  3. wheelies
wheelies
30 Posts 7 Posters 8.9k Views 2 Watching
  • B Offline
    B Offline
    britshgigolo
    you want it working and not pinned just make sure it flush you can try sitting further back on the seat to as that will help but as i said with it set right you will see the diffrence mine comes up from pull away and im 16 stone and tops out at 85 on the clock so im sure yours should do the same if running and set up right
    A 1 Reply Last reply
    • A Offline
      A Offline
      anima
      appreciated
      • B britshgigolo
        A Offline
        A Offline
        anima
        @britshgigolo do you have your reed switch removed ? and what exhaust pipe have u got on it ?
        • V Offline
          V Offline
          vtrn_raptor
          Deps supposed to be better than big one
          • B Offline
            B Offline
            britshgigolo
            yes reed switch is taped up under the clocks out the way and it got standard exhaust on front derestricked and dep silencer
            • V vtrn_raptor
              A Offline
              A Offline
              anima
              @vtrn_raptor i have a dep pipe just havent fitted it and stil havent fitted my 240 jet either
              • B britshgigolo
                A Offline
                A Offline
                anima
                @britshgigolo nice one i may have to fit my dep its sat there i just havent bothered fitting it
                • B Offline
                  B Offline
                  britshgigolo
                  im sure yours is 2001 same as mine it should have a 240 main jet as standard and mine is in use every day for work same as yours i change oil and plugss once a month and all has been fine
                  • B Offline
                    B Offline
                    britshgigolo
                    you will notice the diffrence once dep is fitted too
                    • B britshgigolo
                      A Offline
                      A Offline
                      anima
                      @britshgigolo my dad is adimant i wont i think hes wrong though i just think he may be trying to keep me at a low as speed as possible
                      • DartyD Offline
                        DartyD Offline
                        Your not going to find much extra power, get her jetted nice first,
                        Raise the rear the ride height,, and gear it down (bigger sprockets) will help dramatically!
                        • A Offline
                          A Offline
                          anima
                          am i right in thinking that big one expansion chambers are restricted anyway ? i have heard so and i can see a kind of mesh thing near the echaust manifold but in the start of the chamber pipe
                          DartyD 1 Reply Last reply
                          • B Offline
                            B Offline
                            britshgigolo
                            im running standard sprocket set up as standard as did not want to lose top end as use a roads as well
                            • B Offline
                              B Offline
                              britshgigolo
                              i dont know much about exhaust to be fair only everyone says dep are the best buth rust like hell thas why i stayed with the standard pipe and de risticked it
                                A Offline
                                A Offline
                                anima
                                @Darty its pretty highly jacked anyway but illl look into a jack up kit
                                • A anima
                                  DartyD Offline
                                  DartyD Offline
                                  @anima no idea,
                                  but BigOne expansion chambers are designed to make more Midrange torque, a proper homologated road pipe,
                                  If there is a baffle in the expansion chamber, then defo remove it tho,
                                    @anima no idea,
                                    A Offline
                                    A Offline
                                    anima
                                    @Darty i will do once i fit my dep then i got the big one as a spare only thing is as has been said the deps rust easily my big one is nearlya year old and still in perfect nick no rust practically no discolouration at all
                                    • A anima
                                      DartyD Offline
                                      DartyD Offline
                                      @anima I know, Dep will rust to shit within a year without constant attention,
                                      I've had mine 4 years, only managed 7000 miles out of it,
                                      But, its the best stamped pipe for it unfortunately,
                                      4cm Jack up kit is a good height btw, I've ridden a few DT setups now,
                                      • A Offline
                                        A Offline
                                        anima
                                        any reccomendations on where to get a jack up kit from ?
                                        N 1 Reply Last reply
                                        • A Offline
                                          A Offline
                                          andrewj1680
                                          Acf 50 solves the problem of the dep exhaust rusting it's pretty expensive around £15 but it works I lagged mine a couple of months back after a clean and it's still the same condition as it was when I first sprayed it, yes it burns off the eccess when you get the bike hot but it's still protects I plan to use it every 3 months and a can seems to go a very long way
