Lingering revs and no running without choke
SO I always found that the bike never started with the stock carb without choke. So choke from cold is normal.
Once warm however it should be fine.
I would make sure the throttle is not ajar.
Its lean If it wont idle without choke when warm. Is the airscrew around 1,5 turns out?
You need to clean the carb, pay special attention to the idle jet, and the internal tube between that and the airscrew (remove the airscrew and make sure the tube is clear by spraying fluid (carb cleaner, wd40, brake cleaner or compressed air ect) through it
@Jens-Eskildsen do you know of any carbs which are a direct replacement for the dt? And not got to the screw yet will do tmoz thank you for helping me out btw.
The stock carb seems to work fine for the bike, so no I havent reserced if another one is bolt on, but wouldn't think so.
