  4. Ignition key replacment
54 Posts 4 Posters 12.9k Views
    Should be stamped into the frames headstock. Throttle side. Try the engine number as well. Should be on the gear change side, above the front sprocket. I’m going to hazard a guess that there’s no number plate?…
    E
    E
    erion
    @SpookDog yeah its a switzerland import i think because they got it in swiss in 2006 i think and we are the 2nd owners of the bike but the documentations are lost and we didnt register it in kosovo so yeah
      @erion to identify the year you need to read the frame number on the headstock. If you care to tell me the first few digits I may be able to help you with it. Should begin 3DB123 Or 3MD123 Or 4BL123? I'm guessing you don't know the reg? There's a company on Facebook called vin to reg/ reg to vin. They will find the reg from your frame number for £5 which you only pay if they find it.
      E
      E
      erion
      @markus-w in the head stock is a number pressed on the frame it's 4dk-006706
      And there is a number in the cylinder block wich may be the engine number and its 3mb00
      E S 2 Replies Last reply
      • E erion
        E
        E
        erion
        @erion and another one on the trans on the left side but im not sure where the engine number should be
        • E erion
          @erion
          Don’t want the cylinder barrel/block. You want the number above the front sprocket, just below/behind the carburettor…
          S E 2 Replies Last reply
            @erion
            Only thing I could find said it was a 94 Dtre!…
            E 1 Reply Last reply
              @erion
              E
              E
              erion
              @SpookDog there is a raised surface between the carb and the suspension spring its the same as the frame number
                E
                E
                erion
                @SpookDog its not RE tho it doesnt have electric start
                • E erion
                  @erion
                  Yeah, it should be if it’s a numbers matching, righteous bike 🙂
                  Has this bike ever been registered in the UK before? If it has I’d contact the DVLC and ask them. Or maybe try their website? If it’s not UK registered there are hoops you have to jump through that I know nothing about…
                  Someone here will know though 🙂 …
                    @erion
                    It might be a 94 bike then. They didn’t do RE’s till 2004 or 6
                      @erion
                      E
                      E
                      erion
                      @SpookDog my relatives bought it in switzerland from a neighbour in 2006 i think and they imported it here in kosovo its should of been registered in swiss but by many chances we are the 2nd owners of the bike and that makes me think its a model that was exported to swiss
                      • E erion
                        @erion
                        You are in Kosovo? Oh well I can’t help you bud! 🥴 …
                          @erion
                          E
                          E
                          erion
                          @SpookDog im looking if i can derestrict it somehow thats why im looking to find the year model
                          • E erion
                            @erion
                            Does your bike have a power valve servo fitted to it?
                              @erion
                              E
                              E
                              erion
                              @SpookDog idk what the servo one is but it does have a pwer valve conected to the cylinder with 2 cables , can you explain what the servo is
                              • E erion
                                @erion
                                Electric motor that the two cables come out of. Makes a noise when you turn the key.
                                If you count how many wires the servo connector has you can date the bike…
                                  @erion
                                  E
                                  E
                                  erion
                                  @SpookDog are you saying the 2 cables that go from the power valve upwards to a black thing with wires?
                                  • E erion
                                    @erion
                                    The black thing with wires is the servo, yes! If it has 3 wires it’s an 1988 -1995 bike, if it has 5 it’s later…
                                    • E erion
                                      #24
                                      @erion
                                      More questions! Does your bike rev freely above 7000RPM? Does it have a standard exhaust, or an aftermarket one?…
                                        @erion
                                        E
                                        E
                                        erion
                                        @SpookDog the cable for the rev metter is broken i need to buy a new one as fir the exhaust it has a standard one with akrapović muffler or idk what its called in the end
                                        • E erion
                                          E
                                          E
                                          erion
                                          @erion silencer*
