  4. Ignition problem
Ignition problem
24 Posts 4 Posters 6.0k Views
  • V Offline
    V Offline
    vtrn_raptor
    Hello guy just changed coil thinking that was the reason my bike wouldn't start as had no spark now I've realised it's the ignition it sparks while it's off and sparks with the ignition disconnected
      Brother had this on his bike.
      I think the CDI went faulty.
      Is the spark intermittent.
      • V Offline
        V Offline
        vtrn_raptor
        Yeah mate it only sparks 3-4 times with a hard kick
        • V Offline
          V Offline
          vtrn_raptor
          And doesn't spark at all with ignition on
            Check the side stand switch hasn't gone faulty bud.
            • V Offline
              V Offline
              vtrn_raptor
              How do I do that mate
              • V vtrn_raptor
                NINJAN Offline
                NINJAN Offline
                @vtrn_raptor It's the switch located directly on the side stand. It's programmed to cut out the engine if the stand is lowered whilst the bike is moving.
                  @CYBER-NINJA Yeah it's just above the stand.
                  It's a NO circuit, I don't know if the CDI is clever so I wouldn't say anything is programmed. It's just a switch as far as I know.
                  • V Offline
                    V Offline
                    vtrn_raptor
                    Checked that just now and still nothing it sparks perfect with the ignition off and also with it disconnected but nothing with it on
                    • V vtrn_raptor
                      @vtrn_raptor Yeah that's why I am saying check to make sure it's not faulty bud.
                      If it's faulty, it's a NO circuit. I.E. the circuit never completes and hence your problem.
                      You will want to bridge the wires and make it NC circuit. If you do that and you're still having issues, then you know it's not the side stand switch.
                      • V Offline
                        V Offline
                        vtrn_raptor
                        Ive disconnected it and still no spark mate
                        • V vtrn_raptor
                          @vtrn_raptor Yes mate, It's a NORMALLY OPEN circuit.
                          So disconnecting it won't fix the issue, as it's NORMALLY open.
                          You have to close the circuit to fix the issue. So short out the circuit which will force it into NORMALLY CLOSED state.
                          As said, if you do that and it's still not sparking then it's not the side stand switch.
                          Start off simple and we can work our way up.
                          • V Offline
                            V Offline
                            vtrn_raptor
                            How do I do that mate as new to this kinda thing
                            • V vtrn_raptor
                              @vtrn_raptor Just complete the circuit, have you a haynes manual handy as it would make a lot more sense.
                              Think of it as a light switch in your room.
                              If the light switch goes faulty then you won't be able to turn the light on, no matter what state the switch is in, to rectify the issue you would bypass the switch.
                              So whereever the wires go you will want to short out the circuit, a paperclip would do the trick.
                              • V Offline
                                V Offline
                                vtrn_raptor
                                Yeah I have a Haynes Manuel mate
                                • V Offline
                                  V Offline
                                  vtrn_raptor
                                  I disconnected the cdi moved it and reconnected it their was spark then when I disconnected and re positioned it theirs nothing
                                  • V vtrn_raptor
                                    @vtrn_raptor Sorry I'm confused?
                                    Did you short the side stand switch out?
                                    • V Offline
                                      V Offline
                                      vtrn_raptor
                                      No because it's confusing I have no idea how to open the circuit
                                      • V vtrn_raptor
                                        NINJAN Offline
                                        NINJAN Offline
                                        @vtrn_raptor You won't believe how many times this has happened to us all, but have you checked that the handlebar cut out switch is off???
                                          @CYBER-NINJA Done that too many times
