Head gasket
Hello
So i have a problem my cylinder head is slightly scratched and a little bent so the regular metal gasket doesnt seal it (coolant gets in the bore) but i found a solution a athena composite head gasket that nicely squished the head together but it was time for a rebuild and i had to tear it down tried to fit a normal headgasket but that didnt hold (found out the hard way) so im in need of the thicker athena composite headgasket but i cant find it anywhere and i cant remember what store i bought it from.Thanks for any help!
Several options
Can you not skim the head and barrel and remove the imperfections, then space the barrel with two bottom gaskets?
Can you not get yourself a reusable copper head gaaket. They used to be all the range a few years ago.
You could always contact an engineering firm like PJME to machine an o-ring into your setup to bypass the imperfections.
https://www.pjme.co.uk/acatalog/Yamaha-DT125R-Head-Gasket-O-Ring--5866.html
i sadly cant skim the head because i dont have the machines myself and in my country its a rather ellusive and expensive thing
where could i find the copper gasket and will it make the compression go down?
and about the o-ring can i let the machining be done at a lathe here by the dimensions on the pjme site and if i switch to o-ring its just the o-ring or is it the o-ring+headgasketPS sorry for my spelling english isnt my main language
and thanks for the help! -
okay found a solution that i completly forgot a large piece of glass + fine wet sandpaper and it should to the trick the cylinder itself is completly fine
