  3. DTX
  4. Dtx Project Codename Moneypit
77 Posts 13 Posters 35.6k Views 2 Watching
  • G gareth_iowc
    Yz one is not wide enough. Tried this myself 2 weeks ago and gave up on that idea
    ZrakoZ
    ZrakoZ
    Zrako
    @chalkey46 Sir I need your help ☺
    @gareth_iowc !
    YZ Swingarm
    This Sir did the job mate .
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
      Anything is possible. No it's not a direct fit, but if it were then every joey would have done it.
      The only reason I didn't do it, was because I spent many many nights lining up my supermoto wheels with my current setup, changing the arm, whilst trivial, would have undone all that work.
      • ZrakoZ
        ZrakoZ
        Zrako
        At first Im spotted the 2 problems I need to deal with : 1st - the linkage fitment is different
        2nd - the brake bracket .
        Wondering if the yz bracket will fit my caliper and line up properly with the disc 🤔
          @Calum Big respect to all Joey's!!! LOL 😉
            To do it properly you are going to need to realign the whole geometry of the bike.
            With the new swingarm you are going to need the YZ brake carrier. Which will need modifiying to either accept your brake, or use the YZ brakes.
            Either way the swingarm needs altering to fit between the frame and the engine.
            This will cause the sprocket to be out of alignment with the rear sprocket, which is going to to cause undue stress to the gearbox bearings. This will need correcting by either shimming or machining.
            You are then going to find the front and rear wheels are no longer in line. So this will need altering to ensure that the front and rear wheels are inline, and the front and rear sprockets are inline.
            If you don't then you will find the bike will have a tendency to crab or to cause excessive damage to the gearbox.
            This is why my front wheel is off centre from the forks. This was done to ensure the front and rear wheels line up perfectly, whilst maintaining the correct geometry for the front and rear sprockets.
            I'm all for the swingarm conversion, but it sounds like you haven't thought this through enough?
            If you're going to do, do it right. Is all I'm going to say.
            It's just a case of measuring once, twice three times to be sure. This is the reason why I didn't use the alloy swingarm, AFTER I had already done all of this measuring.
            I should have done it all at one time and saved myself the effort of measuring twice.
            If any of that is unclear I am happy to go into more detail.
            ZrakoZ 1 Reply Last reply
              ZrakoZ
              ZrakoZ
              Zrako
              @Calum yeah to be honest Im thought its lot easier than it really is and I havent the yz swingarm in the hand to get the measurements.
              Definitely I have only 2 ways of doing this: properly or stock swingarm.
              • G
                G
                gareth_iowc
                I'm keeping the stock arm and swapping the wheel hubs over just to keep the project going ATM. I did like the idea of the yz wheel adjustment on the rear as it looks smarter than the dt 1
                DT125R 2000
                DRZ400 2006
                Golf Mk3 20v Turbo 1996
                • G gareth_iowc
                  ZrakoZ
                  ZrakoZ
                  Zrako
                  @gareth_iowc are you on supermoto project as well?
                    #26
                    Well I have seen quite a few DTRs with YZ250/WR400 swingarms. Doable.
                    Custom linkage brackets, fabricated an welded...
                    Complete YZ/WR rear end,, new chain/ possibly only a 520.
                    A earlier style YZ/WR shock will only just clear the exhaust, and will need a custom spacer just to fit it into frame shock tower!
                    This is a proper fabrication job.
                    This was the very reason a WR200 swingarm was the ONLY choice for me.
                    • G
                      G
                      gareth_iowc
                      @zrako I'm sticking with off road but I want to use the 19" rear
                      DT125R 2000
                      DRZ400 2006
                        Yeah if you wanted to do minimal fabrication then buy a YZ rear end and shock, this would minimise a lot of stuff.
                        If I had a garage I would happily make these sorts of bits for people. But I am so tight for storage at the moment it simply is not possible!
                        • ZrakoZ
                          ZrakoZ
                          Zrako
                          Guys , desperately searching internet for the complete set of swingarm bearings , pins , thrust washers , bearings . Heeelp please ☺
                          • ZrakoZ Zrako
                            @Zrako just measure them and go to simplybearings
                              ZrakoZ
                              ZrakoZ
                              Zrako
                              @Calum will do mate . Im thought that Im found one but its for 78-81 model.
                                As said I got all mine off simply bearings no problem. Saved loads of money as well!
                                • ZrakoZ
                                  ZrakoZ
                                  Zrako
                                  Small update . Engine rebuilt and frame finally came back from powdercoating. Not sure if I love the change but have to deal with it now 😂 0_1491671835721_20170407_180013.jpg
                                  3
                                  • ZrakoZ Zrako
                                    @Zrako Yes mate that is looking lovely!
                                    • ZrakoZ Zrako
                                      @Zrako If it's not as you originally envisaged, most of it will be hidden anyways, so it's all good really!!! 😉
                                      • G
                                        G
                                        gareth_iowc
                                        Same frame colour as me. I like it 🙂
                                        DT125R 2000
                                        DRZ400 2006
                                        • ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          Shame I have to wait till monday to build it up as I work all weekend now. Still no bearings for swingarm as I need all seals and the needle bearing shafts...😓
