211 Posts 11 Posters 119.1k Views 3 Watching
  • Stevie WonderS
    Stevie WonderS
    Stevie Wonder
    Cheers for your help boys, I’m convinced it’s a piece of cake now and I honestly look forward to taking everything apart to see if we can get her running again.
    I see why you love two strokes so much, very little to go wrong and very easy/cheap to replace.
    With the head studs I thought may as well as everything else would be new, plus don’t you need to replace the washers anyway?
    Also yeah thinking about it as long as I’m organised and methodical I should be good, most of the bolts that come off can be left or put back in the put it in to avoid them getting lost anyway
    @SpookDog Ohhh like use a hook pic or a spikey to stab into the middle to pull/lever it out. If that’s the case I always thought it’d be much harder then that 😂
    Also can anyone reccomend a tool for that job.
    I think it’ll be a couple weeks before I can order the bits too
      @Stevie-Wonder
      Like I said, small flat head screwdriver 🙂
      Only replace the head studs if you have to, then only with genuine ones. Never buy fleabay ones! They may as well be made of glass 🥴
      Breaking a stud of in the barrel is a pain in the ass. My local reputable bike shop put in the helicoil pissed, like the tower of piza 😐 ...
      • Stevie WonderS
        Stevie WonderS
        Stevie Wonder
        Engines out, ready to be stripped.
        I’m going to leave the engine standard and focus on performance upgrades last.
        In the mean time I’m just going to take things slowly and get her ready for next year.
        Whilst stripping the engine I noticed the swing arm bushings etc looking like they could use replacing.
        Rather then rebuild the stock swingarm I’ll buy a bearing kit for the DT200wr swinger I’ve got, get it painted and finally chuck it on the bike. Im really really excited about seeing this on the bike and feeling the weight difference between the two swingarms.
        Another thing is 19” rear wheel jacks the ass up a lot, the bigger wheel doesn’t look right and tire options are limited. Plus with USD’s on the front and knobbly tires it makes the DT a very tall bike. Even for someone 6ft.
        For those reasons that’ll be going shortly.
        I have to wire in a trail tech vapor speedo too, I have been without working clocks for sometime now. Not good.
        Im shit with electrics so I’ll probably pay someone to do that and save all the agg.
        I wish they where just the standard DT clocks but that’s just not on option anymore with the front end I’ve got now.
        This is everything I reckon I’ve got to do
        Everything the DT needs to make 100%
        Front brake hose holder clip €22.50
        5DH2587500
        Brake pad retaining pin £
        5DH2593300
        Front wheel inner Axle threads needs heli-coil/tap and dye as does brake hose guard cover bolt
        Cover, Hose €23 (UFO/Polisport disc cover will also do the same job and give 90’s aesthetics)
        5DH2314E00
        Oem Fork guard bolts (Anodised ones are usually ally and the threads give way after a couple twists, it’s amazing it’s took until now for most of them to go missing/work their way free)
        Rear panels + graphics (bikerpartshop + hazard)
        Helmet lock 5H0-21308-01
        Possibly oil + coolant for once engine’s drained
        Seat cover - either custom or bikerpartshop dark blue replica
        • Battery strap
          22F-82131-00
        https://sumorubber.com/straps ( a very handle little sight that specialises in battery straps for vintage bikes, the steel on my battery strap that clips to the frame had completely deteriorated)
        DT125R headlight frame / bracket holder. (I love the 3et light for its slimmer profile but the smaller size with the bigger forks means there’s not a lot of space to put your dash, the original would be more practical, look better and fit better.)
        Working fucking clocks!!!
        Speedo cable wire for Vapor
        Magnet pick up sensor
        DT200WR swinger needs difference in pivot mounts measuring + chain alignment checking
        18x2.15 excel rim
          5DH2587500
          5DH2593300
          5DH2314E00
          • Battery strap
            22F-82131-00
          18x2.15 excel rim
          @Stevie-Wonder With the engine removed from the frame, now would be an opportune moment to test the fitting of your DT200WR swingarm. Sounds counter-intuitive I know, but assuming the swingarm pivot bosses are the same width/distance apart as the stock steel arm (meaning it will fit into the chassis), it's the engine boss which dictates it's (and in turn the rear sprocket/wheel) position in the bike. Sprocket alignment is the biggest enemy here; you won't notice front/rear wheel alignment being a few mm out as once you factor in tyres, rims etc. (MOT allows 4mm lateral rim runout) most bikes on the road aren't perfect anyway.
          Here's an explanation how to do the swingarm side clearance with pics from the Yamaha manual. Don't forget you'll need to do this again after splitting and reassembling the crankcases as this process might alter the engine boss width:
          https://dt125r.co.uk/post/29135
          It's actually possible to do this without going near the chassis if you have the engine out; I went through the process using a 3ET swingarm and a spare set of crankcases to do a workbench mock-up to assess sprocket alignment. 3ET swingarm, spindle, drive side spacer and rear caliper mount (it's thinner due to the fatter ends of the alloy arm) and stock DT125R hub produced almost perfect sprocket alignment according to my 600mm straight edge. I might need to play around with this slightly to get it perfect; there was a 3mm thick M20 washer between the caliper mount and arm when this pic was taken and the sprockets look about 1mm out.
          Good shout going back to an 18" rim. If you can, go back to your stock 18" DTR rear wheel as well because stock rear wheel with good sprocket alignment = wheel alignment (or at least it places your stock rear wheel where it should be) which will keep things simple for now. Also 19" rear wheels on MX bikes were largely an attempt to reduce the rear wheel's weight which reduces unsprung weight/inertia to improve acceleration and suspension responsiveness on the track; most Enduro bikes run 18" because the flabbier tyre sidewall is more forgiving and offers better puncture resistance against rocks, roots, Ferguson tractor parts in the corner of farmers' fields etc.
          https://www.thumpertalk.com/forums/topic/213621-18-vs-19-wheels/
          I can't comment on the DT200WR arm as the chassis is different from the DT125R as well meaning you might need the entire rear suspension assembly to make it work (the DT200WR shared a much beefier relay arm and linkage with the WR200 IIRC). And compared to the 125 steel arm I'd be looking at overall length as well as the distance between the pivot and where the linkage attaches to try and get an idea whether the leverage ratio will change noticeably.
            Stevie WonderS
            Stevie WonderS
            Stevie Wonder
            @HOTSHOT-III said in Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR):
            Thank you for that @HOTSHOT-III thats really helpful. The swinger still needs painting, which I’ll get round to eventually none the less I’ll be doing what you said.
            My 19” rear is just a YZ rim laces to DTR hub so in theory the alignment should be the same.
            • Stevie WonderS
              Stevie WonderS
              Stevie Wonder
              I’ve since split the cases, I don’t have photos but the top end was pristine. The head had no plinking/det marks, crosshatching on the bore still, perfect even burn pattern along the piston crown and a beautiful bronze/brown colour. No play in the crank either.
              My suspicions were right and both seals had in fact given up. A quick call to PJME for a round of oem seals, power valve rebuild kit, Yamaha seals and some koyo crank bearings for good measure and we’re sorted.
              I also did some tinkering today and found out what’s wrong with my clocks as I was having issues with using the stock ones with my USD forks.
              -The Speedo side of the clocks fine, however when I hooked up I didn’t get reading so the speedo drive is possibly faulty. Plus to make matters worse speedo drive is to opposite side of the clocks meaning you can’t route the cable properly.
              -I found out the rev side of my clocks has seized somehow which is why my bike snapped two cables.
              (If anyone has any experience with taking the clocks apart that’d be great, are they complicated/fiddly?)
                #145
                @Stevie-Wonder
                Standard clocks? You have to separate the base with a Stanley knife. Then stick it back together with mastic/sealant…
                I’d try wd40 and try to get it moving with a screwdriver or such. The bit that spins has a magnet inside the unit that sits inside a kinda steel ‘bell’ that connects to the needle. The spinning magnet moves the ‘bell’ which has a very delicate return spring…
                It’s fiddly but doable. If the gauge is fubar you’ve got nothing to loose…
                  @Stevie-Wonder
                  #146
                  PS the input where the square end of the cable fits into should turn/spin freely in either direction. Don’t worry about damaging the internals by forcing it a tad! There’s no physical connection inside 🙂 …
                  • Stevie WonderS
                    Stevie WonderS
                    Stevie Wonder
                    Cheers man I’ll give that a try
                    Engines back together now, took an afternoon to do between me and Stacey of VJMC Suffolk division, the crank bearings and seals come out no trouble and it was fun educational experience. They’re surprisingly simple and light.
                    Still learning about the gearbox aspect. That’s gonna take a couple more goes before I get.
                    I polished the piston crown, rebuilt the powervalve and through a set of koyo main bearings and used OEM everything else.
                    Unfortunately I forgot to order a Reed gasket so we’ve had to put it on hold until that comes back, then we can see if she runs.
                      @Stevie-Wonder
                      More hands on you get, the more confidence you gain. Good to hear you’re still around 🙂
                      You been riding that FZR, wasn’t it? Revvy 4/ fun!….
                      • Stevie WonderS
                        Stevie WonderS
                        Stevie Wonder
                        Yes my FZS600, a great bike with plenty of power. Very Rev happy, very reliable too. I’d definitely own one again. Unfortunately I had to sell it. My only complaint isn’t really so much a complaint but more personal preference and that’s that it felt like riding a two stroke, the power was very linear yet flat at low revs but increased more and more with the revs. It makes for a lot of fun but personally if I wanted that feeling I’d just experience the real deal by riding a two stroke. If I’m riding four stroke I like bottom end and not having to constantly be on revving the tits of it. It gets annoying after a while, that is unless it’s a two stroke.
                        Update with the bike, I’ve sourced some parts for the DTR thanks to a certain someone (forget their @). I’m getting rid of the 200r headlight, making a second rear plate holder and at some point I might buy some replica OEM indicators. The 19” rear will eventually go but I’m not replacing it with anything other than an excel 18” so that’ll take time and $$$. From the parts I sourced was a headlight frame to put the original back on, quite looking forward to putting the original back on to be honest!
                        I do need to somehow sort out a mount for it. I also replaced the rear mud flap as my one got eaten by a whopping great big knobbly that I put on my bike when I first got it. 140/80-18’s aren’t for your bike is what I’d tell myself if I could 😂.
                        So far so good with everything really, since being rebuilt I’ve only rid her around a couple times, she’s yet to go on any proper outings though.
                        On my list of jobs to do was to change the pads as the right side of my EBC pad had literally just fallen off. What was meant to be a quick job turned into a bit of a nightmare though as the calliper wouldn’t come away from the hanger. Many hits and a lot of heat made absolutely no difference at all. When it finally did budge it was just the thread of the pin coming loose
                        I’ve since disconnected the calliper from the hose and left it to soak in methylated spirit as the Aussie’s on fb said that remedied their issue with the calliper fusing/seizing to the pin to their 200r’s.
                        I’ve been told it’s a common problem, if any one has any advice for this then let me know.
                        Id noticed the seals of the piston protruding out too, so whilst I am tempted to push the piston in give it all a thorough clean and then Chuck it back together so it’s sorted, I know it’s only going to be a temporary fix and it’ll need to be done one day.
                        Plus knowing that my callipers seized to the hangar bucks the shit out of me because everything else on my bike has been perfect,
                          Uuuhhmmm, two strokes aren't linear power. I think you've misphrased that.
                          A lot of road going four strokes I've ridden are gutless and you have to wring their necks to actually make them fast. I don't see that as being akin to a two stroke.
                          ZX6R
                          Where as an RD350LC, or two stroke will have a much more erratic explosive powerband.
                          Bear in mind on the RD, you're talking about something which makes DTR power just above idle. So they are very rideable, but the real fun/power is up at those higher RPMs.
                          You really need to be up there (750cc+) on four strokes for them to actually be fast IMO.
                            ZX6R
                            Stevie WonderS
                            Stevie WonderS
                            Stevie Wonder
                            That’s exactly what I mean, I’m not talking about the literal powerband but the way the bike feels and is ridden. That revvy in-line four akin to the DT is begging to have its necks wrung because you literally double the amount of power high up in the revs and like said that’s how you make them fast
                            CalumC S 2 Replies Last reply
                              @Stevie-Wonder Yeah, I see what you're saying. With a bigger 4 stroke it's not like that so much. I haven't yet ridden a super bike however.
                                #153
                                @Stevie-Wonder
                                I had an old Suzuki gn/dr 400 single cylinder mongrel that I put a sidecar on so I could ride it on L plates. It was like riding a tractor it was so torque’y. Uphill or down, pull away whatever gear, it just loved to pull 🙂
                                Gotta love torque!
                                I lost a lot of brake power to having a worn slide pin. The calliper just kinda tilted sideways for a big part on the levers throw. I was going to drill out the calliper (the hole was oval-ed) and put an oversized pin in, but couldn’t find one.
                                Failing that put a brass sleeve in it and a standard size new one, but couldn’t find one! Got a titanium one that turned out to be too small diameter. Gave up and just stripped it and replaced the rubbers and seals. Grease the pin! 🙂
                                Apart from major heat I’d soak it in vinegar or washing soda, or even caustic soda to try and release it. Also, if it’s that corroded I’d replace the piston with a stainless or titanium one…
                                Good luck bud, nice to know you’re still about…
                                  Stevie WonderS
                                  Stevie WonderS
                                  Stevie Wonder
                                  @Calum when I rode a CBR900rr fire blade it still produces that same style of power but was no where near as revvy as the fazer.
                                  The fazer wanted to be ridden past 8k everywhere, by all means you could ride it under but it just didn’t feel like you was using it properly
                                    @Stevie-Wonder
                                    Gotta love torque!
                                    Stevie WonderS
                                    Stevie WonderS
                                    Stevie Wonder
                                    @SpookDog thank you mate. I hope you’re well. I had a lot of plans this year but life decided otherwise 😂
                                    I’ll keep everyone posted with things coming
                                      @Stevie-Wonder That sounds grand. I love my SM setup, but trust me, the bike is most fun in stock trim. 100% believe that. Want a fast bike, do your test, want a bike that puts smiles on your face.... Well you found it!
                                      My bike got stolen and smashed to pieces and I was sick of the sight of it, hence why it went and got modified. But if the bike never got stolen then I would have left it stock.
                                      Part of the my enjoyment back then came from the rebuild. But I have long since grown tired of that and the headaches!
                                      Hark_PtooieH
                                      Hark_PtooieH
                                      Hark_Ptooie
                                      Good looking thing! Love the decals in front.
                                      Both my previous DT125's were stolen, smashed up, and found in a ditch. First in 1991, second in 1999. What it is with DT's and sadistic thieves?
                                      The second one had done a thorough job, there were wooden sticks protruding from holes in the expansion chamber and headlight.
                                      • Hark_PtooieH Hark_Ptooie
                                        #157
                                        @Hark_Ptooie said in Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR):
                                        @Hark_Ptooie I think it's jealousy. When you're 17-18 yrs old and rock up on a flash 125, it really gets people's backs up, specially if they're the kinds of teenagers who aren't capable of anything more than sitting in a bus shelter, drinking two litres of cider and endlessly complaining "there's nothing to do round here".
                                        When I got my 1st DTR at 17 it changed my life, we lived somewhere pretty remote by UK standards but suddenly I was able to ride out 7 or 8 miles to the nearest town and see some mates. So I unwittingly came in for rather a lot of this because I had a nice DTR, plus the fact I was faced with the petty-minded attitude of people who realised I didn't grow up on their street, go to the same school as them etc. This included:
                                        My bike being vandalised several times when parking it in the middle of town.
                                        An endless supply of bozos flicking the kill switch to "off" when I wasn't looking.
                                        On one occasion I parked the bike outside a pub full of "local people" and someone pulled the 2T oil feed pipe off the reed block which resulted in the engine seizing solid at nearly 70mph. AC lighting + seizure = the lights go out when the rear wheel locks in pitch darkness. I saved it with the clutch but this was a terrifying experience and extremely spiteful, whoever did that knew what they were doing with two-strokes and fully intended to cause harm. I never found out who did it.
                                        I went to school in the 80s where we had it drummed into us that we were very lucky to live in the free world. The Berlin Wall came down when I was 15 and I'll never forget watching the people streaming across the border on the news, it was the 1st political event I ever paid attention to. Looking around at all the beautiful consumer products we're able to own in industrialised western countries, it's a great shame that jealousy, cowardice and fragile egos conspire to mean one has to be careful. If you read the chapter in Animal Farm where one of the younger pigs comes up with some new ideas to run the farm more efficiently, and the senior pig urinates all over them before storming off, that is basically the mindset you're coming up against with such people. In the USSR they could send you off to the gulag but in a free society, they have to be content with fucking up something owned and enjoyed by you.
                                        https://www.youtube.com/watch?v=znb_X48WXUg&t=3s
                                        Please don't consider this a negative post. Individualism is a lonely and difficult journey but 100% worth it.
                                        • Hark_PtooieH
                                          Hark_PtooieH
                                          Hark_Ptooie
                                          Yeah, I suppose. I went back to uni when I was 30 and had a CBR929RR. The rest were all like 19 year old and didn't even meet my gaze, least of all talked to me. And one day I found a hole in the saddle.
