
                    Walney-Reptiles
                    @Darty cheers, il have to edit it to fit my carb "When i get it"
                      Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                      QUICK ENOUGH LOL
                      NINJAN declanD J Louis-DT-WRL finchfockerF 5 Replies Last reply
                      3
                        QUICK ENOUGH LOL
                        @Darty Looking damn good my man!!! πŸ‘
                          QUICK ENOUGH LOL
                          @Darty amazing
                            Absolutely sweet bud! Nice carb boot.
                              QUICK ENOUGH LOL
                              Jbplap
                              @Darty
                              That DTX bracket looks sweet, any chance you could make another one for sale?
                              I would be very interested!
                              CalumC DartyD 2 Replies Last reply
                              • J Jbplap
                                @Darty
                                @Jbplap Got 4 years to wait? Oh and another Global Pandemic by the sounds of things 🀣
                                  @Calum Now now - play nice!!! 😜
                                    @NINJA Sorry, should I have used the "Quote" feature. I was just relaying that @Darty Said it's taken him 4 years and a pandemic to sort his brakes out.
                                    • J Jbplap
                                      @Darty
                                      @Jbplap Yeh nah maybe, long ting it’s effort I’d have to charge for my time, and @Calum is right πŸ˜‚,
                                        @Darty I'm only talking from experience. The amount of time spent on a manual lathe to make the worlds smallest simplest component, and what you would want for doing it is not justifiable.
                                        That said, what else ya doing πŸ˜›
                                          @Calum said in SuperDeet125R '01 - Running Project:
                                          As the saying goes; "Better late than never!!!" 😁 πŸ˜€ 😁
