  3. DTX
  4. my new yamaha dtx rebuild and my some photos of my old one.
37 Posts 11 Posters 19.5k Views 1 Watching
  • Biker_123B Biker_123
    Looks brilliant mate! Where did you get that headlight from if you don't mind me asking? Looking for something similar for my bike but can only find it in white 😞
    aidan1996A
    aidan1996A
    aidan1996
    @Biker_123 amazon
    wouldnt fit with stock speedo tho, so would need none speedo or trail tech
    the straps aint best so put zip tie on it both side to help
    Biker_123B CalumC 2 Replies Last reply
    • aidan1996A aidan1996
      @Biker_123 amazon
      Biker_123B
      Biker_123B
      Biker_123
      @aidan1996 Thanks mate!
      Every problem has a solution
        @Biker_123 amazon
        @aidan1996 JUst make it fit. But a numberboard would look odd stuck out 10cm lol
        aidan1996A 1 Reply Last reply
        • MightymanM
          Absolutely love that headlight, fitted one to my DR-Z a few year back. It's probably the closest thing to an MX board you can get, whilst still having lights fitted.
            aidan1996A
            aidan1996A
            aidan1996
            Programmable CDI PCDI-10V on ordered added up to 250 ish with postage and fees
            i hope its worth the money. most money i spent on part hahah
              @aidan1996 It Is not a lot of money in the grand scheme of things. My Wideband for my car costs more and thay doesn't do anything but measure the O2 readings from the exhaust.
              It's the best upgrade for the money. But only really becomes noteworthy when you go down the modifying root. You now have full control of your engine. I assume you are looking to go down the modified root hence the CDI upgrade.
                aidan1996A
                aidan1996A
                aidan1996
                @Calum yes, custom pipe and the Zeeltronic and stock carb and no filter
                hoping to be a good everyday bike with good bottom and top
                (need to find a stock 28mm carb if you got any) ?
                  @aidan1996 If you want a good every day reliable bike, leave it bog standard mate. I used mine daily modified, but then I was happy to swap the rings twice a year.
                    aidan1996A
                    aidan1996A
                    aidan1996
                    @Calum how long did you Zeeltronic kit take to come mate?
                    says 2 weeks after paymeant :S bought of same people as you 🙂
                      @aidan1996 I bought mine from Skellerns Cheltenham?
                      Can't remember mate to be honest.
                      I remember mine going faulty. And it took like a week to send the old one back and for the new one to arrive.
                      Borut was very good,
                        aidan1996A
                        aidan1996A
                        aidan1996
                        @Calum how much you pay bought mine of the Zeeltronic website 🙂
                          @aidan1996 I paid around the 180 mark mate.
                            aidan1996A
                            aidan1996A
                            aidan1996
                            @Calum bought mine of zeeltronic.com and that usa you think ill get import fees ?
                              @aidan1996 I've never used PartsZilla myself but have Ordered stuff from Japan no problems. So long as you specify it's a gift which is the usual stuff.
                                A Former User
                                What Kit did you use for the trail tech? Mostly what temp sensor?
                                • AndyYamA
                                  AndyYamA
                                  AndyYam
                                  You will get hit for import on parts from partzilla i expect. I did on both my orders for DT200WR parts.
                                  • NINJAN
                                    #33
                                    All -
                                    You can pick the basic Trail Tech Vapor kit up for £110;
                                    http://www.moorespeedracing.co.uk/trail-tech-motorcycle-digital-speedos.html
                                    If you want the extra Dash kit then that's an extra £40 on top . 😉
                                    ZrakoZ 1 Reply Last reply
                                      All -
                                      ZrakoZ
                                      ZrakoZ
                                      Zrako
                                      @CYBER-NINJA Im thinking about the vapour speedo as well. Found lots of different kits , is better to get the universal one or I m found one for wr450 yam. Also what about the connectors , do i have to cut them and fit each wire with terminals to connect it + Im not sure about rev meter as my dtx dont have rev counter.
                                      1979 Jawa Mustang 50
                                      2003 Gilera DNA 125 R.I.P
                                      2015 Keeway TX 125 SM
                                      2006 Yamaha DT 125 X
                                      • ZrakoZ Zrako
                                        @Zrako That's why I did.
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/635961310348804338_zpssocsff1c.jpg
                                          pg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160421_002_zpslci4rgfs.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160419_023_zpsqkplzxyu.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160419_007_zpsdlaai2ee.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160418_022_zpsukd23ldk.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160418_020_zpsinhtz9xl.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160418_016_zpsxowe9afk.jpg
                                          also took another set of dtr forks apart and added another half tube ontop of the stock dtx tube to make the rebound better and make stiffer made a massive difference
                                          cut it in half. struggled to get the cap on 😉 but was worth it
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160714_003_zpsn29fpkp7.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160418_015_zps9m0svtbh.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160418_005_zpsra9nrxtd.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160414_010_zps54ucipkp.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/2016-30-6--14-34-40_zpsfboqizzs.jpeg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160625_001_zpsmaq6glxa.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160625_002_zps4wn4gean.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160617_006_zpsyhrvu17d.jpg
                                          also used plasi dip but didnt last 2 seconds in blue
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160610_007_zpszj5wl4ek.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160610_003_zps4hzr7wid.jpg
                                          also bought mild steel upper exhaust fitted to dep stubby rear
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160601_003_zpsd5taf1oa.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160519_004_zpsmravmprd.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160512_003_zpsktom6ypp.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160519_002_zpsbuy8sfv4.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20150616_033_zpsxvos6lg1.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160519_003_zpsu7mfhfzf.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/jeoije 3_zpsstostxh0.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/jeoije 2_zps7qx2tcqc.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/jeoije 1_zpsqlhpg2bn.jpg
                                          http://i44.photobucket.com/albums/f5/Yamaharacing96/WP_20160617_005_zpsxfpj1bum.jpg
                                          just looking for a new carb as my stock 28mm one has the air screw rounded off
                                          found a tmx 30mm for 150 pound same as stock but size up so cable all fits
                                          add https://www.facebook.com/profile.php?id=100010743997330
                                          @aidan1996 Where did you get that sweet looking front pipe from bud???
