  4. Head gasket
Head gasket
17 Posts 2 Posters 861 Views
  • P
    P
    Pilot_LC
    Hello
    So i have a problem my cylinder head is slightly scratched and a little bent so the regular metal gasket doesnt seal it (coolant gets in the bore) but i found a solution a athena composite head gasket that nicely squished the head together but it was time for a rebuild and i had to tear it down tried to fit a normal headgasket but that didnt hold (found out the hard way) so im in need of the thicker athena composite headgasket but i cant find it anywhere and i cant remember what store i bought it from.
    Thanks for any help!
    • P
      P
      Pilot_LC
      forgot to add the part where i ask for help if anyone knows where to get one 🙂
        Several options
        Can you not skim the head and barrel and remove the imperfections, then space the barrel with two bottom gaskets?
        Can you not get yourself a reusable copper head gaaket. They used to be all the range a few years ago.
        You could always contact an engineering firm like PJME to machine an o-ring into your setup to bypass the imperfections.
        https://www.pjme.co.uk/acatalog/Yamaha-DT125R-Head-Gasket-O-Ring--5866.html
        • P
          P
          Pilot_LC
          i sadly cant skim the head because i dont have the machines myself and in my country its a rather ellusive and expensive thing
          where could i find the copper gasket and will it make the compression go down?
          and about the o-ring can i let the machining be done at a lathe here by the dimensions on the pjme site and if i switch to o-ring its just the o-ring or is it the o-ring+headgasket
          PS sorry for my spelling english isnt my main language
          and thanks for the help!
          • P
            P
            Pilot_LC
            okay found a solution that i completly forgot a large piece of glass + fine wet sandpaper and it should to the trick the cylinder itself is completly fine
            • P Pilot_LC
              @Pilot_LC Yeah, I wrote a blog on doing it here: https://dt125r.co.uk/post/23
              It's only a gentle skim, it won't cure completely warped heads.
              Be sure to the deck of the barrel too.
              • P
                P
                Pilot_LC
                did the process the original gap was about 0,1mm got it down to zero put it together with a new standard gasket and it holds! also it has more compression now then ever before and i can feel that it has more power
                  @pilot_lc That's amazing! Fingers crossed 🤞 that's it now then.
                  • P
                    P
                    Pilot_LC
                    yeah so it ran for 600km with no problem then started randomly getting really hot and spewing coolant out just like before so now i had to bring it home with a trailer (again) and ill disassemble the head tomorrow to see what the problem is now.
                    • P Pilot_LC
                      @Pilot_LC 600km, are you sure you used a genuine head gasket and not the cheap white ones.
                      And it was definitely fitted in the right orientation.
                      P 1 Reply Last reply
                        P
                        P
                        Pilot_LC
                        @Calum yes i used a athena head gasket and its 100% in the right orientation.
                        also what saams to be wierd is that its spewing out coolant from the overflow tank but there is no pressure in the system when you remove the radiator cap even when its really hot. It also doesn't seem to be burning coolant
                          As I say, one issue is the radiator cap spring looses tension so try replacing that.
                          I just use a cheap Chinese one on my DTR with a temperature sensor in it and it's been sound.
                          Another problem could be the thermostat as given up, maybe it's locked closed so it's not regulating temperature correctly.
                          • P
                            P
                            Pilot_LC
                            okay but how would those explain the significant loss of coolant through the overflow tank?
                            • P Pilot_LC
                              @Pilot_LC Ideal Gas Law - PV=nRT. Pressure of a system is directly proportional to the temperature of that system. So if the thermostat is stuck, then the temperature goes up and therefore the pressure. The radiator cap bleeds this pressure to the overflow tank. Ergo explains loss of coolant.
                              • P
                                P
                                Pilot_LC
                                okay but i took it apart anyway and yes it was the headgasket again dont know how but now the cylinder is also warped maybe it was before but i didnt notice it anyway i dont know head and cylinder are both resurfaced now and ill get a new gasket tomorrow will also put a bit of "engine glue" idk how to translate it but hopefully it will now finally hold
                                  If you keep having problems then it might be worth sending the barrel off to someone lile PJME to have the O-Ring conversion...
                                    P
                                    P
                                    Pilot_LC
                                    @Calum so i got it together it ran well when i started it in the garage but when i went for a ride when riding it doesnt have power and doesnt rev over 7k rpm when in neutral doesnt go over 9k but powervalve is working and no weird noises from the engine im completly clueless
