  3. Top End
  4. Dt200r cylinder
Dt200r cylinder
18 Posts 5 Posters 4.4k Views
  • A Offline
    A Offline
    andrewj1680
    Anyone know if the 3et cylinder from a Dt200r will direct bolt onto a dt125r any help is much appreciated
      Bolts onto the crankcase, but the stroke is out so you need to either get a 200 crank, or retro fit the connecting rod.
      See @Louis-James build thread.
      Jeez Louis I couldn't find you. I was searching The Only Way is Yamaha LMAO!
      A 1 Reply Last reply
        A Offline
        A Offline
        andrewj1680
        @Calum ideal thanks calum Will look into getting the crank too then 👍
          Definitely read his build.
          What you actually want is the 3xp00 engine as it is far superior
          • S Offline
            scrimsmustang
            Fitting a 200 rod to a 125 crank wont work, you need the 200 crank in 200 cases or you need 125 cases machined to fit the 200 crank.
            3
            • A Offline
              A Offline
              andrewj1680
              I abandoned this idea as I bought a wr200 3exp whole bike instead and rebuilding as a second bike gonna do a complete rebuild on everything thanks for the advice tho the dt is gonna stay almost original now other than the zeeltronic ignition mick abbey tuning head and barrel mod and a complete dep exhaust but have all original parts to go back on if I do decide to drop it back to a standard bike which is hard to find now
              • A andrewj1680
                @andrewj1680 @scrimsmustang is an absolute gold mine for knowledge! I hope all is well bud!
                • S scrimsmustang
                  NINJAN Offline
                  NINJAN Offline
                  @scrimsmustang Is that the real scrimsey??? LOL 😉
                    A Offline
                    A Offline
                    andrewj1680
                    @Calum totally agree, totally different bike now you can really feel how restricted that head really was, I had the bike jetted before the cylinder went away and I've had to back the jets off slightly I'm guessing it's where the flow is better now
                    • Louis-DT-WRL Offline
                      The cylinder legs won't fit, cases need boring out for crank and cylinder legs, transfer ports enlarging, and the correct crank. See my thread 🙂
                      • Louis-DT-WRL Louis-DT-WR
                        A Offline
                        A Offline
                        andrewj1680
                        @Louis-James thanks bud I've decided to keep the dt as a 125 and rebuilding a wr200 instead, stunning bike you have there takes awhile to get through your build spec too lol can I ask what your v force reeds are meant for i can't seem to find them for the wr200 👍
                          Thanks a lot, they're for a YAMAHA Blaster 200
                            A Offline
                            A Offline
                            andrewj1680
                            @Louis-James you alright mate just wondering what crank you ended up using and where did you get it from? I've stripped my engine down and personally don't think it needs it but I'd rather do it properly first time around, I've searched but seems the only options are the hodrods crank which don't seem to have many good reviews and a rabbit rebuild kit that I can't seem to find much info on at all
                            • A andrewj1680
                              @andrewj1680 I ran it with a Blaster wiseco crank for a while with a modified spacer behind the primary drive gear which made it have less overlap on the clutch, I wasn't happy with it worrying it would damage it, so I bought a new wr200 crank and sold the wiseco one 🙂
                                A Offline
                                A Offline
                                andrewj1680
                                @Louis-James think thats how I'll go about it, when I spoke to fowlers they were suggesting I had to buy the crank in 2 halves is this right? Your don't have a part number do you bud? Seem to be getting a lot of ideas from your build the bigger carb reeds for example it's nice to know it's already been done
                                  A whole crank. Fowlers have it listed on their website as a single item. There are rs250 carbs on eBay, mine was £50 in perfect working order. I can find a part number if you can't
                                    3XP1140000 says it replaces 2TV-11400-00
                                    Fowlers list this also for the Dt200r which is strange because apparently the wr200/dt200wr is meant to have 0.7mm longer stroke.
                                      A Offline
                                      A Offline
                                      andrewj1680
                                      @Louis-James thanks mate appreciate it I'll get on it tomorrow first thing, there is nothing wrong with the crank in it but knowing my luck they will have discontinued it by the time I do need it lol always the way ain't it
