  3. Wheels
  4. 19” YZ wheel & Sprocket
20 Posts 5 Posters 5.2k Views
    Noooo! I want to recreate the same ratio that was originally on the bike whilst still having the 19” rear as I know longer have an 18” to use anymore 🙂 Does that make a bit more sense?
    @Stevie-Wonder the way I see it you want to recreate the same gearing you had with your 18" wheel on a 19" wheel is that correct? If so doing the maths you'll need to know the circumference of both tyres and work out the difference as a percentage, for example if the 19" you have now is 5% bigger circumference than the 18" then to compensate you'll need to upsize the amount of teeth on the rear sprocket or downsize the front by 5% or as close as sprocket size options allow.
    • Stevie WonderS
      Stevie WonderS
      Stevie Wonder
      @Calum it might be worth building an 18” rear to use then, fucking about with sprockets is a pain in the ass.
      Also my original tire size I was used to having when I was running my 18” rear was 120/100-18 or 140/80-18, I can’t remember exactly. All I remember was thinking bigger was better at the time of ordering them.
      If I was to get an 18” wheel again I’d run 100/100-18 or alternatively 120/80-18 if I couldn’t find the previous size
        @Stevie-Wonder I seriously doubt that you will notice that much of a drop in performance/top end with 1 inch wheel size and a different rear sprocket. So long as it's close enough you'll be fine.
          Stevie WonderS
          Stevie WonderS
          Stevie Wonder
          @Calum sprockets are still the same, also you’d honestly be surprised the difference it’s not a huge one but it’s enough to completely change the way I have the ride the bike.
          The gears as of a lot longer and are like a supersport 125, to get to the top end of your power band you really have to hold her WOT for quite a long time, because of this and the length of 4th and 5th you now can’t change into powerband to keep pulling in 6th.
          Off road has a couple of advantages and makes the bike a little nicer to cruise on but overall it’s really not doing me or the bike favours
          CalumC S 2 Replies Last reply
            @Stevie-Wonder You do realise the wheels I'm running on my DTR right???
              @Stevie-Wonder
              Seriously bud?! Building another wheel is less hassle than changing a front sprocket? I think you’re over thinking something here. Seriously, drop a tooth at a time till you’re happy...
              • Stevie WonderS
                Stevie WonderS
                Stevie Wonder
                You got sumo’s + 4DL trans aint you?
                Dropping a tooth at the front makes the gears too short sadly, you'd need to adjust from the back which would require renthal making me a sprocket or somehow finding one.
                Don’t get me wrong I’ve took the bike out a bit recently and changed the way I’ve been riding it and it’s been a lot of fun, it just requires more carefully timed shifting and clutch. Through 1st to 4th
                Best way I could explain it is before on the original setup, it’s like you’d hit band in first then straight away shift into second then zip through the gears
                As where now you get to power band and rather then zipping through you’re sat there letting it Rev and Rev waiting for it to reach to the end of the power curve so you can change up, it’s very reminiscent of a 4/ 125
                Theoretically having that wheel should up the top speed but practically it’s made it slower
                  @Stevie-Wonder I wouldn't exactly call them Sumo and no I'm on stock DTRE transmission.
                  Aprilia RS 125 wheels and DTRE transmission. So it's a considerable change from the stock wheel setup and I think the gearing is fine. Tops out at about 70mph though 🤣 but I'm not 17 anymore and weigh considerably more.
                  Rides lovely though and for zipping to and from town it's a perfect little bike.
                  • Stevie WonderS
                    Stevie WonderS
                    Stevie Wonder
                    Update the sidewall height of both tires I run on both wheels where the same, I’m not sure what an extra inch added equates to in terms of sprocket teeth but it explains a bit
                    Also no @SpookDog of course not, although I do need to buy a socket the right size that’ll fit the nut on the sprocket so I can experiment with a couple sprockets. Ya never know I might not be able to replicate the ratio but I could possibly get a nice medium between them both.
                    I think realistically though the stock gearing is the best without compromise for using the bike about town and off-road, which along with the occasional long road trip or weekend camping trip is what I need it for.
                    Also @Calum she sound good, may only do 70 but I bet she gets there pretty flipping quick
                    B 1 Reply Last reply
                      B
                      B
                      biohazard13
                      @Stevie-Wonder
                      The difference between a 3.50 standard tyre and a 4.00 is a half inch. I corrected that gearing on my bike by dropping 1 tooth from 17 to 16. If you have a 17 front cog try searching ebay for a 15 tooth Jt front dtr125 sprocket. They are about 6 quid...
                      Whether you drop the front or raise the rear, its still the same. You are lowering the gearing. You want it 'shorter'...
                      SpookDog...
                      • Stevie WonderS
                        Stevie WonderS
                        Stevie Wonder
                        As it happens I think I actually have a 15” sprocket in my garage, anyone know what size the sprocket bolt is?
