  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 38.9k Views 2 Watching
  • tdr125gregT Offline
    tdr125gregT Offline
    tdr125greg
    wrote on last edited by tdr125greg
    Evening all,
    upon removing the end can I realised all the packing was gone,so decided to go ahead and order some dep exhaust wadding (not the loose kind) whilst I wait for it to be delivered I thought I'd give the can a wee clean up
    Check out the results
    • tdr125gregT tdr125greg
      Evening all,
      NINJAN Offline
      NINJAN Offline
      @tdr125greg Very shiney!!! :thumbsup:
        Looks good Bud :D
        • MightymanM Offline
          MightymanM Offline
          Not sure if your bothered about losing the sticker, but you can get a new one from DEP if you contact them directly.
          tdr125gregT 1 Reply Last reply
          • MightymanM Mightyman
            tdr125gregT Offline
            tdr125gregT Offline
            tdr125greg
            @Mightyman. I did manage to find heatproof Dep pipes decal to go back on
            Cheers for the knowledge man!!!.
              tdr125gregT Offline
              tdr125greg
              Hello forum,
              I have had a very productive day today.
              I've stripped the powervalve down seeing as the seal and o-ring were shot to bits and the valve itself,caked in carbon.
              I have now received all the correct O-ring and seals needed to complete the refurbishment courtesy of PJME
              Here are some pictures
                Hello forum,
                @tdr125greg If you get some wet and dry paper, you can smooth off the valve and grind out the lettering.
                This will allow the exhaust gases to flow better into the expansion chamber, AND GAIN YOU LIKE 0.000001 BHP.
                But it's free power so...
                  tdr125gregT Offline
                  tdr125gregT Offline
                  tdr125greg
                  @Calum said in TDR125 4GW:
                  Free power is free power my friend
                  I will get right on that.
                  What's your thoughts on getting my 4FU ported??
                  I mean in terms of gains
                  I've read up that the guy for that is stan Stephens but I'm new to this so fishing for knowledge.
                  Cheers.
                    Cheers.
                    @tdr125greg I doubt Stan will do that barrel for you.
                    From when I looked many moons ago, he only works on classics, and he is probably getting on a bit.
                    I had porting work carried out by Mick Abbey.
                    But porting work alone won't do very much. And it's all about the bigger picture.
                    The 4FU heads are restrictive. Getting a 3MB, with a domed piston, increased jetting, Ignition system, Pipe and induction shall see you great cans.
                    But doing one without the other will bring more drawbacks than good.
                    If you want to start on one thing, I would do the ignition system.
                    Then I'd build a separate engine from the ground up, and transplant it when it was finished with the supporting mods.
                    But that's expensive and takes time.
                    Best way though
                      tdr125gregT Offline
                      tdr125greg
                      You speak of ignition upgrades as a first port of call, are you talking about changing the cdi? If so what are my options.? Aftermarket or OEM.
                      With regards to the engine your absolutely bang on about building a separate one from the ground up, like you say it will take a lot of money and time, but the theory behind it makes more sense. Especially now I have a spanking new flat top mitaka piston for the 4FU barrel I mas aswell run it as is for now.
                        @tdr125greg Yeah, I don't know what your options are. But I used Zeeltronic Ignition System. I will be using them again for my new build.
                        By far the single one component that I noticed.
                        Yeah, I personally, would have ran a domed piston, higher compression. Usually, Higher Compression = Higher Peak Power.
                        Usually.
                        It's not a strict rule, and it does add wear, but if you tune it right, you can generally make bigger gains upping the C/R
                          tdr125gregT Offline
                          tdr125greg
                          So you are telling me I could have ran a dome top piston in my 4FU nikasil plated barrel.
                          The only reason I ask is because I was told I could only run a 56mm flat top in my cylinder by pjme?.
                            @tdr125greg PJME know what they are doing.
                            You can run whatever you want.
                            But you would want to have the combustion chamber reworked.
                            If you have a 4FU head then you should notice a restrictive combustion ring around the chamber.
                            For £30 odd quid Mick Abbey will grind that out and put a nice squish band there. 80% of the power of a two stroke comes from the head. So getting this part right is crucial.
                            Telling your tuner that you are going to run a domed piston, will allow them to correct the squish band.
                            My advice would again be do this with another, specifically designed, engine.
                            The Rotax 122 engine that I am building comes stock with a flat top piston. But I intead to rework the head and run a domed.
                            Running at higher compression puts you at risk from detonation. This is an engine killer. To avoid this you need to retard the ignition, or up the fueling.
                            So it's not always clear what the best path is.
                            I have had a few 4FU's but never saw a build through to the finish.
                              tdr125gregT Offline
                              tdr125greg
                              Thankyou calum I will take everything into consideration and make a path for myself. I solidly agree on a second engine but for now I'd rather get the current engine running smoothly and swap the front end.
                              When I have a nice set up I will give it the beating heart it deserves.
                              • DartyD Offline
                                DartyD Offline
                                wrote on last edited by Darty
                                You cant run a Domed piston in a 4FU? Wouldn't it hit the head? I've got a 4FU head, and they never came with combustion rings, only 2RK/3BN's?
                                A Flat top piston doesn't interfere with your transfer ports as much as a Domed piston, so you can take advantage of scavenging with correct porting and a proper exhaust,
                                The 4FU seems to have larger volume crankcase transfers than a 3MB?
                                I'm running .6mm squish and a 134cc heavy Top end porting on a 3MB barrel. Looking at 25bhp maximum on 97octane. Most power will be made by the cylinder head itself, the barrel is aiding it along.
                                No doubt moving torque, and not that much more of it to very high RPM, will only make you come to be very efficient at going up and down the gearbox quicker to keep the thing in the right rev range.
                                Depends what you want from it, i'd say get the ports cleaned up, but don't change the Port timings at all, and just run her standard. These engines don't make power at all like a Rotax!
                                I've been bulding a race setup for mine for a while now, yet to know proper results tho
                                  @Darty Here was my 4FU
                                  As said I don't know natively if it supports domed, but certainly if you removed that ring and reworked the head
                                  DartyD 1 Reply Last reply
                                    tdr125gregT Offline
                                    tdr125greg
                                      DartyD Offline
                                      DartyD Offline
                                      https://c1.staticflickr.com/1/440/30800032804_7635f2db5c_c.jpg
                                      https://c1.staticflickr.com/1/431/31525983671_ea3ee375cf_c.jpg
                                      Mine might have been modified, the crown seems very different. No signs of a heavy skim. it's a closer match to a P' stamped head but with a squish height less than .5, A domed piston would crash into it at that point.
                                      A base gasket would help, but then you begin to change port timings, not good. I gave up on a 4FU, Nicasil is expensive if you lunch the bore up.
                                        Sorry my bad.
                                        I have had a few 4FU's and they have all been this way.
                                        Which is why I said it...
                                          tdr125gregT Offline
                                          tdr125greg
                                          Another purchase sees the trail tech vapor and indicator dash added to PROJECT TDR.
                                          I purchased the kit on eBay from Moore speed racing for £150 all in which I thought was a good deal. 🔥🔥
                                          Any of you guys run the vapor on a tdr/Dt before?
                                          0_1488293323206_DSC_0017_1.JPG 😀
