my new yamaha dtx rebuild and my some photos of my old one.
@aidan1996 It Is not a lot of money in the grand scheme of things. My Wideband for my car costs more and thay doesn't do anything but measure the O2 readings from the exhaust.
It's the best upgrade for the money. But only really becomes noteworthy when you go down the modifying root. You now have full control of your engine. I assume you are looking to go down the modified root hence the CDI upgrade.
What Kit did you use for the trail tech? Mostly what temp sensor?
All -
You can pick the basic Trail Tech Vapor kit up for £110;http://www.moorespeedracing.co.uk/trail-tech-motorcycle-digital-speedos.html
If you want the extra Dash kit then that's an extra £40 on top . ;)
@CYBER-NINJA Im thinking about the vapour speedo as well. Found lots of different kits , is better to get the universal one or I m found one for wr450 yam. Also what about the connectors , do i have to cut them and fit each wire with terminals to connect it + Im not sure about rev meter as my dtx dont have rev counter.
