Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR)
@HOTSHOT-III wow that’s a lot haha, I feel like I need to sit and read the Haynes manual back to back for w good few nights
Thanks by the way, also I had planned of going with koyo, I’ve only ever heard good things about them
@Stevie-Wonder It really isn't that complicated. Ultimately, you'll be pulling the bike apart long before those bearings give way anyway.
The thing is, if you're going down the 3XP route on the stock DTR bottom end, you'll going to be adding a lot of undue stress to the bottom end that it wasn't designed for, so it'll need regular maintenance/rebuild anyhow.
I'd definitely recommend the Haynes idea. Watching that video is good too. And keep the haynes handy.
Get lots of food bags (or zip lock bags) handy along with cable ties to keep nuts washers etc together and in the order they came out. A nice box to put all the engine bits in. It's well worth getting the cases cleaned properly before removing the bearings. This removes the risk of scoring any journals if there is any debris left there before removing the bearings. I've never had a problem using the oven technique and it's my preferred method.
That's a really good book for understanding engine rebuilds etc, there is a PDF floating about, but I had the book.
Ultimately, nothing should be tight and everything should turn freely by hand. If at any point it isn't, then taka sit back and examine the situation as chances are you've missed something.
@Stevie-Wonder No worries, also I've just remembered a 30mm open end spanner fits on the end of the Yambits clutch holding tool perfectly, giving more leverage so I didn't need the ugga dugga gun to undo the clutch nut.
And try and undo as many fasteners as possible with the engine still in the frame to avoid chasing it round the bench. Using an impact driver, reducers down to 1/4" drive, extension bars and an 8mm socket with my improvised JIS bit I think I was even able to crack off all the crankcase screws with the engine still in the frame
@Calum probably sounds complicated because there’s a lot I don’t know and words and things that I don’t know what they belong too and a lot to remember
What extra stress do you mean as I thought the 125 and 200 shared crank bearings so I figured in that sense you shouldn’t have to worry so much
Either way I’m prepared for the extra upkeep, the way I see it is the it’ll get me very comfortable with the engine and once I’ve done one time every other time should just easier
I’m actually a big fan of the zip lock/sandwich bag method, i also Chuck some two stroke oil or acf50 in the bags with the bolts sometimes it helps revive/preserve them
What I was planning on doing was getting a few bits of carb board and tracing the cases and numbering the bolt holes then poking the bolts in the appropriate places, keeps them safe and knowing where they went is self explanatory.
@HOTSHOT-III cheers for that, I don’t have any access to any mains power or power tools so any more primitive methods are preferred
I’ve also been watching this video a lot
https://youtu.be/7hHF5FC5ko4
Not a fan that they didn’t use decent gaskets but the video is good quality and it’s made me want an engine cradle -
Removing the bearing from the crank is the worst part. It’s so easy to ruin the crank by trying to lever of the bearing. It is how I removed mine tho, just have to be careful not to dent the crank edges with the levers. I used wood to protect the crank edges...
If the crank bearings are good, and the big end bearing, you don’t need to build the bottom end. If it’s not broke, ect...
I would definitely do your main seals though. You have had similar symptoms to my ‘weak mixture at low throttle ‘ problems that were causing my head gasket to blow...
Okay thank you guys, I’ll be pulling the top end off and checking the bottom end.
For the price of a set of rings, an OEM gasket and having the head and cylinder skimmed itd be stupid not too.
I do have a really good pick set in my repertoire which has made life beyond easy for grabbing out seals in wheel bearings etc so I’m pretty sure I should be able get them out, I’ve got a pretty good feel for those things.
However I would’ve been pretty hap-hazzard about the crank mating surfaces, which of course being ally would be easy to score or burr -
The seals came out real easy in my case bud. Just replace them with good reputable ones if you can’t afford genuine parts. I made the mistake of buying fleabay China the first time round ☹️
What do you mean about the ‘crank mating surfaces’ though? You mean crank cases? If so, that little hole/slot in the front bottom of the bottom end makes a good leverage starting spot. Be gentle and put in plenty of rubber mallet tapping all around and it will separate without having to use brute force. Shit man! If I can do it!! 🤪
@SpookDog sorry I meant the outer surface which the seal presses against
And consider myself told! I think I haven’t spent much time with the engine apart either so I’m a little blurry and unfamiliar except from what I’ve read so it’ll be a good exercise to pull her apart.
Give me a couple weeks to get paid and I’ll be ordering the bit needed.
So far I need, gasket, new head studs + screws + copper washers, @HOTSHOT-III crankcase splitter tool thing, clutch holding tool (i think I have one already), cordless impact wrench, JIS screwdrivers (I already have a pack of 5 which are very good and I’m if I remember right I’ve got JIS ratchet attachments too), 1/4” torque wrench / a nice handheld torque wrench (i actually already have one except it’s for cars and is huge not very ideal for doing cylinder studs etc), lots of sandwich bags + sharpie and zip ties, sheet of cardboard for making a template to stick bolts that require being placed in a specific order into.
Anything I missed?
@Stevie-Wonder do you need new head studs? What's the matter with the existing ones?
You're definitely dotting the i's and crossing the t's.
If you are just doing the top end then you won't need much in the way of sandwich bags and zip ties. It only takes an hour, including time to take the tank off so there won't be any time to misplace stuff.
I didn't use an impact gun, instead stick a screwdriver inbetween the primary and secondary gearbox output cogs. That'll lock the crankshaft to get the clutch basket off. If you do it in situe then the engine mounts will hold the engine steady. Again no more than an hours job to replace the crankshaft seals.
@Stevie-Wonder
You lever on the seals centre, not it’s outer edge 🙂You will need a tool to hold the clutch centre while you undo/do up the clutch centre nut. Sticking a screwdriver in will allow you to undo the crank nut though 😜
Cheers for your help boys, I’m convinced it’s a piece of cake now and I honestly look forward to taking everything apart to see if we can get her running again.
I see why you love two strokes so much, very little to go wrong and very easy/cheap to replace.
With the head studs I thought may as well as everything else would be new, plus don’t you need to replace the washers anyway?
Also yeah thinking about it as long as I’m organised and methodical I should be good, most of the bolts that come off can be left or put back in the put it in to avoid them getting lost anyway
@SpookDog Ohhh like use a hook pic or a spikey to stab into the middle to pull/lever it out. If that’s the case I always thought it’d be much harder then that 😂
Also can anyone reccomend a tool for that job.
I think it’ll be a couple weeks before I can order the bits too
Like I said, small flat head screwdriver 🙂
Only replace the head studs if you have to, then only with genuine ones. Never buy fleabay ones! They may as well be made of glass 🥴
Breaking a stud of in the barrel is a pain in the ass. My local reputable bike shop put in the helicoil pissed, like the tower of piza 😐 ... -
Engines out, ready to be stripped.
I’m going to leave the engine standard and focus on performance upgrades last.
In the mean time I’m just going to take things slowly and get her ready for next year.Whilst stripping the engine I noticed the swing arm bushings etc looking like they could use replacing.
Rather then rebuild the stock swingarm I’ll buy a bearing kit for the DT200wr swinger I’ve got, get it painted and finally chuck it on the bike. Im really really excited about seeing this on the bike and feeling the weight difference between the two swingarms.
Another thing is 19” rear wheel jacks the ass up a lot, the bigger wheel doesn’t look right and tire options are limited. Plus with USD’s on the front and knobbly tires it makes the DT a very tall bike. Even for someone 6ft.
For those reasons that’ll be going shortly.I have to wire in a trail tech vapor speedo too, I have been without working clocks for sometime now. Not good.
Im shit with electrics so I’ll probably pay someone to do that and save all the agg.
I wish they where just the standard DT clocks but that’s just not on option anymore with the front end I’ve got now.This is everything I reckon I’ve got to do
Everything the DT needs to make 100%
Front brake hose holder clip €22.50
5DH2587500Brake pad retaining pin £
5DH2593300Front wheel inner Axle threads needs heli-coil/tap and dye as does brake hose guard cover bolt
Cover, Hose €23 (UFO/Polisport disc cover will also do the same job and give 90’s aesthetics)
5DH2314E00Oem Fork guard bolts (Anodised ones are usually ally and the threads give way after a couple twists, it’s amazing it’s took until now for most of them to go missing/work their way free)
Rear panels + graphics (bikerpartshop + hazard)
Helmet lock 5H0-21308-01
Possibly oil + coolant for once engine’s drained
Seat cover - either custom or bikerpartshop dark blue replica
- Battery strap
22F-82131-00
https://sumorubber.com/straps ( a very handle little sight that specialises in battery straps for vintage bikes, the steel on my battery strap that clips to the frame had completely deteriorated)
DT125R headlight frame / bracket holder. (I love the 3et light for its slimmer profile but the smaller size with the bigger forks means there’s not a lot of space to put your dash, the original would be more practical, look better and fit better.)
Working fucking clocks!!!
Speedo cable wire for Vapor
Magnet pick up sensorDT200WR swinger needs difference in pivot mounts measuring + chain alignment checking
18x2.15 excel rim
@Stevie-Wonder With the engine removed from the frame, now would be an opportune moment to test the fitting of your DT200WR swingarm. Sounds counter-intuitive I know, but assuming the swingarm pivot bosses are the same width/distance apart as the stock steel arm (meaning it will fit into the chassis), it's the engine boss which dictates it's (and in turn the rear sprocket/wheel) position in the bike. Sprocket alignment is the biggest enemy here; you won't notice front/rear wheel alignment being a few mm out as once you factor in tyres, rims etc. (MOT allows 4mm lateral rim runout) most bikes on the road aren't perfect anyway.
Here's an explanation how to do the swingarm side clearance with pics from the Yamaha manual. Don't forget you'll need to do this again after splitting and reassembling the crankcases as this process might alter the engine boss width:
https://dt125r.co.uk/post/29135
It's actually possible to do this without going near the chassis if you have the engine out; I went through the process using a 3ET swingarm and a spare set of crankcases to do a workbench mock-up to assess sprocket alignment. 3ET swingarm, spindle, drive side spacer and rear caliper mount (it's thinner due to the fatter ends of the alloy arm) and stock DT125R hub produced almost perfect sprocket alignment according to my 600mm straight edge. I might need to play around with this slightly to get it perfect; there was a 3mm thick M20 washer between the caliper mount and arm when this pic was taken and the sprockets look about 1mm out.
Good shout going back to an 18" rim. If you can, go back to your stock 18" DTR rear wheel as well because stock rear wheel with good sprocket alignment = wheel alignment (or at least it places your stock rear wheel where it should be) which will keep things simple for now. Also 19" rear wheels on MX bikes were largely an attempt to reduce the rear wheel's weight which reduces unsprung weight/inertia to improve acceleration and suspension responsiveness on the track; most Enduro bikes run 18" because the flabbier tyre sidewall is more forgiving and offers better puncture resistance against rocks, roots, Ferguson tractor parts in the corner of farmers' fields etc.
https://www.thumpertalk.com/forums/topic/213621-18-vs-19-wheels/
I can't comment on the DT200WR arm as the chassis is different from the DT125R as well meaning you might need the entire rear suspension assembly to make it work (the DT200WR shared a much beefier relay arm and linkage with the WR200 IIRC). And compared to the 125 steel arm I'd be looking at overall length as well as the distance between the pivot and where the linkage attaches to try and get an idea whether the leverage ratio will change noticeably.
@HOTSHOT-III said in Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR):
Thank you for that @HOTSHOT-III thats really helpful. The swinger still needs painting, which I’ll get round to eventually none the less I’ll be doing what you said.
My 19” rear is just a YZ rim laces to DTR hub so in theory the alignment should be the same. -
I’ve since split the cases, I don’t have photos but the top end was pristine. The head had no plinking/det marks, crosshatching on the bore still, perfect even burn pattern along the piston crown and a beautiful bronze/brown colour. No play in the crank either.
My suspicions were right and both seals had in fact given up. A quick call to PJME for a round of oem seals, power valve rebuild kit, Yamaha seals and some koyo crank bearings for good measure and we’re sorted.
I also did some tinkering today and found out what’s wrong with my clocks as I was having issues with using the stock ones with my USD forks.
-The Speedo side of the clocks fine, however when I hooked up I didn’t get reading so the speedo drive is possibly faulty. Plus to make matters worse speedo drive is to opposite side of the clocks meaning you can’t route the cable properly.-I found out the rev side of my clocks has seized somehow which is why my bike snapped two cables.
(If anyone has any experience with taking the clocks apart that’d be great, are they complicated/fiddly?) -
Standard clocks? You have to separate the base with a Stanley knife. Then stick it back together with mastic/sealant…
I’d try wd40 and try to get it moving with a screwdriver or such. The bit that spins has a magnet inside the unit that sits inside a kinda steel ‘bell’ that connects to the needle. The spinning magnet moves the ‘bell’ which has a very delicate return spring…
It’s fiddly but doable. If the gauge is fubar you’ve got nothing to loose… -
Cheers man I’ll give that a try
Engines back together now, took an afternoon to do between me and Stacey of VJMC Suffolk division, the crank bearings and seals come out no trouble and it was fun educational experience. They’re surprisingly simple and light.
Still learning about the gearbox aspect. That’s gonna take a couple more goes before I get.I polished the piston crown, rebuilt the powervalve and through a set of koyo main bearings and used OEM everything else.
Unfortunately I forgot to order a Reed gasket so we’ve had to put it on hold until that comes back, then we can see if she runs.
@Stevie-Wonder
More hands on you get, the more confidence you gain. Good to hear you’re still around 🙂
You been riding that FZR, wasn’t it? Revvy 4/ fun!….
