Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
the engine on my dt125r is running fine until i put it in gear and its as if the side stand down but its not so i disconnected it and the same problem still happens. any advice
@jimmydc98 Then the clutch is slipping?
its electrical it stops sparking when put into gear
Side stand switch mate.
You can't just disconnect the side stand switch, you have to instead finish off the circuit by joining the wires if I'm right? @Calum @Darty
@Mightyman True, mine wouldnt even start,
Yeah it's a normally open circuit and you have to close the circuit for it to work.
normally open
