  4. Ignition key replacment
54 Posts 4 Posters 12.9k Views
    @erion it is 1994. My 1999 DT125R french import says exactly that on the v5. But on Yamaha database it says RE. It's not electric start, I believe the E means it's a European model which were different in a few ways.
    E
    E
    erion
    @markus-w yeah as that guy said i checked it the servo has 3 wires so it means it should be 1985 to 1995 maybe its a 93 or 94
    • E erion
      @erion 4DK was manufactured in 1994 for sale in Europe.
      E 1 Reply Last reply
        E
        E
        erion
        @markus-w if its 94 do you know if i can derestrict it somehow without having to cut the exhaust or having to buy a new one
        • E erion
          @erion don't know much else about this year to be honest only some of the older European ones has a little washer type thing spot welded into the exhaust at the header to close it up and restrict it. Remove the exhaust and you'll see it if it's there.
            E
            E
            erion
            @markus-w now the bike is fucked i got the carb cleaned cus it wouldn't run i rode it yesterday now it wont start , its being a pain in the a** bike
              @erion Bro you need to chill 🤣 These bikes are incredibly simple. The fact of the matter to me seems like you are accepting a botched repair rather than taking the time to do things properly.
              Tapping up the ignition switch, and God knows what other botches you're doing, is going to bite you in the backside big time. If that wire comes loose on a ride out you're going to be stuck in the middle of nowhere with a brick of a bike.
              Juat relax and take the time to do the job properly and it'll pay dividends later on.
                E
                E
                erion
                wrote on last edited by erion
                #34
                @Calum im actually not doing much cus the bike was in perfect condition i just wanted the key to be fixed and ill get the cables for the speedo and rpm counter and thats it but i cant seem to find what the problem is the bike turns over time after time and runs like 1-2 seconds and turns of
                  Sounds like an ignition problem to, presumably it was working before you messed about with the ignition?
                    E
                    E
                    erion
                    @Calum no i installed the ignition yesterday afternoon and took it for a ride it was good but i had the same problem a week ago and i thought it was carb related so i took the carb out and took it for cleaning yesterday i put the carb back in on the morning and i rode it like 2 hours it was just fine but now its doing the same thing it did before a week
                    • E erion
                      E
                      E
                      erion
                      @erion it turns over if it was resting it runs 1-2 seconds and turns off but after that if i keep kicking it over it won't start
                        Still sounds like an ignition issue🤣
                        I had this when I mistakenly bought a cheap chinese "Racing" coil. The bike would ride fine for a while, but then would start misfiring and running awful. Since I did a nut and bolt rebuild on the bike, I didn't think it was the coil since everything was new on it, but as time wore on I decided to revisit the issue. A brand new Genuine coil later and the bike was back to running sweet again.
                        I run a similar "Racing" coil on my RS...need to swap that out at some point.
                        If you're comfortable that the bike is being fueled properly, then I'd be inclined to look at the ignition as you next port of call.
                        Had a similar issue on a 2001 DTR, where it would only start if you kicked it over whilst turning the ignition from "Off" to "On".
                        It was the side stand switch on that particular instance, and it was looped out and this was the only way to get the bike running.
                          E
                          E
                          erion
                          @Calum i bought the key from amazon its not chinese but idk im kinda lost
                            @erion Key? Or ignition barrel.
                            My bike was stolen in 2010 and I replaced the ignition barrel with a Wemoto one. It's not bad, but it isn't great either. About a year later the whole ignition assembly crumbled in my hand and I've had to hand solder all new cables onto it.
                            E 3 Replies Last reply
                              E
                              E
                              erion
                              @Calum no the key thing wich you turn the bike kn and off
                                E
                                E
                                erion
                                @Calum how do i post videos and pics here ??
                                  E
                                  E
                                  erion
                                  @Calum https://imgur.com/a/sTDj42S this is the key i replaced
                                  • E erion
                                    @erion
                                    Yeah, that’s a cheap shit ignition barrel and key! It could well be your problem…
                                    Try drawing the carb, just to make sure the bowl is filling with petrol…
                                    Did you put fresh petrol in?…
                                      @SpookDog The thing about the ignition barrel, is it's literally just a switch with no circuitry so it shouldn't matter too much. It doesn't look the best mind you.
                                      The problem is @erion We're trying to remotely diagnose a bike with little to no information. Only you know what modifications your bike has and we're really making wild guess based off the little information that you have presented us with.
                                      What we could end up doing, is focusing on the ignition switch, as it's the only thing you've really mentioned, and this could be a red heron. Ultimately wasting your time and ours...
                                        E
                                        E
                                        erion
                                        @Calum im sorry if im wasting your time , but as far as i know the bike doesn't have any modifications its bone stock and im just trying to get it start up again so i was looking for some advice on where to look at first or what the problem could be related to
                                        • E erion
                                          E
                                          E
                                          erion
                                          @erion if its ignition problem where should i start checking
