Rear shock spring removal!
Suspension
11
Posts
3
Posters
2.1k
Views
@perky Yes
You just need a spring compressor tool and then you can remove the shim plate that fastens it to the shock. Simple job to do.
@calum Hi mate I bought these clamps but couldn't get the split collor off the shock to take spring off?
There may be a big steel washer on the centre rod. It looks like it’s fixed but can be forced down. You might need to do it to remove the collar. Sometimes it appears the split in the collar is to narrow
