1.1k Posts 26 Posters 666.9k Views
    What do you recon bud?…
    114454049955
    EBay…
    #448
    @SpookDog That's for an SR125 which has I think an 17" front wheel, and the spindle diameter is likely to be different as well so it definitely wouldn't fit a DTR.
    https://www.motorcyclespecs.co.za/model/yamaha/yamaha_sr125 97.htm
    Have you tried Motorcycle PartFinderUK from my previous post?
      #449
      Same diameter 15mm. I was more interested in the 3 prong internals. I could use my gear wheel if not my worm drive. There are some used ones going for £11 I’m going to see if I can find measurements for one. The 3 prefix letters are different but the middle numbers (25190) are the same, it has an 01 on the end instead of a 00. I’m hoping that an upgrade to where the cable fits in, an oring maybe 🙂 I live in hope!…
      Gonna try part finder later today but don’t think it’ll be cheap…
      Edit Got one coming for £8 it’s worth laying eyes on for that price…
      There are mid 80’s XT ones that look the same, 3 prong and seal ect. Some of the XT’s used the same speedo/rev counter as the dtr I think…
        Would you believe it that my top end has developed a rattle that is only getting worse! 😬
        It’s my fault for using second hand top ends before, because I couldn’t cure the head gasket blowing problem.
        Now I’ve solved it I want to get my original 3MB barrel rebored with piston, ect. I’ve got another bottom end I want to put new everything in as well though, while I’m at it.
        I might put the Tzr on the road first though. So I’ve got something to run while I get the frame and casings, ect powder coated…
        Juggling decisions on a shoestring budget, you kinda got to get it right before you do it 😐
          #451
          Can you believe that this worm gear will still not just pull out?! 😵‍💫 …
          Even after beating the brass cap/insert up & out the worm gear shaft won’t come out 🙂
          I had to cut down even further because the hard steel of the worm gear had ‘burred’ over a lip on the ally that held it in!…
          And finally! Freedom! And it’s not bent!…
          My~Fucking~Life!…
          SAPFM!….
          Is there supposed to be a washer on the top @ bottom of the worm drive?
          Mine only has one on the top? I’m guessing that the spin makes the drive ride up against the top washer, so it doesn’t need one on the bottom?…
            My~Fucking~Life!…
            SAPFM!….
            @SpookDog I noticed the washer was always on the top of the worm drive when repairing the plastic ones; odd because as the worm gear rotates with the wheel, IMO it pushes the worm drive downwards. As I said I bought a load of shims the correct ID/OD for pence from China and just shimmed mine at top and bottom when reassembling.
            I wouldn't go for the SR125 NOS one if I were you; if the spindle is the same diameter all well and good on that score but the internal gear ratio will be completely different for a 17" wheel meaning the speedo won't read correctly. And paying £55 to try and swap your internals into it, you might as well pay the extra £19 for a brand new 3XP one from Fowlers.
            Expensive for a speedo drive though yes, I'd be getting on to PartFinder and Googling breakers all over the UK. Also consider getting on FaceBook as there's around 15-20 dedicated DTR pages full of helpful people, some of whom buy and sell DTR parts all the time. This forum is excellent but bottom line there's more people on FB, I'm not a huge fan of social media but you have to make it work for you.
            IIRC Yamaha use the same numbering system for all their parts, the actual 5-digit number is the same for a particular item (a spoke set for instance) and the 3-digit prefix denotes the model (3XP = DT200WR I think, so I guess they adapted that bike's USD forks so th same shape speedo drive could be used). 00, 01, 02 etc. endings are where a part has been superseded with minor changes.
              #453
              I’ve ordered a second hand one for £8.00 I don’t think I can go wrong at that price…
              Damn it I’ve got water in the carb again! I think it’s cause my tank is very rusty inside which massively increases surface area, add that to a cheap cap that lets air in and it gets a lot of condisation in the tank. It’s the only reason I can think of anyway. Just another upgrade job to do when I have the money and off road time to do it. Or stop running it onto reserve! 😛 Looks like I’m going to have to get the Tzr running, which I’m going to have to half ass to start cause I don’t have the money to get the 4Fu steel liner put in @ PJME…
              Happy daze to all you smokers out there! 😬 I hope you have better luck with them than I does…
                #454
                Stripped and cleaned the carb last night and put it back together, then the 250 main jet I ordered a while ago turned up this morning! 🙂 …
                Bikes running well again though without the blob of water molesting the jet…
                Noticed that a couple of the links on my x-ring chain have locked solid. The road salt really kills them in no time at all. Thankfully spring is real close and I have new chain and sprocket, along with new tyres to go on. Will have to put the new forks together without painting them like I wanted. Those are the licks of being a peasant tho! 😀 …
                  #455
                  Just another Monday night 🙂 …
                  Took the top end off to change the little end bearing. Turns out it was the gudgeon/wrist-pin had eaten away at the piston and allowed enough slack to vibrate like… well, a vibrator 🙂 but on one side only…
                  I’m guessing it was caused by yet another piston ring placement pin failing? Basically the top ring was free to spin/turn as and when/where it pleased. Judging by the wear on the ends of the top ring it looks like it was playing chicken with the inlet (& exhaust!) ports 😛
                  Both ends are chamfered off! Also my power valve looks like the loose rings were polishing it!
                  I’ll get there eventually though, I’m nothing if not stubborn 😬 …
                    Nothing has touched this outside of the barrel…
                    It’s polished and chamfered by the top ring I’m guessing…
                    I think I’m real lucky that this didn’t snag a port & detonate, so i guess things could be worse 😛 …
                      @SpookDog Dayum! Luckily these engines are so simple it's just a case of dusting it off and reassembling.
                      I took delivery of new piston/rings/gaskets/small end this morning, so I'll be fitting my ported big bore soon!
                        Yep, I couldn’t get a decent pic of it but the top ring location pin has just ‘disappeared’ off flush with the piston. Weird having two fail in a row so soon. The top ring was literally spinning around in the groove. I’m amazed that an end didn’t tangle with a transfer port…
                          @SpookDog there's a Speedo drive on Facebook group for £40 Inc postage.
                            @SpookDog The genuine Yamaha pistons have always been prone to ring pegs getting out and walking on the DTR, TZR125 and TZR/TDR250. Back in the 90s when having a rebore, we would demand Japanese Mitaka piston kits by name as they were better. Not tried any of the Wossner etc. ones available these days but Mitaka always did the job for me and I think PJME sell a lot of them.
                              #461
                              @markus-w
                              ![alt text](image url)
                              Cheers bud, I’ll keep that in mind till ‘pay day’ 🙂 …
                              Hotshot! I agree with the jap Mitaka piston. It’s good stuff. I used my original one that got its crown eaten into to put my engine back together, along with the barrel that the pin ‘walked’ out of! It’s not ideal but it’ll keep me mobile till I get a couple of barrels of to PJME for rebored 🙂 bike is running really sweet with the mismatched pair as well!!…
                              Back together 11.30 last night!…
                              Just did a 40 mile shake down ride and it was well perky 🙂 even though I’m not going above 5~6K…
                                @markus-w
                                #462
                                I really am impressed with Henrique Romeau’s workmanship & design…
                                I found a 22mm stainless steel P clip on fleabay for a few quid…
                                Fits a treat and rubber mounted to counter vibration…
                                Looks the part as well…
                                I drilled out the mount hole on the pipe to 15mm to take a rubber mount, formerly used as a radiator mount on the Dtr…
                                The reason for the rubber mounting is that stainless steel is a very brittle metal with non of the elasticity of softer steel. If mounted to tight and subjected to vibration it can crack quite easily…
                                PS this is what happens when you ride around on salty roads! If I had access to a jet wash I’d rinse it down every chance I had! Salt kills almost as many 2 strokes as boyracers!! ☠️😛 …
                                  #463
                                  Speedo drive unit for the sr/whatever arrived at my sisters today. First impression looks good. I won’t be sure till i compare the two side by side. The oil seals are the same size, the ring drives are Less than 0.5 mm bigger on the new one. The only real difference I can tell is the teeth of the gears are different /// on one & \\ on the other…
                                  I’m gonna try fitting it later on, but for now it looks promising that the casing @ least will be usable. If not the whole thing…
                                    #464
                                    It fits but doesn’t work. I didn’t realise that the gears slant would affect the rotation. I’m guessing the speedo drive is fitted on the left side. Shame because it’s identical but runs backwards! but back to square one. I’ll fit my gears into the good case…
                                    It makes me wonder if some of the XT ones are a straight fit…
                                      #465
                                      Have you drilled out an aluminium drive or plastic only? I’m wondering whether to try the back then drift out the pin or drill the pin out itself? I’m guessing it’s from the back…
                                      Again: if you know how to look up registrations and can find out what colour my bike was originally, I would really luv to know 🙂 …
                                      HOTSHOT IIIH markus.wM 2 Replies Last reply
                                        #466
                                        @SpookDog I looked up your 3DB - 001369 number and your bike is definitely an '88 round slide carb early bike, but it gives all three colours (white/red, black/red and endurance blue) as options.
                                        I've only ever repaired the plastic speedo drives. I think you could theoretically drill into an alloy one from the back and tap out the roll pin, but you'd probably need a fair bit of heat/PlusGas as the steel pin will be seized in to the alloy body. Or if you have a pillar drill and a means of firmly attaching the drive to the bed at exactly 90 degrees to the drill bit, you could drill directly into the pin with say a 1mm drill bit, then slowly increase the bit size and just get rid of it that way before choosing a slightly bigger split pin to reassemble it. TBH though it seems a shame to bastardize that SR125 drive as they're classics as well. So I'd stick it back on eBay and someone somewhere will buy it off you.
                                        Are you doing all this online stuff on a smartphone? Because a screen the size of a fag packet can make life very difficult. I have a smartphone but I'm old and crotchety as well, and I hate the things. Get a reconditioned PC for cheap, or use one at the library and you can have loads of windows open at once and look around all over the world for the best deal. And get on Facebook as well, I know I've said this before but there are a fair few lads on there who buy and sell DTR bits all the time, you could have an actual DTR unit in your hand by this time next week.
                                          #467
                                          @SpookDog as @HOTSHOT-III says. The Facebook groups are a really good place for getting parts and with much better prices than eBay. I myself was always anti Facebook but I gave in about 3 years ago and joined up for the sole purpose of joining the DT groups. Haven't got my picture on there. But as I said there's a Speedo drive for sale there for £40 including postage. If you want I can message the guy and try get a phone number for you?
                                          Also if you send an email to customersupport@yamahamotor.co.uk and tell them you have one of their bikes and you would like to get it back to original they will give you all the information you need. I did this when I got mine and received about 6 separate emails back from them. Even sent me a wiring diagram. Really couldn't fault their service. Give them the reg and vin.
                                          S 2 Replies Last reply
