portingignitech4dldtrwr200
135 Posts 27 Posters 141.9k Views 6 Watching
    @Darty btw that bike is legendary well fucking done man
    @declan Cheers boss, yeah I guess it hasn't risen much, it's not running right at top end RPM's. Possibly the Reeds failing.
    It's amazing how much more torquey it is than before, it's not a bad commuter bike still 😂
      32 degrees, sticky rubber, cotswold country lanes, 2strokes and considerable beer intake on par with University life.
      I ride this thing 22 miles a day as a daily to go work, built this thing to be used and I just 'turn it up' a little on the Laptop for a blitz on the weekend somewhere.
      Drawing this project to a close, and enjoying the result, or atleast this iteration of it so far...
      I had some clearance issues with the Powervalve under expansion. I removed material in increments by machine sanding.
      Custom bracket for the FMF Powercore1 can. Fits on a DTR well.
      Built the headlight brackets,
      WR400 Face swap.
      There is no room left on this bike. Made a mount for the Ignitech Ignition, secure, doesn't suffer from heat exposure and most importantly it's accessible.
      As for cooling, air flow is fine still.
      Modified AS3 Silicone WR200 radiator hose's to suit this mongrel application.
      This leads me to something interesting I found,
      I needed a new WR200 coolant pipe, turns out later 4BF4 1995' WR200s use a larger 18mm bore coolant pipe.
      I got one brand new old stock from Japan. I've rust protected it, primer and a Gold top coat for a little bling.
      Then of course a 4BF4 Waterpump cover is required.
      4BF4' Pictured above vs 125R/200R
      I never knew Yamaha updated the cooling for the WR200, so I had help getting a used one.
      IT ONLY JUST FITS... Tight bruuuh. I made a brace for the coolant down pipe as it's just a braised joint and I managed to split my last one like a clot.
      Originally this mounts onto the WR200 Cylinder, so ideally this has to be done to the 125R barrel.
      Cooling is now more than adequate,
      WR200 Inlet, TM32 fitted. This inlet gives you more angle to use larger carburettor bodies.
      WR200 vs DT125R. Inlet tract a little longer, Mounting points have to be modified and crankcase stuffers removed.
      New YZ braided brake lines and removable exhaust joint to get the FMF onto the DEP.
      (An oldschool mechanical display setup. Dorky but I love this older stuff.
      The fun bits. Built to be ridden alot!
      Using a base map close to a TZR125 4DL SP, It runs particularly well under 6K.
      This DT now shifts.. I use a 4DL servo setting which utilises the PV opening later than the DT or TDR 3SH.
      It's far from perfect, but a safe base tune to run on as this is my daily as the weather is so good.
      It's run in properly now, and it is glorious. It sounds fantastic over 10,000rpm.
      Powerband is up at 9,500rpm and it pulls hard to 13,000.
      DTR Gear ratios are perfect for this TZR head and it's acceleration characteristic is spot on, 0-62 less than 6 seconds.
      More to come, more bits from Japan to arrive and then finally a Dyno session with a TM34ss fitted.
      Stay safe!
      @Darty Oh my, yes bud this is fantastic!!!!! 😄
      • MightymanM
        Very interested to see the dyno results!
          #92
          Yeah me 2 😃
          • C
            C
            conmador
            hey, are the calipers you designed for the dtx front brake? or is it for dtr front brake? because if it is for dtx front brake i would be interested
            • MiniaM
              MiniaM
              Minia
              Thats a cool dtr!
                Stevie WonderS
                Stevie WonderS
                Stevie Wonder
                @Darty this is what’s sat at the top of my tabs list for the past 4 weeks, your bike build. It’s Mk1 stage with the aprillia headlight and YZ wheels is probably my biggest inspiration for my bike to date. Timeless classic looking crosser and I can’t relp but keep looking at or referring to the pictures of it late at night 😉 (when I’m on eBay that is and not a certain other website 😂)
                DartyD 1 Reply Last reply
                  @dtStevie98
                  Lost but not forgotten, back on a standard Top end, bent Shifter fork and Clutch issues, bent caliper hanger, seized caliper piston, slightly bent yokes as it turns out from long ago, and the Dep Expansion pipe that is only 65% left in existence.
                  I also dented the tank very badly and cannot pull it out, it's trashed,
                  And the Power-valve which was 'fully sent'. It blew the remaining pin out the exhaust,, I think as the bottom end didn't grenade itself.
                  It was doing 80mph in 5th gear and still pulling, so it was mission accomplished.
                  Full Yeet.
                    wrote on last edited by Darty
                    #97
                    *Nobody
                    ME:
                    *A custom inlet tract for a DT125R.
                    Couple beers and some eyeballing and you can make whatever you want.
                    Getting to old for Pod filters and hacking shit bits together. So if you could, why not re-design OEM equipment in your favour?
                    Knocked these up on Solidworks to be a straight swap into the frame and Airbox.
                    The brief, for my application, getting an inlet tract as straight as possible for 34mm or larger Carburettor to fit around my YZ490 shock, which is way larger than the original DTR unit.
                    Science bitch.
                    I have access to a 3D printer, so I've been designing and making prototypes just for a bit of fun after work,
                    Technology these days....,
                    4
                      Lions smart, is it up to the task though...
                        *Nobody
                        ME:
                        Science bitch.
                        Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        @Darty Would you be kind enough to send me the STL file for the intake manifold so i can 3d print this on my printer please buddy?
                          @Walney-Reptiles Yeh when I've made a working prototype I'll let you know bud,
                            Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            @Darty cheers, il have to edit it to fit my carb "When i get it"
                              Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                              QUICK ENOUGH LOL
                              NINJAN declanD J Louis-DT-WRL finchfockerF 5 Replies Last reply
                              3
                                QUICK ENOUGH LOL
                                @Darty Looking damn good my man!!! 👍
                                  QUICK ENOUGH LOL
                                  @Darty amazing
                                    Absolutely sweet bud! Nice carb boot.
                                      QUICK ENOUGH LOL
                                      Jbplap
                                      @Darty
                                      That DTX bracket looks sweet, any chance you could make another one for sale?
                                      I would be very interested!
                                      CalumC DartyD 2 Replies Last reply
                                      • J Jbplap
                                        @Darty
                                        @Jbplap Got 4 years to wait? Oh and another Global Pandemic by the sounds of things 🤣
                                          @Calum Now now - play nice!!! 😜
