  4. Power valve
Power valve
7 Posts 3 Posters 1.5k Views
  • A Offline
    A Offline
    andyjack
    Im having trouble fitting a power valve. Im confused because on the engine it says num 1- num 2 cables then on the unit it says 2-1 so from what I've looked at in other units(youtube) cable 1 goes to numb 2 and cable 2 goes to numb 1 on the power unit but i am having real trouble getting the cables on and when i do i canโ€™t seem to line the power valve ( engine side) up to the hole to set it. Or am i putting cables on totally wrong ?. Can anyone help ?
    • A andyjack
      markus.wM Offline
      markus.wM Offline
      @andyjack yes that's correct, 1 goes to 2 and 2 to 1. They don't cross. Obviously use the adjusters to slacken the cable first.
      A 1 Reply Last reply
      • A andyjack
        @andyjack
        Ditto:
        1 to 2
        2 to 1
        No idea why but it fucked me up in the beginning ๐Ÿ˜œ
          @andyjack
          Ditto:
          1 to 2
          2 to 1
          markus.wM Offline
          markus.wM Offline
          @SpookDog i agree. Can't think of any reason Yamaha would do that with the numbers on the cables other than to confuse us. I imagine it's caught a lot of people out.
            A Offline
            A Offline
            andyjack
            @markus-w thanks for the help
            • A andyjack
              markus.wM Offline
              markus.wM Offline
              @andyjack no problem buddy. Did you manage to sort it?
                A Offline
                A Offline
                andyjack
                Yes thanks
