  4. Engine tuning/ bike build
45 Posts 9 Posters 24.9k Views
    Interesting to see the clutch basket split.
    I was looking at it the other day as it happens and was wondering what it looked like 😛
    A
    A
    Arild
    @calum yeah i agree, i wanted to check if it was possible to change worn bushings and it looks like it is, however like i mentioned the real problem is putting it back together, my idea is to thread the holes and use some bolts and the best loctice there is but still id be somewhat worried of it coming loose
    Whenever my engine is being torn out for a rebuild ill probably look into rebuilding the current basket aswell since it was alot more loose than the broken one I split
      Where are you getting the bushes from?
      A 1 Reply Last reply
        A
        A
        Arild
        @calum Id either take the ones from the broken basket since they seem pretty good, but im also thinking of designing a them in solidworks so whoever that needs them can just get them 3D printed, i however know nothing about 3d printing and im curious what the best plastic filament would be to use for something like that
        • A Arild
          #27
          @arild
          Can you please post a pic of the under side of the cog piece?
          I think that the cog would have to be real sloppy loose to need new bushes...
          Also, I’d just rivet it back together like it was originally. Just use steel rod...
            @arild
            A
            A
            Arild
            @spookdog
            Yeah, ur probably correct, this basket is fine but its the one in my bike currently that is worse, and since this basket was broken anyway i wanted to have a look
            Also, it would work to rivet it back together, however, for someone to do that at home might be difficult, youd need a hydraulic press and probably a lathe to machine the rivets since theyre conical on one side
            I would just think its easier to get the holes threaded to m6 and use some bolts and alot of loctite, atleast for people without a developed workshop at home, i got no experience with loctite however so idk if theres stuff strong enough to hold the bolts in place
            Posting this from my phone so no clue if the pictures are going up like theyre supposed to
            • A Arild
              @spookdog
              #29
              @arild
              I’m guessing The clutch on your bike should feel really snatchy when engaging and disengaging the clutch, if it’s worn that bad? If it doesn’t I’d look somewhere else for the noise...
              Any engineering firm near you can make/supply and press rivers for next to nothing (I’m guessing under £20, they rebore a cylinder for about 40!) It’d be less work than threading it and finding a conical bolt to fit. Just google ‘local engineer’ and you’ll find loads of real clever people willing to work for you on any project you can imagine 🙂 they’re an underused resource IMO...
              Cheers for the pics, I’ve always wondered what it looked like inside...
              CalumC A 2 Replies Last reply
                @arild
                @spookdog Engineering firm round me took 16 months to clean my engine and still haven't welded my RS frame yet. Guys are mentall busy!!!
                I reckon you should be able to tap the threads and lock tight without a problem. Get a nice countersunk bolt in there too by the looks of it.
                  There's quite a few guides out there, on doing it on banshee engines, which are very similar to ours. They tap and bolt the two half's together. Nearly every basket I've had in my hands has had excessive play. Problem for us is getting the rubber parts unless someone can 3d print them.
                    @arild
                    A
                    A
                    Arild
                    @spookdog
                    i get u mate, problem is over here in sweden that whole industry of workshops, small garages, people reboring cylinders and all that is growing smaller by the day, i called a local guy to me to check and he took 80 pounds to rebore the cylinder, however that guy also does work for koenigsegg and theyre cylinders so that might impact his idea of a good price idk, there isnt really anywhere to call over here if u dont know the contacts already sadly, idk how it impacts the engine tbh but i would think if those bushings are loose and worn it would make a clanking noise since the cog wouldnt move aswell together with the rest of the basket if u get what i mean.
                    @DTR-NSR as i said above im planning on 3d printing a pair if i get spare time for that, i might make a batch and sell them for 5 pounds or something
                    • A Arild
                      @spookdog
                      @arild said in Engine tuning/ bike build:
                      I'd definitely be interested in a set!
                      • T
                        T
                        theportingmaster
                        £80 for a rebore is very expensive, Mick Abbey charges £25 for a
                        rebore and hone and postage abroad is only £10 as done a few
                        cylinders for overseas customers.
                        • T theportingmaster
                          A
                          A
                          Arild
                          @theportingmaster
                          Thats a really good price, what shipping company were u using??
                          • A
                            A
                            Arild
                            been a while, ive just recently started doing some work on the bike again, took a long break over the winter, you lose the will to work on the bike when its negative degrees in the garage.
                            Ive been getting some stuff going this past week, I was able to go over to my neighbours company/workshop where he had a lathe i was able to use. So I threw together an adapter that is slipfitted over the cylinder skirt, which then centers up in a simple 3-jaw chuck lathe, I did this cause I didn't have access to a four jaw, but that's ofcourse the preferred method to go. I then skimmed and bored the barrel, still have lots to go cause I think a piston had exploded in that barrel before so there's a lot of material missing over the exhaust port.
                            https://i.imgur.com/LhPCUF0.mp4
                            https://i.imgur.com/usIIdnO.mp4
                            Some vids I took at the lathe.
                            I also just last night finished up making a port map for my 3mb barrel, I later printed it, cut everything out and used it as a porting guide
                            As you can see I added some 8mm auxiliary exhaust ports.
                            I then just started porting, the only tools I had to use was a normal dremel with a flexshaft and some carbide and diamond burs aswell.
                            Ofcourse its not even close to a perfect port job, but it being my first time without and real porting tools I'm really happy with the result, its not finished yet, the ports need to be cleaned up, barrel needs a rebore which ill do in the lathe this week and the exhaust port needs to be polished cause it got some dings from the dremel. I went conservative with this first iteration, they open at 188 degrees, my main port opens at 200 degrees. Its just a test and if they need to be higher ill raise them a tiny bit.
                            I then also need to attack the power valve to get passages for the gases to flow through that aswell.
                            Some other stuff I've been working on is an airboot for my 32mm carb so I can use the stock airbox, the opening for the carb is 55mm compared to the roughly 38mm stock carb and boot. No matter how much heat or force used it didn't fit.
                            My tacho fixture on the case had also been stripped so took an hour to mock a new model up in solidworks so I could 3dprint
                            I was also able to pick some wr426f forks up for free, however the shape they're in isn't the best, the aluminium has corroded and pitted all over the fork tubes, its nothing deep tho so its only visual, so whenever I get a front axle for it and get the bearing cup made I'm chucking them on aswell
                            • A Arild
                              @arild Lovely bud!
                              Are you going to make match holes in the powervalve as well? Or are you running open port?
                                @arild Lovely bud!
                                A
                                A
                                Arild
                                @calum I havent really decided that yet, i want to be able to run the pv but I'm not sure how to do it with the auxiliaries in a good way, ideally id like the ports to stay closed and open up with the rest of the valve, idk how well that will work tho so I might just resort to having the open all the time
                                T 1 Reply Last reply
                                • A Arild
                                  T
                                  T
                                  theportingmaster
                                  @arild Added boost ports and modified powervalve to suit, can
                                  upload port maps to add boostports.
                                    @theportingmaster that looks pucker mate!
                                    Let us know how the bike rides after.
                                      T
                                      T
                                      theportingmaster
                                      @calum Will be getting it dynoed at Mick Abbeys in a couple of weeks so will upload dyno results and video of its power run once
                                      sorted. cheers Terry
                                        A
                                        A
                                        Arild
                                        @theportingmaster
                                        that's looking real good mate, certainly way better than my porting
                                        • D
                                          detsinomistaja
                                          Would Boosted port 3mb cylinder work if im having DEP exhaust and 30mm chinese PWK? Would i get noticeable power gains? I have an friend who could port the cylinder and make boost ports.
