portingignitech4dldtrwr200
135 Posts 27 Posters 144.2k Views 6 Watching
  • T Tuan Rizkhan
    @Darty How do you fit 36mm carb on your dt,what kind of carb boot use for it.
    @Rizboy We fitted a 38mm keihin carb to a 2001 DTR
    https://www.youtube.com/watch?v=bOGAEzTaBgI
    Just used a heat gun to up the carb boot and reamed out the inlet manifold to suit.
      jonne123
      Darty do you have accelaeation video or something like that or dyno result
      DartyD 1 Reply Last reply
      • J jonne123
        @jonne123 Never got round to it, I’m looking to get it Dyno’d in the future
        • Sven HackbarthS
          Sven HackbarthS
          Sven Hackbarth
          I am also working on a custom inlet. Very cool inspiration here
            wrote on last edited by Darty
            #119
            Prototype V4, 3D printed in a TPU at 80A Shore Hardness like the original. This is chemical and UV resistant filament and it's rather tough!
            This is the final design for use with a pressure mold.
            Concessions need to be made for 3D printing rubber unfortunately, so now I'm using M5 Socket cap bolts and the original flange that's molded in the Airbox as a sealing face, it actually works out to be the most effective alternative. Much like a YZ Airbox will use the same design.
            The Airbox is so important when jetting a 2stroke road bike, we need to control the flow of air and have a place to store some also! Induction theory carries on. The area inside is free of interruption and the boot helps to increase the velocity upon entering the carb. I'm hoping to gain more torque down low by using that stock Airbox volume.
            The design now minimises any angles greater than 55deg, this means material does not have to be supported as we print. As you can see, this is the optimal version as the rest of the print can completed cleanly as a vertical slice.
            Job done,
            So much more flexibility with jetting. Measure 69 times, draw it once.
            Mikuni TM34ss finally finished.
              Actually amazing that you can 3D print parts!
              I need to get myself a 3D printer. Can just imagine the hassle I could save!
                Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
                QUICK ENOUGH LOL
                Louis-DT-WRL
                Louis-DT-WRL
                @Darty tm34ss is the perfect upgrade due the the shape and angle, keeps the float bowl level .
                I think there's a tm36ss also
                • PeluriP
                  PeluriP
                  Peluri
                  wrote on last edited by Peluri
                  #122
                  Hey darty, could you share us the files for your 3D printed intake manifold and airbox thingy?
                    #123
                    Exhaust Porn
                    This was the last one ever left, I finally bit the bullet and purchased a Stainless exhaust for the DT.
                    This came all the way from bloody Portugal like this πŸ˜‚
                    Great job lads.
                    Ballin' - This is the 'YAMAHA DT125 Special Exhaust' in STAINLESS DTX DTR-E with end can from Romeu125 an eBay seller.
                    Custom design by the gang over there and beautifully hand made.
                    Really quite impressed, only ever 4 sold on eBay.
                    Looks great, low slung - Interesting design. I've got to say, did not fit that well with the tail pipe supplied. It was so awkward in fact I decided to fit my WR200 FMF tail pipe DIY instead.
                    Looks cool, but too raspy for my taste.
                    Picked up maybe the last NOS WR200 Mikuni Idle screw ever? This stuff is all getting expensive and stupidly hard to come by these days...
                    Airbox
                    Next up, finishing up the Airbox. Drilled and bolted up with M5 bolts and importantly using Nylocs. Can't have the ingestion of M5 bolts into the crankcase.
                    Got it bang on with a perfect seal, sadly it's no going back with the install but that's the best that can be achieved SLA 3D printing.
                    WR200 SideStand - 1991-1993
                    The early versions of the WR200 came with a long enduro style kickstand. Almost impossible to find nowadays and I'm kicking myself for not getting one NOS from Fowlers back in the day, but I was a student at the time.
                    Due to the design you need to notch the DTR frame, so 'sayonara' fresh powdercoat here and sent it with the Grinder. It looks like I've cut to far there, but it's just swarf.
                    Again, NO GOING BACK.
                    The WR200 sidestand looks mint, tucks up nicely and props the bike up much further if you run an increased ride height over standard on the DTR.
                    (New longer spring needed)
                    FINAL FORM
                    I'm running DT230 Lanza Frame Guards, Left handside here is a ZETA part. Otherside is an OEM Lanza Part which only fits right handside for the DTR and require spacers and machining to fit the DTR. But worth it.
                    HOT BOI
                    Such an odd Croissant that pipe....,
                    I think that's it for the DTR, It's a beast, sounds great and is still alot of fun 7 years on. But it's had it’s day.
                    Is it better? All I'm certain is that it's mine.
                      Yeah that's looking lovely mate. It's a lovely looking machine.
                      I don't think this is the end for you mate. I reckon you need throw a set of USD forks on there for completeness.
                      That would just be πŸ‘Œ Perfect then!
                      • PeluriP
                        PeluriP
                        Peluri
                        You should really get some better foot pegs! I think the WR200 ones fit right on.
                          I am running Apico KTM ones. Nice and wide.
                          PeluriP 1 Reply Last reply
                            PeluriP
                            PeluriP
                            Peluri
                            @Calum That's nice, how do the KTM pegs fit the DTR? Any modding needed or bolt-on?
                              I just ground down the ends of them as they wouldn't sit flush. It's a very minor mod I didn't think twice about it.
                                PeluriP
                                PeluriP
                                Peluri
                                @Calum Ok so they fit easily? I'll think about getting myself a pair of those then!
                                  Yeah it was simple. I tried looking I could find exactly what I bought. I must have done it after I "finished" my bike and thus didn't document it. But yeah was a really easy mod and now I have Phat footrests.
                                    PeluriP
                                    PeluriP
                                    Peluri
                                    @Calum Really nice! My only problem is the budget, those things are like a 100€ 😬 Maybe I should get some Chinesium ones πŸ˜…
                                    • PeluriP Peluri
                                      @Peluri the Chinese footpegs look nice been meaning to get a set
                                        PeluriP
                                        PeluriP
                                        Peluri
                                        @declan Alright, I'll get myself a pair of those! Thanks!
                                          QUICK ENOUGH LOL
                                          finchfockerF
                                          finchfockerF
                                          finchfocker
                                          @Darty what ignitec cdi did you go for?? Ive sent an email and they have recommended the DCCDIP1 race
