  3. wheelies
wheelies
30 Posts 7 Posters 9.4k Views 2 Watching
  • A
    A
    anima
    thankyou, pv servo working or pinned open ? sorry bit of a noob
      Removed baffles? it isn't a four stroke mate you need solid back pressure as to allow the supersonic sound wave to pressurise appropriately to allow the forced induction to operate.
      • A
        A
        anima
        i dunno mate but it was alot faster than it is now acceleration wise. like i said no expert im a noob, i can only theorise that the dents he put in the pipe were to compensate for the baffles being removed.
        • britshgigoloB
          britshgigoloB
          britshgigolo
          you want it working and not pinned just make sure it flush you can try sitting further back on the seat to as that will help but as i said with it set right you will see the diffrence mine comes up from pull away and im 16 stone and tops out at 85 on the clock so im sure yours should do the same if running and set up right
          A 1 Reply Last reply
          • A
            A
            anima
            appreciated
            • britshgigoloB britshgigolo
              A
              A
              anima
              @britshgigolo do you have your reed switch removed ? and what exhaust pipe have u got on it ?
              • V
                V
                vtrn_raptor
                Deps supposed to be better than big one
                • britshgigoloB
                  britshgigoloB
                  britshgigolo
                  yes reed switch is taped up under the clocks out the way and it got standard exhaust on front derestricked and dep silencer
                  • V vtrn_raptor
                    A
                    A
                    anima
                    @vtrn_raptor i have a dep pipe just havent fitted it and stil havent fitted my 240 jet either
                      A
                      A
                      anima
                      @britshgigolo nice one i may have to fit my dep its sat there i just havent bothered fitting it
                      • britshgigoloB
                        britshgigoloB
                        britshgigolo
                        im sure yours is 2001 same as mine it should have a 240 main jet as standard and mine is in use every day for work same as yours i change oil and plugss once a month and all has been fine
                        • britshgigoloB
                          britshgigoloB
                          britshgigolo
                          you will notice the diffrence once dep is fitted too
                            A
                            A
                            anima
                            @britshgigolo my dad is adimant i wont i think hes wrong though i just think he may be trying to keep me at a low as speed as possible
                              Your not going to find much extra power, get her jetted nice first,
                              Raise the rear the ride height,, and gear it down (bigger sprockets) will help dramatically!
                              • A
                                A
                                anima
                                am i right in thinking that big one expansion chambers are restricted anyway ? i have heard so and i can see a kind of mesh thing near the echaust manifold but in the start of the chamber pipe
                                DartyD 1 Reply Last reply
                                • britshgigoloB
                                  britshgigoloB
                                  britshgigolo
                                  im running standard sprocket set up as standard as did not want to lose top end as use a roads as well
                                  • britshgigoloB
                                    britshgigoloB
                                    britshgigolo
                                    i dont know much about exhaust to be fair only everyone says dep are the best buth rust like hell thas why i stayed with the standard pipe and de risticked it
                                      A
                                      A
                                      anima
                                      @Darty its pretty highly jacked anyway but illl look into a jack up kit
                                      • A anima
                                        @anima no idea,
                                        but BigOne expansion chambers are designed to make more Midrange torque, a proper homologated road pipe,
                                        If there is a baffle in the expansion chamber, then defo remove it tho,
                                          @anima no idea,
                                          A
                                          A
                                          anima
                                          @Darty i will do once i fit my dep then i got the big one as a spare only thing is as has been said the deps rust easily my big one is nearlya year old and still in perfect nick no rust practically no discolouration at all
