Taillight/Brake light issues
I changed my taillight from an LED to a bulb unit as the LEDs had mostly gone. All three wires are correct (to the best of my knowledge) got the taillight working ok when running, but no brake light at all on either switch. Was working when the led was on and I simply cut the three existing wires to the led and joined the three from the bulb in its place. Bulb is ok. (Tried reconnecting the led but not working now either)
Any ideas? Cheers
So neither bulb is working?
If you cut the 3 wires at the same time when power was applied chances are you've blown a fuse. I'd check them first
have you tested for power when the brakes are aplied as you should have power if you dont then you will have to trace back to each switch to see were the brake in the wire is but seems strange was working ok before
I used one of these that I found on uk eBay
http://doctorenduro.com/index.php?main_page=top_mount_led_tail_brake_light
Hang on so the old light is working?
This is going to make life SOOOO MUCH EASIER....
http://www.ebay.co.uk/itm/New-Accurate-DIGITAL-LCD-VOLTMETER-MULTIMETER-WIDE-RANGE-TESTER-AMMETER-AC-DC-UK-/191921991924?hash=item2caf7130f4:g:tP4AAOSwcLxYEw1OAnd for the money.
Got it all sorted cheers lads, turns out the loom extension had been chopped further up, and the connecting block was filthy. I replaced the cables, cleaned it and wired it up. Boom all working again
@CallumJ94 Unmolested looms are a rarity these days!!!
