  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 47.9k Views 2 Watching
  • F
    No problems with rev counter on mine, it's wired directly to the coil
      @finnerz89 Never had any problems with the counter myself.
      On my new build it csn be wired directly to the cdi
      F 1 Reply Last reply
        @Calum is that with the zeeltronic?
          @finnerz89 Yeah I believe it's the green/yellow wire that will pulse when the ignition fires. So no need to wrap the HT lead you can just wire it directly to the CDI.
          I would double check the wiring diagram first mind you.
          tdr125gregT 1 Reply Last reply
            tdr125gregT
            tdr125gregT
            tdr125greg
            @Calum I've been in talks with borut at zeeltronic, and I have decided I will definitely order the cdi and the programmer within the next 2 months. I've seen many varied experiences using the Rev counter but I'm assuming that's down to a bad install as I've also seen the Rev counter work great..
            TDR125 🔥
            Put some respek on it! 😂
            MightymanM 1 Reply Last reply
            • tdr125gregT tdr125greg
              @tdr125greg Yeah don't take my experience as fact, I expected that it wasn't the norm.
              CalumC tdr125gregT 2 Replies Last reply
              • MightymanM Mightyman
                @Mightyman Way back when, When I took my bike license before the law changed, I did it on my DT.
                There is a bit where you must do national speed limit. Guess what? Vapor packed up. Looked down and I was doing 110 MPH I was like WTF! Bike only does 70 lol.
                I have had glitches sure, but the norm is that it is spot on.
                  tdr125gregT
                  tdr125gregT
                  tdr125greg
                  wrote on last edited by tdr125greg
                  #38
                  @Mightyman haha sorry man didn't mean to make it sound like I was roasting you lol..
                  These things happen don't they and I'm sure the way you done it is a method stated in the trail tech manual.
                  I guess Calum's way just picks the pulse up in a more accurate Manor 😀
                  TDR125 🔥
                  • MightymanM
                    No worries @tdr125greg 😎 Would have preffered connecting it up directly but when I specified the bike was an MT-03 they just sent me the kit that was to be fitted around the spark plug wire and told me to do it that way. @Calum that's mad, would have put me right off... I managed to just about do my full test on a YBR 125. It was a bit of a struggle to get it up to speed round the corners in the mod 1 though.
                    • F
                      It's the same cable whether you wrap it around the HT lead or wire it up to your coil. I went with coil as it seemed more reliable and accurate. Had the bike stripped at the time so it was no hassle to do.
                        @finnerz89 Oh right, fair enough. Mine didn't have bare wire exposed on the end so I didn't realise.
                        • tdr125gregT
                          tdr125gregT
                          tdr125greg
                          Nice one lads, so the moral of the story is wire it in and bobs your uncle 😀
                          TDR125 🔥
                            @tdr125greg Well as said I haven't ridden my bike with it wired into the CDI yet, since I haven't ridden my bike for years. But I had it wrapped around the HT leads and never had an issue.
                            In neutral there is a bit of lag between what the engine is doing and what the revs are. To be fair that's to be expected. But this isn't noticeable on the move since the engine isn't accelerating as much.
                            • tdr125gregT
                              tdr125gregT
                              tdr125greg
                              #44
                              And here she is all stripped down,
                              Next thing on the to do list is custom fit the usd forks when they arrive
                              Followed by the fabrication of all necessary brackets etc.
                              Once all the fab work Is done the frame the fork legs and other miscellaneous parts will be off to the powder coaters!!
                              TDR125 🔥
                              • MightymanM
                                Awsome. Haven't seen a fully stripped down bike on here in ages! 😂
                                  tdr125gregT
                                  tdr125gregT
                                  tdr125greg
                                  @Mightyman thanks Bro , to be honest it's quite daunting but at the same time I'm amped.:-D
                                  TDR125 🔥
                                    tdr125gregT
                                    tdr125gregT
                                    tdr125greg
                                    @Calum thankyou dude!!
                                    TDR125 🔥
                                    • tdr125gregT
                                      tdr125gregT
                                      tdr125greg
                                      #48
                                      WE ALL LOVE IT WHEN THE MAIL MAN BRINGS US PARTS!!!!!!!
                                      So today the aprilia MX forks arrived and dude was I happy to see that parcel 😀
                                      I got straight to the task of unpacking and a tedious moment or two later I soon had my grubby paws on the contents.
                                      A few comparisons...
                                      I soon dug out the X front wheel and mocked that together.
                                      didn't Realise the forks where Marzocchi's
                                      I'm made up!
                                      I then mocked the clamps on the frame just for a a wee glimpse.
                                      (so excited I put the legs on the wrong way round Hey Ho) 😂😂😂😂
                                      TDR125 🔥
                                      3
                                        I'm made up!
                                        @tdr125greg Nice beefy upgrade their bro, I was gonna do this conversion on my DT, but at the time I couldn't find a set of MX forks. So I ended up buying a whole bike instead!!! 🙂
                                          Such a great conversion.
                                          Loads of people going down the USD route, worth every penny.
