  4. '99 DT125R "OEM+"
'99 DT125R "OEM+"
37 Posts 8 Posters 17.8k Views 2 Watching
    @Burridge OEM+ Indeed
    BurridgeB
    BurridgeB
    Burridge
    @Calum Yes sir 😜
    • BurridgeB
      BurridgeB
      Burridge
      Had a good days riding today, it's ran on top form as usual all day until being about 10 miles from home, whizzing along at 70 when suddenly.... BWAAAAAAAH
      power dropped completely and would barely get to 20mph. I thought the header had come off or even worse the pipe had split.
      Pulled over and heard it coming from behind the side panel, the pipe was fine thankfully, pulled the panel off and all looked okay, until I put my fingers around the back of the rubber and turned it round
      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpshoxxbnhq.jpeg
      I carried on for a bit but was getting dirty looks and going extremely slow so I pulled over again to see if I could do something with it. Ended up wrapping my glove around it with the Velcro then putting the rest of it up against the pipe, it worked thankfully, got to 50 which got me home okay. Shame about my trusty old richa glove, fully toasted.
      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsejtvpeg6.jpeg
      So now I've got to figure out what to do with this. As you can see the chamber is ridiculously out of line with the link pipe of the dep, I'd bodged it on originally hence why it went pop, just wish the Romeu pipe has a better fit.
      • MightymanM
        Did you tell Romeu that the pipe wasn't a good fit? I thought he would have it all down to a T by now but it seems not. Can't be selling badly fitting pipes to everyone though.. Tell him your not happy. In the mean time you'll have to manage with another bodge if you need use of the bike.
        BurridgeB 1 Reply Last reply
        • MightymanM Mightyman
          BurridgeB
          BurridgeB
          Burridge
          @MIGHTYMAN Nope:( in hindsight I should have done to be honest, but it's been a good few months now since I got it's it's abit late really. I'm gonna look at flexible metal piping to bridge the gap or something like.
          Apart from the fitting issue with that and the bracket that bolts to the frame being way out in happy with the pipe, I know what you're saying though, I just guess that he's using a different model dt to make the pipes on, and metal distorts when it's welded too?
          MightymanM 1 Reply Last reply
          • BurridgeB Burridge
            @Burridge It does distort to a certain degree, but I would be surprised if he wasn't accounting for that.
              BurridgeB
              BurridgeB
              Burridge
              @MIGHTYMAN that's true, he clearly knows what he's doing when it comes to welding, just can't think why it would fit so badly
              • AndyYamA
                AndyYamA
                AndyYam
                Personally I'd contact him and let him know. Even if its not a moan but just to point it out. He may offer you a replacement or may not but atleast he can know what he's done wrong so no one else gets the same issue in the future.
                • ConnorDTRC
                  ConnorDTRC
                  ConnorDTR
                  wrote on last edited by ConnorDTR
                  #35
                  I've had the same thing happen with my romeu pipe, i've resorted to using a piece of radiator hose and two jubilee clips and it seems to be holding. Also out of interest, what tyres are you running?
                  • ConnorDTRC ConnorDTR
                    BurridgeB
                    BurridgeB
                    Burridge
                    @ConnorDTR do you have a picture matey? I'm still debating what to do to it but I'll probably do something like that. And I think they're called Bridgestone trail wings or trail riders or something, the standard tyres that come with the bike from new:)
                      On another note, my pipe is lovely 😄
                      Sorry haf to be said
