  4. 4BL flywheel removal
6 Posts 4 Posters 1.1k Views 1 Watching
  • R Offline
    R Offline
    rubberfingers
    Hi I need to split the cases on my 4bl engine as either my big end or side bearings have gone. How do you get of the nut and then pull off the flywheel - its different from my other bikes with the usual centre screw puller?
    thanks a lot
    https://ibb.co/NyJFchD
    2 Strokes
    RD500 TDR250 TZR250 2MA TZR250 3MA DT125RE DT125R TS125
    4 Strokes
    YZF600R XS750 FZ1
    • R rubberfingers
      thanks a lot
      @rubberfingers I think you need one of these:
      https://www.machinemart.co.uk/p/clarke-cht698-46-piece-harmonic-balance-puller/
      • R Offline
        R Offline
        rubberfingers
        Thanks any idea about how to get the nut off first? Is it am impact gun job?
        2 Strokes
        4 Strokes
        YZF600R XS750 FZ1
          You can get someone to sit on the bike and put the rear brake on and that can be used to undo the nut.
          Or you can whip the cylinder off and place two pieces of wood on the crankcases and run a piece of metal through the small eye and use that to lock off the crankshaft.
          • R rubberfingers
            @rubberfingers What @Calum said, or Lidl are selling cordless 20V impact guns from today which are as good as a branded one costing three times as much. Might be worth it if you've got to undo a few other bits to split the crankcases:
            https://www.lidl.co.uk/p/parkside-20v-cordless-vehicle-impact-wrench/p10012652
            • R rubberfingers
              First gear, back brake on. I use a half inch socket with a slide bar, apply pressure to take up the ‘slack’ then a sharp tap with a rubber mallet usually does it…
