Ignition key replacment
@erion to identify the year you need to read the frame number on the headstock. If you care to tell me the first few digits I may be able to help you with it. Should begin 3DB123 Or 3MD123 Or 4BL123? I'm guessing you don't know the reg? There's a company on Facebook called vin to reg/ reg to vin. They will find the reg from your frame number for £5 which you only pay if they find it.
@markus-w in the head stock is a number pressed on the frame it's 4dk-006706
And there is a number in the cylinder block wich may be the engine number and its 3mb00 -
Don’t want the cylinder barrel/block. You want the number above the front sprocket, just below/behind the carburettor…
@SpookDog there is a raised surface between the carb and the suspension spring its the same as the frame number
Yeah, it should be if it’s a numbers matching, righteous bike
Has this bike ever been registered in the UK before? If it has I’d contact the DVLC and ask them. Or maybe try their website? If it’s not UK registered there are hoops you have to jump through that I know nothing about…
Someone here will know though
…@SpookDog my relatives bought it in switzerland from a neighbour in 2006 i think and they imported it here in kosovo its should of been registered in swiss but by many chances we are the 2nd owners of the bike and that makes me think its a model that was exported to swiss
@SpookDog im looking if i can derestrict it somehow thats why im looking to find the year model
@SpookDog idk what the servo one is but it does have a pwer valve conected to the cylinder with 2 cables , can you explain what the servo is
Electric motor that the two cables come out of. Makes a noise when you turn the key.
If you count how many wires the servo connector has you can date the bike… -
@SpookDog are you saying the 2 cables that go from the power valve upwards to a black thing with wires?
@erion
More questions! Does your bike rev freely above 7000RPM? Does it have a standard exhaust, or an aftermarket one?… -
@SpookDog the cable for the rev metter is broken i need to buy a new one as fir the exhaust it has a standard one with akrapović muffler or idk what its called in the end
