portingignitech4dldtrwr200
135 Posts 27 Posters 142.0k Views 6 Watching
    @Darty this is what’s sat at the top of my tabs list for the past 4 weeks, your bike build. It’s Mk1 stage with the aprillia headlight and YZ wheels is probably my biggest inspiration for my bike to date. Timeless classic looking crosser and I can’t relp but keep looking at or referring to the pictures of it late at night πŸ˜‰ (when I’m on eBay that is and not a certain other website πŸ˜‚)
    @dtStevie98
    Lost but not forgotten, back on a standard Top end, bent Shifter fork and Clutch issues, bent caliper hanger, seized caliper piston, slightly bent yokes as it turns out from long ago, and the Dep Expansion pipe that is only 65% left in existence.
    I also dented the tank very badly and cannot pull it out, it's trashed,
    And the Power-valve which was 'fully sent'. It blew the remaining pin out the exhaust,, I think as the bottom end didn't grenade itself.
    It was doing 80mph in 5th gear and still pulling, so it was mission accomplished.
    Full Yeet.
      wrote on last edited by Darty
      #97
      *Nobody
      ME:
      *A custom inlet tract for a DT125R.
      Couple beers and some eyeballing and you can make whatever you want.
      Getting to old for Pod filters and hacking shit bits together. So if you could, why not re-design OEM equipment in your favour?
      Knocked these up on Solidworks to be a straight swap into the frame and Airbox.
      The brief, for my application, getting an inlet tract as straight as possible for 34mm or larger Carburettor to fit around my YZ490 shock, which is way larger than the original DTR unit.
      Science bitch.
      I have access to a 3D printer, so I've been designing and making prototypes just for a bit of fun after work,
      Technology these days....,
      4
        Lions smart, is it up to the task though...
          *Nobody
          ME:
          Science bitch.
          Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          @Darty Would you be kind enough to send me the STL file for the intake manifold so i can 3d print this on my printer please buddy?
          DartyD 1 Reply Last reply
            @Walney-Reptiles Yeh when I've made a working prototype I'll let you know bud,
              Walney-ReptilesW
              Walney-ReptilesW
              Walney-Reptiles
              @Darty cheers, il have to edit it to fit my carb "When i get it"
                Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                QUICK ENOUGH LOL
                NINJAN declanD J Louis-DT-WRL finchfockerF 5 Replies Last reply
                3
                  QUICK ENOUGH LOL
                  @Darty Looking damn good my man!!! πŸ‘
                    QUICK ENOUGH LOL
                    @Darty amazing
                      Absolutely sweet bud! Nice carb boot.
                        QUICK ENOUGH LOL
                        Jbplap
                        @Darty
                        That DTX bracket looks sweet, any chance you could make another one for sale?
                        I would be very interested!
                        CalumC DartyD 2 Replies Last reply
                        • J Jbplap
                          @Darty
                          @Jbplap Got 4 years to wait? Oh and another Global Pandemic by the sounds of things 🀣
                            @Calum Now now - play nice!!! 😜
                              @NINJA Sorry, should I have used the "Quote" feature. I was just relaying that @Darty Said it's taken him 4 years and a pandemic to sort his brakes out.
                              • J Jbplap
                                @Darty
                                @Jbplap Yeh nah maybe, long ting it’s effort I’d have to charge for my time, and @Calum is right πŸ˜‚,
                                  @Darty I'm only talking from experience. The amount of time spent on a manual lathe to make the worlds smallest simplest component, and what you would want for doing it is not justifiable.
                                  That said, what else ya doing πŸ˜›
                                    @Calum said in SuperDeet125R '01 - Running Project:
                                    As the saying goes; "Better late than never!!!" 😁 πŸ˜€ 😁
                                    • Stevie WonderS
                                      Stevie WonderS
                                      Stevie Wonder
                                      Welcome to every possibly carb option for a DTR, the darty edition.
                                      Never heard of Nikkon before. Pretty pipe I must add proper phat boi. Also good to see you cracking on at last man
                                        Well. I sometimes wonder why I bother. If you have ever ridden a proper Off-road motorcycle, you quickly realise when thraping a DT, just what a sqeegey, pogo stick, slightly too small, floppy forked, 80s steel timer chassis it really is. When it comes to modifying a DT. You might aswell buy something better. But anyway, I like playing with it so..
                                        Fitted a 1/4 Action throttle from a 1988 KX80. The throttle tube is a larger diameter, much more comfortable and has been invaluable as an upgrade. I had to modify my 'Genuine' throttle cable by cutting back a bit of outer sheath. XT600 brake lever is a great swap, and I use a little shorty alloy clutch lever of a 85cc on there.
                                        Needed to replace the original headlight cluster.
                                        Missed out on a decent Yamaha WR400 headlight.(Perfect shape) Got one of a Aprilia RX, had to do some wiring for this. Needed to be painted white of course. Its worse than the DT headlight.. but, got the look.
                                        If your into DTRs. Then the DT200R (3ET) is the one to have. I couldn't find much information on these (YZ) wheel upgrades I've seen. I wanted alloy wheels on it like the 200. So after some research and a failed attempt at getting a set of WR200 wheels, I concluded that 1988-94 Yamaha YZ wheels have the same size rear hub as the DT. Straight swap. For the front, had to be 1987'-1988' because they ran similar sized rotors back then. However the hubs are about 10mm wider on the YZ, So I chose some YZ 1986' front spacers, looked similar proportion to match a DT fork in the pictures. If your going to swap to a YZ wheel, I gave up trying to fit the Speedo drive back on and took it off. Took of the clocks. Then fitted a bicycle wired speedo, just for an MOT really.. its crap and does not register the pick up past 60 mph or so. Minor price to pay. A vapour unit out of the budget. Don't need idiot lights for wheelies.
                                        Yamaha built the 1986-1988 YZs with Gold anodised rims and man.. wish I could find a back one. The front is a 1988- the back of a 1994. MX was starting to use 19" rear wheels for better drive and handling back in the early 90s. Yamaha were on this on the YZ range. Bigger wheel does throw the gearing off slightly on acceleration. Got a big dutty knobbly on the back and you really loose out on power if you have to nip along the road.
                                        The rear shock is crap on any DTR, or at least mine was. Did some googling' and a man in Australia agreed with me, and I had to copy his idea for myself. The DT uses the same shock to linkage fixing as 87-88' YZs Shipped a 1987' Yamaha YZ490 Rear shocker that bolts right in! Its even got Yamaha's 'B.A.S.S' system on it. Which is rubbish.. but cool anyway. When fitting it, the top damper mount on a YZ frame is different, apparently much narrower than the DT frame, so you will need to use the bearing with it's fixed spacer off the DT shock and replace the YZ one with it. I actually used two big cable ties instead just to stop any lateral movement under compression. Anyway I now have Adjustable spring rate, Damping settings and Rebound settings. It will sit pretty high on a firm setting. 4-5cm lift. I also stuck with my short Dog-bones,3cm riser ones. It gives the shock better clearance from the swing arm, its a tight fit.
                                        I cannot find the thread any more, but here are the pictures on the suspension modifications
                                        I already replaced the battery with a capacitor from '2strokeracelab' - check it out. The shock is bigger than the DT unit, longer and a fatter spring with of course,with a piggyback reservoir. So there is no room for the battery. It is also no going back as there is the tab which the battery tray is bolted to on the frame, which has to be cut off for the shock to be accepted properly. I also cut the side cover apart. Bit easier to get a flat head in for adjustment and gives me access to the Yamy Tool kit.
                                        I use 15w Fork oil and it makes the best of the standard forks. I do own a very nice set of 1991' WR200 Kayaba Forks. I chose them because the WR yoke had an Ignition mount. They are just the right forks for it. But I don't want to modify the frame to accept the WR stem. I'm looking at having the Stem pressed from the WR yoke, and getting it machined down with an extended thread which would allow me to just use the original top cap and ball bearing race on the DT. Need to model it in 3D first.
                                        I'm at University currently so I just stock pile things at the moment. But future updates; Installing a Twin radiator configuration from the DT200R(3ET) - Got all the goodies now. I've also got a 'Ignitech DCCDPI2' on the way. The 3RM' really needs ignition modification before anything else. And the fiendishly unfriendly, how do I horse anything bigger than a 30mm Carburettor? plans to Original Air box configuration at some point,
                                        It does not need to be big, I have drilled out the Air box already with good results with some Jetting and Pipecross Airfilter fitted. But I do have a Keihin PWK 36 that would be alot of fun.
                                        Picked up a very nice Yamaha TZR125RR (3MB00-P-Y2) Barrel ages ago. (The real deal Y3 Belgarda' has eluded me) Just a display piece at the moment. Interested to hear about any Porting experiences.
                                        Thanks
                                        T
                                        T
                                        Tuan Rizkhan
                                        @Darty How do you fit 36mm carb on your dt,what kind of carb boot use for it.
                                        • T Tuan Rizkhan
                                          @Rizboy We fitted a 38mm keihin carb to a 2001 DTR
                                          https://www.youtube.com/watch?v=bOGAEzTaBgI
                                          Just used a heat gun to up the carb boot and reamed out the inlet manifold to suit.
