1.1k Posts 26 Posters 740.9k Views
  • S
    Posts have disappeared, as well...
      @SpookDog It'll be something to do with your phone unfortunately. There isn't anything I can do my end to fix that.
      If you go to the Apple App Store and download a different browser you'll see that it'll appear as normal.
      https://apps.apple.com/gb/app/firefox-private-safe-browser/id989804926
      It's working fine my end after I patched the software, but when I used my laptop the website was totally broken for me. Clearing my cookies/cache fixed this issue for me.
        @SpookDog I've had similar problems in the past. I just signed out of this forum then signed in again.
        • S
          Tried downloading browsers but it needs iOS 13 or higher. My old iPhone 7 is only supported to 12.5.
          None of the funcion buttons are working. I can’t see new updated posts or anything.
          I’ll try and keep up through other means, but until I get a new phone, Adios! 🐾🐾🐾
            @SpookDog hhmm 🤔
            I am sure its just a browser cache thing, but I can't not patch the forum software, otherwise its vulnerable to critical vulnerability exploits, ransomeware and denial of service attacks.
            I mean you only have to look at the 'User Sign Ups' to see the bots that hit this website on a daily basis.
              @SpookDog hhmm 🤔
              iOS 12.5 isn’t supported anymore, we live in the age of built in redundancy 😑
              Oh well! 🙂
              My front sprocket has been wearing unevenly on the inner side. I’m wondering if there are different front sprocket spacer sizes? If the lock/tab washer thickness could affect, or if I’m just missing a normal washer? I’ve never seen a sprocket wear away on one edge/side before. I can’t work out what is causing the discrepancy in the front to rear alignment to cause the wear. Any insights, anyone?…
                Oh well! 🙂
                Am I right in thinking that there are only 3 wheel spacers for the entire Dtr range? Two rear and one front? I’m hoping that I don’t have the wrong width spacer on my bike that is causing the offset in my sprocket alignment?…
                I’d rather fix the problem than treat the symptom by fitting a spacer-washer to the front sprocket…
                HOTSHOT IIIH 2 Replies Last reply
                  #335
                  @SpookDog The front wheel spacer is very different to the rear wheel spacers so you'd know if you'd got that wrong, in fact it's a much smaller ID than the rears IIRC so that's ruled out.
                  The DT200R drive side rear wheel spacer is a lot shallower than the 125 (because the 3ET alloy swingarm is a lot fatter at the ends) but you'd notice if you had a DT200 spacer and a 125 steel swingarm, I mean you'd have to physically pinch the swingarm ends together to tighten the rear spindle. Which would probably result in bigger problems than slightly uneven sprocket wear.
                  Depending upon how your snailcam chain adjusters are oriented and which side your rear spindle nut is on, it's possible to inadvertently adjust one side wrongly when tightening the nut but if you've owned and ridden the bike for a year or two you're unlikely to get this wrong. I like to have the spindle nut on the brake side and the snailcams oriented so the brake side one has to rotate clockwise to tighten the chain; this minimises the possibility of the cam slipping. Also snugging them against the anchor pins on the swingarm by wedging a rag between the chain and rear sprocket whilst tightening the spindle nut helps.
                  Assuming your swingarm bearings have no play (worth checking) my money is on the swingarm side clearance adjustment having been done wrong by a previous owner. It's a lot less complicated than Haynes makes it look (how unusual lol); you're basically trying to get the swingarm to move freely with 0.4-0.7mm of side-to-side play with the swingarm pivot nut done up tight (the arm should fall under its own weight with the nut tightened and without the rear wheel/linkage attached). Crucially, if you need to add shims to take up excess play, Yamaha insist you only add them to the right-hand (i.e brake) side; the one 0.8mm shim on the drive side is what retains front/rear sprocket alignment. Here are some pics of the procedure in the Yamaha manual along with my calcs from the last time I reinstalled a DTR swingarm written in my childlike scrawl.
                  One other thing, if you get an All Balls 28-1212 or similar bearing kit (the WRP one is exactly the same) they come with 1mm shims; Yamaha shims are either 0.8mm or 0.3mm so you might need to order some if you get the arm out and find you don't have enough to get the side clearance right. And 90Nm is ridiculously, thread-rippingly tight for the swingarm spindle nut IMO; Yamaha do this a lot on the DTR, I guess so they don't get sued for major components falling off when young lads are out riding. I've always done up that nut up to 55Nm and it's never moved.
                  No-one ever does swingarm side clearance on the DTR; even with some of the "DTR specialist restorers" you can tell by their social media pics they don't bother with this step but potentially, if it's far enough out it could produce uneven front sprocket wear over time. Even if it's not the culprit, checking it will it give great peace of mind!
                    #336
                    @SpookDog Also just had a look on Fowlers Parts, the 3RM DT125R and 3ET DT200R output shafts, sprocket lock washer and spacer behind the front sprocket are all the same part number. Only the sprocket nut is different (I guess thinner to accomodate the 200's 520 front sprocket) so I can't see that affecting sprocket alignment (unless someone has tried to bodge it with a DT200R sprocket nut and extra washer between the front sprocket and spacer, but this would be very unlikely).
                    https://www.fowlersparts.co.uk/parts/4105071/dt125r-3rm5-1993-999-a/transmission
                    https://www.fowlersparts.co.uk/parts/4059369/dt200r-3et1-1988-010-b/transmission
                    Only other thing I can think of would be if the bearing behind the front sprocket is on the way out allowing the output shaft to move around. This does happen eventually when people adjust chains too tight on bikes with long-travel suspension but would be very noisy if it were that far gone and you'd be noticing oil leaks and gear selection problems and all kinds of stuff...
                    CalumC S 3 Replies Last reply
                      @HOTSHOT-III Yeah I didn't even realise the swinging arm even had adjustment! That's pretty meticulous to say the least. I know that the Aprilia has a swingingarm tension bolt procedure, but again it's never something I have ever done.
                        Cheers for the info bud! I did the swingarm shims check by the Haynes manual. It was a while ago though. Put 20,000 miles on it since then 🙂
                        I do have the rear spindle but on the chain side, with the snail cams having the flat edge down. Don’t know if that affects it at all?
                        My swingarm ‘knobbles’ are a bit fubar tho, one of them (the sprocket side one) is flattened off where the cam touches it. Even allowing for this I don’t think it would affect the front sprocket like has happened?!
                        It’s like the front cog wants to be out 1mm more, or the rear 1mm in further…
                          #339
                          Thanks again for putting my mind to rest on the rear spacers!…
                          The other thing I forgot to ask was if anyone knew if Tzr sprocket spacers were different than Dtr ones? My bike is a pure mongrel and may well have a tzr lump in it for all I know 🙂 …
                          At some point I’m going to have to check that I definitely fitted the 0.8mm shim on the sprocket side of the swing arm as well, would explain a lot if I didn’t 😏 …
                            @SpookDog Depending on what TZR you're referring to...the TZRs ran a completely different engine. It was only the Belgarda models that ran the DTR lumps and you'd know if you were running one of those. They have Motori Minarelli stamps on them all over.
                              Any spacer from a 3mb bottom end? I’m not sure, hence asking. One of the joys of owning a mongrel bike is you have no idea what’s right or not. I have no previous experience with a righteous Dtr and am grateful for any enlightenment…
                                #342
                                Second hand forks, yokes and spindle arrived today! Really good condition for the price (£50 + 20 post). Swingarm arrived last week, things are looking good…
                                5090 miles and my head gasket let go today as well 🙂 I’m actually surprised it lasted as long as it did! It was over the previous 700 mile threshold for failure before I found and fixed the weak idle jet mixture fault, so it must have taken a lot of misfire/knocking abuse before it was fixed!…
                                I just need to work out my plan of action next. I’ll probably just throw on a new gasket and rings with a re-hone to see me through the winter. I’ve got another bottom end & crank I’d really like to build with new Koyo bearings and seals to mate to a fresh rebore & piston…
                                  Does every dtr frame have a kinda U-shaped tubular piece that bolts onto the back of the frame, under the mudguard? I saw a picture of a frame with said bit fitted, but mine just ends in 2 flattened tubes with holes in them…
                                  I’ve never seen this bit before the 1 picture, so I could do with some guidance from people that have original, righteous frames…
                                  S 2 Replies Last reply
                                    Scootjockey
                                    I take it your frame doesn’t have the rear sub frame attached ? Earlier 80’s models the frame goes round in a continuous bend. Later models had a bolt on rear subframe which have a kink above the exhaust to allow you to hold on to the rear of the bike. The 2002 DT125R I bought for my son didn’t have the rear subframe or shopping rack, common practice is to junk them and jack the rear mudguard up to give the bike the Crosser look, mind you both replacements were purchased on eBay for about £100 each from memory. And hens teeth to get hold of. Neither of them were straight and took a bit of manhandling to get right. Look up on fowlers parts for the year/model of frame and if you need a sub frame it will be displayed on that page. Sometimes it’s pictured with the rear mudguard.
                                      Scootjockey
                                      One on eBay at the moment ref 165784055445. £75 including the helmet lock for a DT125R I think they changed the frame in 1996 and onwards.
                                      • S Scootjockey
                                        @Scootjockey
                                        Cheers bud! It’s good to know these things. I’d love to have a proper good gurn at a righteous standard 88 bike just so I can see & list all the bits I’m missing. One of the many previous boners deleted the rear foot peg mounting holes, as well as I don’t know what else! 😐
                                        There are loads of bits n bobs I’d like to get, rear reservoir ‘lock’ cap, same for rad cap, oil bottle. Original reusable cable/frame ties, CDI rubber mount, & on & on&on…
                                          @Scootjockey
                                          Scootjockey
                                          Try WWW.ALEADO.COM
                                          it’s a Japanese broker a bit like eBay, but you give them the money open an account bid on the item and the seller sends it to them and they forward it on to you in the UK. Usually see older better parts for sale. There not always cheap but you find they are better condition. Also change your country setting on eBay if you use that… always find parts are better from France and Germany !
