211 Posts 11 Posters 119.1k Views 3 Watching
    @Calum probably sounds complicated because there’s a lot I don’t know and words and things that I don’t know what they belong too and a lot to remember
    What extra stress do you mean as I thought the 125 and 200 shared crank bearings so I figured in that sense you shouldn’t have to worry so much
    Either way I’m prepared for the extra upkeep, the way I see it is the it’ll get me very comfortable with the engine and once I’ve done one time every other time should just easier
    I’m actually a big fan of the zip lock/sandwich bag method, i also Chuck some two stroke oil or acf50 in the bags with the bolts sometimes it helps revive/preserve them
    What I was planning on doing was getting a few bits of carb board and tracing the cases and numbering the bolt holes then poking the bolts in the appropriate places, keeps them safe and knowing where they went is self explanatory.
    @HOTSHOT-III cheers for that, I don’t have any access to any mains power or power tools so any more primitive methods are preferred
    I’ve also been watching this video a lot
    https://youtu.be/7hHF5FC5ko4
    Not a fan that they didn’t use decent gaskets but the video is good quality and it’s made me want an engine cradle
    #133
    @Stevie-Wonder
    Removing the bearing from the crank is the worst part. It’s so easy to ruin the crank by trying to lever of the bearing. It is how I removed mine tho, just have to be careful not to dent the crank edges with the levers. I used wood to protect the crank edges...
    If the crank bearings are good, and the big end bearing, you don’t need to build the bottom end. If it’s not broke, ect...
    I would definitely do your main seals though. You have had similar symptoms to my ‘weak mixture at low throttle ‘ problems that were causing my head gasket to blow...
    • Stevie WonderS
      Stevie WonderS
      Stevie Wonder
      Okay thank you guys, I’ll be pulling the top end off and checking the bottom end.
      For the price of a set of rings, an OEM gasket and having the head and cylinder skimmed itd be stupid not too.
      I do have a really good pick set in my repertoire which has made life beyond easy for grabbing out seals in wheel bearings etc so I’m pretty sure I should be able get them out, I’ve got a pretty good feel for those things.
      However I would’ve been pretty hap-hazzard about the crank mating surfaces, which of course being ally would be easy to score or burr
        @Stevie-Wonder
        The seals came out real easy in my case bud. Just replace them with good reputable ones if you can’t afford genuine parts. I made the mistake of buying fleabay China the first time round ☹️
        What do you mean about the ‘crank mating surfaces’ though? You mean crank cases? If so, that little hole/slot in the front bottom of the bottom end makes a good leverage starting spot. Be gentle and put in plenty of rubber mallet tapping all around and it will separate without having to use brute force. Shit man! If I can do it!! 🤪
          @Stevie-Wonder
          Stevie WonderS
          Stevie WonderS
          Stevie Wonder
          #136
          @SpookDog sorry I meant the outer surface which the seal presses against
          And consider myself told! I think I haven’t spent much time with the engine apart either so I’m a little blurry and unfamiliar except from what I’ve read so it’ll be a good exercise to pull her apart.
          Give me a couple weeks to get paid and I’ll be ordering the bit needed.
          So far I need, gasket, new head studs + screws + copper washers, @HOTSHOT-III crankcase splitter tool thing, clutch holding tool (i think I have one already), cordless impact wrench, JIS screwdrivers (I already have a pack of 5 which are very good and I’m if I remember right I’ve got JIS ratchet attachments too), 1/4” torque wrench / a nice handheld torque wrench (i actually already have one except it’s for cars and is huge not very ideal for doing cylinder studs etc), lots of sandwich bags + sharpie and zip ties, sheet of cardboard for making a template to stick bolts that require being placed in a specific order into.
          Anything I missed?
          CalumC S 2 Replies Last reply
            Anything I missed?
            @Stevie-Wonder do you need new head studs? What's the matter with the existing ones?
            You're definitely dotting the i's and crossing the t's.
            If you are just doing the top end then you won't need much in the way of sandwich bags and zip ties. It only takes an hour, including time to take the tank off so there won't be any time to misplace stuff.
            I didn't use an impact gun, instead stick a screwdriver inbetween the primary and secondary gearbox output cogs. That'll lock the crankshaft to get the clutch basket off. If you do it in situe then the engine mounts will hold the engine steady. Again no more than an hours job to replace the crankshaft seals.
              Anything I missed?
              #138
              @Stevie-Wonder
              You lever on the seals centre, not it’s outer edge 🙂
              You will need a tool to hold the clutch centre while you undo/do up the clutch centre nut. Sticking a screwdriver in will allow you to undo the crank nut though 😜
              • Stevie WonderS
                Stevie WonderS
                Stevie Wonder
                Cheers for your help boys, I’m convinced it’s a piece of cake now and I honestly look forward to taking everything apart to see if we can get her running again.
                I see why you love two strokes so much, very little to go wrong and very easy/cheap to replace.
                With the head studs I thought may as well as everything else would be new, plus don’t you need to replace the washers anyway?
                Also yeah thinking about it as long as I’m organised and methodical I should be good, most of the bolts that come off can be left or put back in the put it in to avoid them getting lost anyway
                @SpookDog Ohhh like use a hook pic or a spikey to stab into the middle to pull/lever it out. If that’s the case I always thought it’d be much harder then that 😂
                Also can anyone reccomend a tool for that job.
                I think it’ll be a couple weeks before I can order the bits too
                  @Stevie-Wonder
                  Like I said, small flat head screwdriver 🙂
                  Only replace the head studs if you have to, then only with genuine ones. Never buy fleabay ones! They may as well be made of glass 🥴
                  Breaking a stud of in the barrel is a pain in the ass. My local reputable bike shop put in the helicoil pissed, like the tower of piza 😐 ...
                  • Stevie WonderS
                    Stevie WonderS
                    Stevie Wonder
                    Engines out, ready to be stripped.
                    I’m going to leave the engine standard and focus on performance upgrades last.
                    In the mean time I’m just going to take things slowly and get her ready for next year.
                    Whilst stripping the engine I noticed the swing arm bushings etc looking like they could use replacing.
                    Rather then rebuild the stock swingarm I’ll buy a bearing kit for the DT200wr swinger I’ve got, get it painted and finally chuck it on the bike. Im really really excited about seeing this on the bike and feeling the weight difference between the two swingarms.
                    Another thing is 19” rear wheel jacks the ass up a lot, the bigger wheel doesn’t look right and tire options are limited. Plus with USD’s on the front and knobbly tires it makes the DT a very tall bike. Even for someone 6ft.
                    For those reasons that’ll be going shortly.
                    I have to wire in a trail tech vapor speedo too, I have been without working clocks for sometime now. Not good.
                    Im shit with electrics so I’ll probably pay someone to do that and save all the agg.
                    I wish they where just the standard DT clocks but that’s just not on option anymore with the front end I’ve got now.
                    This is everything I reckon I’ve got to do
                    Everything the DT needs to make 100%
                    Front brake hose holder clip €22.50
                    5DH2587500
                    Brake pad retaining pin £
                    5DH2593300
                    Front wheel inner Axle threads needs heli-coil/tap and dye as does brake hose guard cover bolt
                    Cover, Hose €23 (UFO/Polisport disc cover will also do the same job and give 90’s aesthetics)
                    5DH2314E00
                    Oem Fork guard bolts (Anodised ones are usually ally and the threads give way after a couple twists, it’s amazing it’s took until now for most of them to go missing/work their way free)
                    Rear panels + graphics (bikerpartshop + hazard)
                    Helmet lock 5H0-21308-01
                    Possibly oil + coolant for once engine’s drained
                    Seat cover - either custom or bikerpartshop dark blue replica
                    • Battery strap
                      22F-82131-00
                    https://sumorubber.com/straps ( a very handle little sight that specialises in battery straps for vintage bikes, the steel on my battery strap that clips to the frame had completely deteriorated)
                    DT125R headlight frame / bracket holder. (I love the 3et light for its slimmer profile but the smaller size with the bigger forks means there’s not a lot of space to put your dash, the original would be more practical, look better and fit better.)
                    Working fucking clocks!!!
                    Speedo cable wire for Vapor
                    Magnet pick up sensor
                    DT200WR swinger needs difference in pivot mounts measuring + chain alignment checking
                    18x2.15 excel rim
                      5DH2587500
                      5DH2593300
                      5DH2314E00
                      • Battery strap
                        22F-82131-00
                      18x2.15 excel rim
                      @Stevie-Wonder With the engine removed from the frame, now would be an opportune moment to test the fitting of your DT200WR swingarm. Sounds counter-intuitive I know, but assuming the swingarm pivot bosses are the same width/distance apart as the stock steel arm (meaning it will fit into the chassis), it's the engine boss which dictates it's (and in turn the rear sprocket/wheel) position in the bike. Sprocket alignment is the biggest enemy here; you won't notice front/rear wheel alignment being a few mm out as once you factor in tyres, rims etc. (MOT allows 4mm lateral rim runout) most bikes on the road aren't perfect anyway.
                      Here's an explanation how to do the swingarm side clearance with pics from the Yamaha manual. Don't forget you'll need to do this again after splitting and reassembling the crankcases as this process might alter the engine boss width:
                      https://dt125r.co.uk/post/29135
                      It's actually possible to do this without going near the chassis if you have the engine out; I went through the process using a 3ET swingarm and a spare set of crankcases to do a workbench mock-up to assess sprocket alignment. 3ET swingarm, spindle, drive side spacer and rear caliper mount (it's thinner due to the fatter ends of the alloy arm) and stock DT125R hub produced almost perfect sprocket alignment according to my 600mm straight edge. I might need to play around with this slightly to get it perfect; there was a 3mm thick M20 washer between the caliper mount and arm when this pic was taken and the sprockets look about 1mm out.
                      Good shout going back to an 18" rim. If you can, go back to your stock 18" DTR rear wheel as well because stock rear wheel with good sprocket alignment = wheel alignment (or at least it places your stock rear wheel where it should be) which will keep things simple for now. Also 19" rear wheels on MX bikes were largely an attempt to reduce the rear wheel's weight which reduces unsprung weight/inertia to improve acceleration and suspension responsiveness on the track; most Enduro bikes run 18" because the flabbier tyre sidewall is more forgiving and offers better puncture resistance against rocks, roots, Ferguson tractor parts in the corner of farmers' fields etc.
                      https://www.thumpertalk.com/forums/topic/213621-18-vs-19-wheels/
                      I can't comment on the DT200WR arm as the chassis is different from the DT125R as well meaning you might need the entire rear suspension assembly to make it work (the DT200WR shared a much beefier relay arm and linkage with the WR200 IIRC). And compared to the 125 steel arm I'd be looking at overall length as well as the distance between the pivot and where the linkage attaches to try and get an idea whether the leverage ratio will change noticeably.
                        Stevie WonderS
                        Stevie WonderS
                        Stevie Wonder
                        @HOTSHOT-III said in Stevie’s French '98, Mid-90's WR/YZ/DT (An idiotproof guide to building your own DTR):
                        Thank you for that @HOTSHOT-III thats really helpful. The swinger still needs painting, which I’ll get round to eventually none the less I’ll be doing what you said.
                        My 19” rear is just a YZ rim laces to DTR hub so in theory the alignment should be the same.
                        • Stevie WonderS
                          Stevie WonderS
                          Stevie Wonder
                          I’ve since split the cases, I don’t have photos but the top end was pristine. The head had no plinking/det marks, crosshatching on the bore still, perfect even burn pattern along the piston crown and a beautiful bronze/brown colour. No play in the crank either.
                          My suspicions were right and both seals had in fact given up. A quick call to PJME for a round of oem seals, power valve rebuild kit, Yamaha seals and some koyo crank bearings for good measure and we’re sorted.
                          I also did some tinkering today and found out what’s wrong with my clocks as I was having issues with using the stock ones with my USD forks.
                          -The Speedo side of the clocks fine, however when I hooked up I didn’t get reading so the speedo drive is possibly faulty. Plus to make matters worse speedo drive is to opposite side of the clocks meaning you can’t route the cable properly.
                          -I found out the rev side of my clocks has seized somehow which is why my bike snapped two cables.
                          (If anyone has any experience with taking the clocks apart that’d be great, are they complicated/fiddly?)
                            #145
                            @Stevie-Wonder
                            Standard clocks? You have to separate the base with a Stanley knife. Then stick it back together with mastic/sealant…
                            I’d try wd40 and try to get it moving with a screwdriver or such. The bit that spins has a magnet inside the unit that sits inside a kinda steel ‘bell’ that connects to the needle. The spinning magnet moves the ‘bell’ which has a very delicate return spring…
                            It’s fiddly but doable. If the gauge is fubar you’ve got nothing to loose…
                              @Stevie-Wonder
                              #146
                              PS the input where the square end of the cable fits into should turn/spin freely in either direction. Don’t worry about damaging the internals by forcing it a tad! There’s no physical connection inside 🙂 …
                              • Stevie WonderS
                                Stevie WonderS
                                Stevie Wonder
                                Cheers man I’ll give that a try
                                Engines back together now, took an afternoon to do between me and Stacey of VJMC Suffolk division, the crank bearings and seals come out no trouble and it was fun educational experience. They’re surprisingly simple and light.
                                Still learning about the gearbox aspect. That’s gonna take a couple more goes before I get.
                                I polished the piston crown, rebuilt the powervalve and through a set of koyo main bearings and used OEM everything else.
                                Unfortunately I forgot to order a Reed gasket so we’ve had to put it on hold until that comes back, then we can see if she runs.
                                  @Stevie-Wonder
                                  More hands on you get, the more confidence you gain. Good to hear you’re still around 🙂
                                  You been riding that FZR, wasn’t it? Revvy 4/ fun!….
                                  • Stevie WonderS
                                    Stevie WonderS
                                    Stevie Wonder
                                    Yes my FZS600, a great bike with plenty of power. Very Rev happy, very reliable too. I’d definitely own one again. Unfortunately I had to sell it. My only complaint isn’t really so much a complaint but more personal preference and that’s that it felt like riding a two stroke, the power was very linear yet flat at low revs but increased more and more with the revs. It makes for a lot of fun but personally if I wanted that feeling I’d just experience the real deal by riding a two stroke. If I’m riding four stroke I like bottom end and not having to constantly be on revving the tits of it. It gets annoying after a while, that is unless it’s a two stroke.
                                    Update with the bike, I’ve sourced some parts for the DTR thanks to a certain someone (forget their @). I’m getting rid of the 200r headlight, making a second rear plate holder and at some point I might buy some replica OEM indicators. The 19” rear will eventually go but I’m not replacing it with anything other than an excel 18” so that’ll take time and $$$. From the parts I sourced was a headlight frame to put the original back on, quite looking forward to putting the original back on to be honest!
                                    I do need to somehow sort out a mount for it. I also replaced the rear mud flap as my one got eaten by a whopping great big knobbly that I put on my bike when I first got it. 140/80-18’s aren’t for your bike is what I’d tell myself if I could 😂.
                                    So far so good with everything really, since being rebuilt I’ve only rid her around a couple times, she’s yet to go on any proper outings though.
                                    On my list of jobs to do was to change the pads as the right side of my EBC pad had literally just fallen off. What was meant to be a quick job turned into a bit of a nightmare though as the calliper wouldn’t come away from the hanger. Many hits and a lot of heat made absolutely no difference at all. When it finally did budge it was just the thread of the pin coming loose
                                    I’ve since disconnected the calliper from the hose and left it to soak in methylated spirit as the Aussie’s on fb said that remedied their issue with the calliper fusing/seizing to the pin to their 200r’s.
                                    I’ve been told it’s a common problem, if any one has any advice for this then let me know.
                                    Id noticed the seals of the piston protruding out too, so whilst I am tempted to push the piston in give it all a thorough clean and then Chuck it back together so it’s sorted, I know it’s only going to be a temporary fix and it’ll need to be done one day.
                                    Plus knowing that my callipers seized to the hangar bucks the shit out of me because everything else on my bike has been perfect,
                                      Uuuhhmmm, two strokes aren't linear power. I think you've misphrased that.
                                      A lot of road going four strokes I've ridden are gutless and you have to wring their necks to actually make them fast. I don't see that as being akin to a two stroke.
                                      ZX6R
                                      Where as an RD350LC, or two stroke will have a much more erratic explosive powerband.
                                      Bear in mind on the RD, you're talking about something which makes DTR power just above idle. So they are very rideable, but the real fun/power is up at those higher RPMs.
                                      You really need to be up there (750cc+) on four strokes for them to actually be fast IMO.
                                        ZX6R
                                        Stevie WonderS
                                        Stevie WonderS
                                        Stevie Wonder
                                        That’s exactly what I mean, I’m not talking about the literal powerband but the way the bike feels and is ridden. That revvy in-line four akin to the DT is begging to have its necks wrung because you literally double the amount of power high up in the revs and like said that’s how you make them fast
                                          @Stevie-Wonder Yeah, I see what you're saying. With a bigger 4 stroke it's not like that so much. I haven't yet ridden a super bike however.
