  3. Exhaust
  4. is a standard dt tail pipe restricted
10 Posts 6 Posters 3.4k Views
  • S Offline
    scotty
    As title really doe anyone know if the DT tail pipe restrictive, if so can they be unrestricted as I would like to keep the standard pipe,thanks peeps
    MiniaM 1 Reply Last reply
    • S scotty
      MiniaM Offline
      MiniaM Offline
      Minia
      @scotty As far as I know it isn't, you might climb a couple horsepower by getting a DEP system but I've found no problem sticking with stock.
      • MiniaM Minia
        scotty
        @Minia cheers mate,I've got a big one expansion chamber but I want to keep the original look hence using the standard pipe 👍
        smudge1995S 1 Reply Last reply
        • S scotty
          smudge1995S Offline
          smudge1995S Offline
          smudge1995
          @scotty I've just changed my exhaust on my dtr to a dep back pipe as I was told the standard pipes have washers welded into them
          • smudge1995S smudge1995
            scotty
            @smudge1995 said in is a standard dt tail pipe restricted:
            Did you notice any difference ? Smudge
            smudge1995S NINJAN 2 Replies Last reply
            • S scotty
              smudge1995S Offline
              smudge1995S Offline
              smudge1995
              @scotty not a huge amount but it don't sound like it's all choked up now the sound is so much crisper... to me it sounded blocked with the restricted one
              • S scotty
                NINJAN Offline
                NINJAN Offline
                @scotty I would be surprised if there was not some sort of restriction in the stock pipe. Some wadding at the very least? Hence why performance pipes work as they remove any restriction to the air flow. Plus normally aspirated engine's require some back pressure too keep the system balanced. The front pipe definitely has some wadding and restriction in there, so it would make sense that the tail pipe had some as well.
                • F Offline
                  F Offline
                  Stock pipe has washers welded inside on earlier models, the newer ones have a cat which is very restrictive. I've never heard of any restrictions in the rear pipe, they do however require repacking periodically so fitting a new one would make a difference
                  • S Offline
                    scotty
                    I might cut my standard pipe open and have a look
                      As a general rule: 2 strokes are restricked in the header/downpipe, and 4 strokes in the silencer/tail pipe.
