Need help
Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
@vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
I'm gunna take the pv cover of and rev it to see if it opens correctly as that could be the issue as was pinned before I got the cdi and put it back on the servo
@vtrn_raptor go to page 86 and read
Will do mate
don't go playing with carb setting yet tho I must stress to you that you should take your time and do every thing methodically or you could end up going in circles with problems you created which is what it sounds like you were doing, to begin with,
this could still be a few things ie needle jets throttle even fuel line so start from the top -
Is it possible that my exhaust is filled with something as reading this page says about Miss firing could be down to exhaust spark plug or air filter
Or could this isue be down to stale petrol as it's probably been sat in the bike for 2-4 months
@vtrn_raptor stale fuel certainly won't be helping. I suggest you get some fresh in there
for instance my brothers cbr 600f just stopped running when we were going out one day I started taking the carb off and seen a fuel pump and the carbs still got cleaned but it was the fuel pump so didn't even have to be cleaned they were minging anyways though the point is start from the top if I had checked the pump, to begin with, time would not have been wasted if fact I would have told him don't worry the bike would be fine without it there for extra fuel at really high rpm and just taken it out at the side of the road that day and we would have had a good day out
From doin a bit a research on it stale gas can make it bog kill spark plugs and not fully burn
The pump on the dt is a tap isn't it ?
@vtrn_raptor hahaha this is perfect exactly what I mean
how long it been in there and that probably not it thou but don't help matters -
@vtrn_raptor there is no pump on a dt was using the story as example
What kinda fuel do you use on a dt my last one I was running high octane
@vtrn_raptor said in Need help:
exhaust is filled
no
stale petrol
no, but change anyway not a good thing when you have carb problems
What kinda fuel
any for me I did always run v-power or super at bp but in the DT I'm not bothered
Fuck sake.
When the engine starts to die, turn the choke off.
Regardless of Terry's bike, or anyone elses, I know from personal experience that my bike never started without choke. Needed it for about 30 seconds, or until it's about to die off. Then choke off. Then ride it until it's up to temperature.
I'll take it for a longer ride later with some fresh fuel and see how it is as didn't take it very far earlier and go from their as bike hasn't been riden in about 2 months and only done 30miles on new piston
@vtrn_raptor Not being funny. My DT was off the road two years. Literally kicked it over on a brand new engine and road it fine.
Same fuel, didn't even bother charging the battery.
So I doubt it's the fuel really.
Fuck sake.
calm down I didn't contradict you pal every bike has its own character and our bikes are clearly different I did not say it's bad or good I just said mine starts fine cold without choke runs sweet with a nice brown tinge to the tip now I played a bit with the carb im just saying to him don't worry about that its a sign, not an issue
