  3. Wheels
  4. Road legal dirt tyres.
13 Posts 5 Posters 4.0k Views 1 Watching
  • G Offline
    G Offline
    gareth_iowc
    wrote on last edited by gareth_iowc
    Hi guys I'm after some recommendations on some dirt tyres.
    They need to be road legal but the main use is intended for forest/green lanes.
    Size I'm looking for is 100/90/19
    Any suggestions?
    Thanks
    DT125R 2000
    DRZ400 2006
    Golf Mk3 20v Turbo 1996
    A 1 Reply Last reply
    • G gareth_iowc
      Any suggestions?
      Thanks
      A Offline
      A Offline
      Ads123
      @gareth_iowc just find some decent tyres and cut the NOT for road use of so it says for road use and stamp a triangle on the tyre job done mine always passes its mot with no bother
      • G Offline
        G Offline
        gareth_iowc
        What are like like on road? I was told they are dangerous due to then spacing of the rubber?
        DT125R 2000
        DRZ400 2006
        • G gareth_iowc
          @gareth_iowc Bumpy lol. I used to run Continental Offroad tyres. Used to get them ex race for a fiver. Would only last a month or so. Used to kick the back end out round corners though, which was fun.
          ThT is the thing with sumo setup, too safe.
          • G Offline
            G Offline
            gareth_iowc
            I did have a look at the Michelin AC10?
            DT125R 2000
            DRZ400 2006
            CalumC B 2 Replies Last reply
            • G gareth_iowc
              @gareth_iowc Yeah I faintly remember people using those.
              • DartyD Offline
                DartyD Offline
                wrote on last edited by Darty
                Look at Continental TKC 80.
                • G gareth_iowc
                  B Offline
                  B Offline
                  Bentley
                  @gareth_iowc I've got some part worn ac 10s on mine at the mo! If I'm honest haven't ridden my Dt a lot but they seem durable and also grippy on and off road 🙂
                  • G Offline
                    G Offline
                    gareth_iowc
                    Thanks @Bentley.
                    What size is every one running on the front?
                    I've current got:
                    Front 90/90/21
                    Rear 90/100/19
                    I can't find a set that matches that. I can find an 80/90/21.
                    I can get road legal 90/90/21 but I would have to have mis matched tyres. Is that aloud?
                    DT125R 2000
                    DRZ400 2006
                    B 1 Reply Last reply
                    • G gareth_iowc
                      Thanks @Bentley.
                      I've current got:
                      Front 90/90/21
                      Rear 90/100/19
                      B Offline
                      B Offline
                      Bentley
                      @gareth_iowc I'll have to check tomoz!
                      I think they're fairly generic, by that I mean Ac-10s don't vary much in width/profile! As long as you have the correct size.
                      Mine are 18Rear 21Front
                      Does that help at all?
                      • B Offline
                        B Offline
                        Bentley
                        looks like the older Dts had a different size rear wheel!
                        19inch? I think ac10s do that however.
                        Like the previous chap said tho I can't imagine some part worn Dunlop Mx 71s will perform much different.
                        They're both a hard pack tyre and I think the stud pattern is very similar and I wouldn't pay any attention to road legal or not unless your worried about getting caught out. (Just scrub the bit out that says not for road use)
                        • B Bentley
                          @Bentley Pretty sure DTR DTRE use the same wheels.
                            B Offline
                            B Offline
                            Bentley
                            @Calum oh the chap said he had a 19 inch rear
