  4. Dt125r 2003 electrical fault
5 Posts 5 Posters 1.7k Views
  • G Offline
    G Offline
    gazzy555
    I just bought my first dtr125 2003 model. My side light and speedo light turns on when i press my brakes after fitting all new bulbs and a new battery. Any ideas what could be the fault? Cheers.
    • MightymanM Offline
      MightymanM Offline
      I think this can occur if you have put a bulb in the wrong way round. You didn't use LEDs did you?
      • G gazzy555
        NINJAN Offline
        NINJAN Offline
        @gazzy555 Are any of the new bulb's a higher wattage? As that may cause the problem. Also check all of the connectors to each bulb, if any are corroded then that would also cause this issue.
        • vtrtomukV Offline
          vtrtomukV Offline
          vtrtomuk
          Most likely a wiring fault, have a look behind the headlight cowl and make sure everything's in the right place.
          as you've just brought it i assume you dont know the history of the bike ? anyone could have messed with it
          have you got a Haynes manual?
          is this a bright orange supermoto by any chance ?
          Current Projects - 2003 DTR
          Have put 12 DTRs back on the road since 2010
          Owner of 4 bikes - Honda VTR1000F 1998 - Honda CBR 600 F3 1998 - Sinnis Apachie 125 2015 - Yamaha DT 125R 2003
          • S Offline
            scrimsmustang
            Its a bad earth connection
