  4. Dt125r/yz sm
Dt125r/yz sm
36 Posts 6 Posters 27.7k Views 1 Watching
    Sick. How are you going to mount them.
    I run twin rads on my dt. The thing with the YZ ones are the mounting it.
    Defo worth doing. So long as you don't cool it down too much!
    • C
      C
      chalkey46
      Going to fabricate new mounts on the frame I think that going to be the easiest way only bought them as the 170 runs slightly hotter than the original
      DARE TO BE DIFFERENT! !
        Actually the 170 should run cooler mate. If it's running hotter then it is because the fueling is off. The 170 runs a Nikasil plated barrel which will dissipate the heat better than a steel liner.
        Double check the fueling and if that's fine then lower the spark plug grade.
        In this weather the engine should run spot on. It really would only be an issue in peak summer.
        • C
          C
          chalkey46
          Ah I've not tried the 170 yet as Ive been waiting on other parts was only going on other people's experience with the barrel so I personally have no idea what temp it will run yet I've got an 8,9 and a 10 plug to see what's best and numerous amounts of pilot and main jets and 3 different needles just stocking up haha
          • C
            C
            chalkey46
            wrote on last edited by chalkey46
            #23
            Quick video of first start earlier http://s572.photobucket.com/user/r1cky_01/media/Mobile Uploads/20151116_100648_zps9qsflm9n.mp4.html
            But first run on the road didn't go as planned low revs up to 1/2 throttle it's brilliant but after that it's a spluttery mess so now it's time to get the jetting / needle ect set right
            • C
              C
              chalkey46
              Had a nice ride out yesterday evening to try and sort out some bugs and got the bike plastered at the same time http://i572.photobucket.com/albums/ss167/r1cky_01/20151118_162852_zps2llmgs8f.jpg
              http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1447962090072_zpsmtnaopto.jpg
              But I can confirm I can't wait for it to be fully ran in as it's brilliant as it is now
                That looks Amazing. That exhaust looks the tits!
                • C
                  C
                  chalkey46
                  Cheers mate sounds amazing
                  • C
                    C
                    chalkey46
                    http://i572.photobucket.com/albums/ss167/r1cky_01/IMG_20151120_150531_zpsflliyxly.jpg
                    http://i572.photobucket.com/albums/ss167/r1cky_01/20151120_150151_zpsb6hapmxd.jpg
                      Looks bloody grand my friend. You have really done a superb job that you can be proud of.
                      Can you do me a favour though...don't get her pinched! Keep it well locked up!
                      • C
                        C
                        chalkey46
                        Haha cheers mate she is locked up tight at night 😉
                        • C
                          C
                          chalkey46
                          Well 300 miles in and I ended up with a dred full knocking noise thinking the worst I stripped it down to find out it was a faulty clutch basket 😡 but new clutch and new basket fitted and she is back to normal, but my wheels are taking a right battering with all this horrible weather so need to source some good aluminium protection any one got any recommendations ?? 😞
                            Inlet manifold is sick!
                            • C
                              C
                              chalkey46
                              Well just realised it's been 8 months since the old girl last seen the light think it might be time to dig her out and wipe off the cobwebs 😂😂
                              • C chalkey46
                                @chalkey46 She looks a sweet ride dude - Good job! Are the forks and swing arm off a YZ then I take it???
                                C 1 Reply Last reply
                                  How do you like the 170 kit? Did you sort out the jetting?
                                    C
                                    C
                                    chalkey46
                                    @CYBER-NINJA yes mate forks and swing arm are off a yz
                                    • J Jens Eskildsen
                                      C
                                      C
                                      chalkey46
                                      #36
                                      @Jens-Eskildsen 170 kit is brilliant with all the extra bits like the carb, exhaust, boysen reeds ect just need to buy a few gearing setups as I'm currently topping out 6th 😕
