portingignitech4dldtrwr200
135 Posts 27 Posters 144.2k Views 6 Watching
    Yeah that's looking lovely mate. It's a lovely looking machine.
    I don't think this is the end for you mate. I reckon you need throw a set of USD forks on there for completeness.
    That would just be 👌 Perfect then!
    • PeluriP
      PeluriP
      Peluri
      You should really get some better foot pegs! I think the WR200 ones fit right on.
        I am running Apico KTM ones. Nice and wide.
        PeluriP 1 Reply Last reply
          PeluriP
          PeluriP
          Peluri
          @Calum That's nice, how do the KTM pegs fit the DTR? Any modding needed or bolt-on?
            I just ground down the ends of them as they wouldn't sit flush. It's a very minor mod I didn't think twice about it.
              PeluriP
              PeluriP
              Peluri
              @Calum Ok so they fit easily? I'll think about getting myself a pair of those then!
                Yeah it was simple. I tried looking I could find exactly what I bought. I must have done it after I "finished" my bike and thus didn't document it. But yeah was a really easy mod and now I have Phat footrests.
                  PeluriP
                  PeluriP
                  Peluri
                  @Calum Really nice! My only problem is the budget, those things are like a 100€ 😬 Maybe I should get some Chinesium ones 😅
                  • PeluriP Peluri
                    @Peluri the Chinese footpegs look nice been meaning to get a set
                      PeluriP
                      PeluriP
                      Peluri
                      @declan Alright, I'll get myself a pair of those! Thanks!
                        Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                        QUICK ENOUGH LOL
                        finchfockerF
                        finchfockerF
                        finchfocker
                        @Darty what ignitec cdi did you go for?? Ive sent an email and they have recommended the DCCDIP1 race
                        • finchfockerF finchfocker
                          PeluriP
                          PeluriP
                          Peluri
                          @finchfocker I myself just bought the DCCDIP1 race. Seems like a great unit, just programmed myself a ignition map to start off with, hopefully I'll get a chance to plug her in soon!
