  3. DTX
  4. Dtx Project Codename Moneypit
77 Posts 13 Posters 35.6k Views 2 Watching
    @Zrako Sourcing some good quality used parts will save you some cash along this journey for-sure!!! ')
    ZrakoZ
    ZrakoZ
    Zrako
    @CYBER-NINJA eBay all the way mate , tried gumtree as well but in NI is not as much bike breakers as in mainland
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • ZrakoZ
      ZrakoZ
      Zrako
      What do you guys think about quick action throttles? Found it on ebay randomly chasing parts.
        I know nev fitted one to his dtr. But I know his would have been a nice one.
        It is not about us, it's about your project.
        ZrakoZ 1 Reply Last reply
          I run a YZ 250 throttle with a billet alloy throttle tube, so much nicer...
          Recomended.
          tdr125gregT 1 Reply Last reply
          3
            ZrakoZ
            ZrakoZ
            Zrako
            @Calum I was mainly asking about it because I am never heard of it and if anyone fitted one on his dt , if its any good and what is the experience like😊
            • ZrakoZ Zrako
              @Zrako Ever ridden a crosser?
              Effectively you are only pulling the throttle a quarter turn before full chat.
              So you lose control of the throttle slider, but you are quicker to go Wipe Open Throttle.
              You would probably want spot on jetting, else risk bogging down.
                ZrakoZ
                ZrakoZ
                Zrako
                @Calum never rided motocross bike ,so with this Im loosing a lot I think , its not really for the cruising and for the traffic as lot of sensitivity will compress in the 1/4 turn ?
                • ZrakoZ Zrako
                  @Zrako It's not really an issue, but the original throttle is there to ease the power on and make it easier to just poot around with traffic for the novice rider. It wouldn't take long before you forgot how it was originally and got used to the quick throttle.
                    Recomended.
                    tdr125gregT
                    tdr125gregT
                    tdr125greg
                    @Darty would model year on the yz throttle matter?
                    TDR125 🔥
                    Put some respek on it! 😂
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      The yz swingarm arrived today . Postman asked me why I am so happy lol.
                      Ehm. The fitment makes me a bit nervous there. Any ideas ?
                      • G
                        G
                        gareth_iowc
                        Yz one is not wide enough. Tried this myself 2 weeks ago and gave up on that idea
                        DT125R 2000
                        DRZ400 2006
                        Golf Mk3 20v Turbo 1996
                        • G gareth_iowc
                          ZrakoZ
                          ZrakoZ
                          Zrako
                          @chalkey46 Sir I need your help ☺
                          @gareth_iowc !
                          YZ Swingarm
                          This Sir did the job mate .
                            Anything is possible. No it's not a direct fit, but if it were then every joey would have done it.
                            The only reason I didn't do it, was because I spent many many nights lining up my supermoto wheels with my current setup, changing the arm, whilst trivial, would have undone all that work.
                            • ZrakoZ
                              ZrakoZ
                              Zrako
                              At first Im spotted the 2 problems I need to deal with : 1st - the linkage fitment is different
                              2nd - the brake bracket .
                              Wondering if the yz bracket will fit my caliper and line up properly with the disc 🤔
                                @Calum Big respect to all Joey's!!! LOL 😉
                                  To do it properly you are going to need to realign the whole geometry of the bike.
                                  With the new swingarm you are going to need the YZ brake carrier. Which will need modifiying to either accept your brake, or use the YZ brakes.
                                  Either way the swingarm needs altering to fit between the frame and the engine.
                                  This will cause the sprocket to be out of alignment with the rear sprocket, which is going to to cause undue stress to the gearbox bearings. This will need correcting by either shimming or machining.
                                  You are then going to find the front and rear wheels are no longer in line. So this will need altering to ensure that the front and rear wheels are inline, and the front and rear sprockets are inline.
                                  If you don't then you will find the bike will have a tendency to crab or to cause excessive damage to the gearbox.
                                  This is why my front wheel is off centre from the forks. This was done to ensure the front and rear wheels line up perfectly, whilst maintaining the correct geometry for the front and rear sprockets.
                                  I'm all for the swingarm conversion, but it sounds like you haven't thought this through enough?
                                  If you're going to do, do it right. Is all I'm going to say.
                                  It's just a case of measuring once, twice three times to be sure. This is the reason why I didn't use the alloy swingarm, AFTER I had already done all of this measuring.
                                  I should have done it all at one time and saved myself the effort of measuring twice.
                                  If any of that is unclear I am happy to go into more detail.
                                    ZrakoZ
                                    ZrakoZ
                                    Zrako
                                    @Calum yeah to be honest Im thought its lot easier than it really is and I havent the yz swingarm in the hand to get the measurements.
                                    Definitely I have only 2 ways of doing this: properly or stock swingarm.
                                    • G
                                      G
                                      gareth_iowc
                                      I'm keeping the stock arm and swapping the wheel hubs over just to keep the project going ATM. I did like the idea of the yz wheel adjustment on the rear as it looks smarter than the dt 1
                                      DT125R 2000
                                      DRZ400 2006
                                      • G gareth_iowc
                                        ZrakoZ
                                        ZrakoZ
                                        Zrako
                                        @gareth_iowc are you on supermoto project as well?
                                          #26
                                          Well I have seen quite a few DTRs with YZ250/WR400 swingarms. Doable.
                                          Custom linkage brackets, fabricated an welded...
                                          Complete YZ/WR rear end,, new chain/ possibly only a 520.
                                          A earlier style YZ/WR shock will only just clear the exhaust, and will need a custom spacer just to fit it into frame shock tower!
                                          This is a proper fabrication job.
                                          This was the very reason a WR200 swingarm was the ONLY choice for me.
