  4. Starter issue
Starter issue
7 Posts 4 Posters 3.0k Views
  • ZrakoZ Offline
    ZrakoZ Offline
    Zrako
    Help please. My starter messing up with me , sometimes it works but it went worse and now it wont start the bike at all. Checked the starter and looks ok. What do you think ? link text
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • MightymanM Offline
      MightymanM Offline
      Sounds like it might not be spinning the starter clutch at all. If you have only checked by looking underneath the engine, try taking off the flywheel cover on the left hand side of the engine (no oil this side) and check if the starter motor is actually spinning the flywheel. Should be around 5 or so bolts, then you will need to pull with a bit of force to overcome the magnetic force. Then try the starter button again and if you still don't see the problem, get another video of the starter spinning inside and we'll check it out.
      • ZrakoZ Offline
        ZrakoZ Offline
        Zrako
        Decided to get back to my starter issue after I've been bump starting it few weeks 😁 tried to pull the rotor from shaft but no luck. Made a special puller plate from 3.mm steel plate but bent it badly haha. Gave up , lost so much hair trying to get to the starter clutch. Sprayed horrible amounts of wd40 on it as well. Gave up. Put the stator in and mirracle happened . It working haha.
          MightymanM Offline
          Sorry mate I don't understand fully... Was this issue solved by you removing the flywheel and then putting it back on?
          ZrakoZ 1 Reply Last reply
          • MightymanM Mightyman
            ZrakoZ Offline
            ZrakoZ Offline
            Zrako
            @Mightyman no , the flywheel is stuck there and I was unable to take it off. Basically I did nothing and I dont know what happened.
            • tunertomT Offline
              tunertomT Offline
              tunertom
              order the proper puller. worth its value 10 times over. saves damaging things trying to get it off.
                Also the pulley can be used for loads of things as well. Lol I have used it for the car and all sorts lol.
