  3. Wheels
  4. Tip for fitting rear wheel bearings
6 Posts 5 Posters 1.6k Views
  • S Offline
    If like me you don’t have a ‘wheeler dealers’ workshop fitting rear bearings can be a bear 🐻 The outer edge is so thin even a well fitted socket can slip and damage the seal on the bearings. My solution is to use the tightening ring fitted to an angle grinder (with a socket on top)…
    Make sure to sticky out side is up so you don’t damage the inner of the bearing.
    Then use a socket on top as usual. A little bit of heat helps 😜 …
      Nice tip! I must admit, I have always had bearings replaced by people with a press.
        @SpookDog Yes pretty cool hack, doesn't matter what you use as long as it keeps the impact away from the inner race and doesn't deform the seal 👍
        • MadGyverM Offline
          MadGyverM Offline
          @SpookDog I always keep old bearings for use at this kind of jobs.
          • MadGyverM MadGyver
            @MadGyver
            I do this as well, it’s just that the outer race on these is so thin that the slightest slip buggers up the rubber seal.
            I learnt this the hard way 😐
            • Stevie WonderS Offline
              Stevie Wonder
              I’ve always froze my bearings heated up the hub greased everything up then gave a bit of gentle persuasion, never had any problems the couple of times I’ve done it but that’s a pretty handy trick
